popeye Posted April 29, 2021 Share Posted April 29, 2021 Have an 06 legacy with standard 2.5L and auto trans. Started noticing that when I push on the gas hard the car will rev up to almost redline and won’t shift until I let off the gas. This happens in all the gears. However when driving normal it shifts fine all the way to 4th gear with no issues. Anyone have any ideas? Link to comment Share on other sites More sharing options...
boxkita Posted April 29, 2021 Share Posted April 29, 2021 if you don't let up, does it shift? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
popeye Posted April 29, 2021 Author Share Posted April 29, 2021 No does not shift - just revs up to top of its range. Minute I take my foot of throttle once RPMs drop a little it shifts. The tranny fluid is nice and purple and I had it changed less than 20k ago. Regular driving and tektronix appear to work fine. Link to comment Share on other sites More sharing options...
apexi Posted April 30, 2021 Share Posted April 30, 2021 In your shoes I'd probably try a TCU reset and go from there. Other posts I'm reading make it sound like you can only reset the TCU with a subaru select monitor, or FreeSSM. Link to comment Share on other sites More sharing options...
DaveWaters Posted April 30, 2021 Share Posted April 30, 2021 Does it hit fuel cut? Link to comment Share on other sites More sharing options...
popeye Posted May 1, 2021 Author Share Posted May 1, 2021 Thanks for the recommendation for a TCM reset. Have to look into this. For the other reply I do not know what reaching fuel cut means. I am having other issues with bank 1 running lean and U1221 and U1223 if that matters or can have an effect on shifting under heavy acceleration. Link to comment Share on other sites More sharing options...
DaveWaters Posted May 1, 2021 Share Posted May 1, 2021 Fuel cut is the type of rev limiter on these cars. If you rev too far the ecu will cut fuel and engine will stutter hard and you’ll know it. If you haven’t hit it you may not be allowing the car to reach it’s shift point before letting off out of fear that you’ll hit redline. Just to confirm, your problem only happens when foot to the floor in sport mode? Link to comment Share on other sites More sharing options...
