1-3-2-4 Posted January 30, 2018 Share Posted January 30, 2018 Ok so thought it was the remote it stopped working for a few weeks then started working again but still iffy.. ordered a new one and programmed it and it worked good for about 3-4 days now it’s back to not working.. entered the code in 3 Times now and still won’t unlock. I also noticed the car will no longer Auto Unlock if the key is still in the car ignition now.. has anyone had this issue in which replacing the remote with new it still did not work? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 31, 2018 Author Share Posted January 31, 2018 Jesus Christ I can't even use the key now to get in the car because it's jammed with something can't get it to turn + my keyless entry feels like it doesn't want to work again. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 31, 2018 Share Posted January 31, 2018 The lock is not frozen is it ? have you got the car wet like by washing it lately ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 31, 2018 Author Share Posted January 31, 2018 Not frozen but yesterday I don't know what the hell happened but someone cleaning the snow kicked up a lot of sand and it ended up on my hood and some on the drivers side door.. when I left work I had to manually unlock because the keyless stopped working again on the new remote. Now I can't turn the key in the door now Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 31, 2018 Author Share Posted January 31, 2018 Finally got in the car.. I have to do something about this keyless issue however it’s starting to become a annoyance Link to comment Share on other sites More sharing options...
r.lee89 Posted February 1, 2018 Share Posted February 1, 2018 I had a similar issue a year ago where all 4 of my remotes will intermittently work. I put new batteries in them they would work normally for 2-3 week then back to the same issue. (These were dollar store batteries) Then i bought some name brand battery like Duracell into 2 remotes they worked okay for 2-3 months then back to same issue. Really started to think its the receiver in the car. So i replaced it and reprogrammed remotes and same issue. Then i decided to get some genuine Maxell batteries and have not had an issue since. All of these batteries had 2.8-3.0 V when tested. Even the Maxell only have 3.0V when new and after 1 year they have 2.7V and they work fine. My guess is when the battery gets a load thats when it fails. As for the auto unlock it could be the bcm or the door ajar has no signal. When you put the key in the ignition with the door open does it even chime? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 1, 2018 Author Share Posted February 1, 2018 I had a similar issue a year ago where all 4 of my remotes will intermittently work. I put new batteries in them they would work normally for 2-3 week then back to the same issue. (These were dollar store batteries) Then i bought some name brand battery like Duracell into 2 remotes they worked okay for 2-3 months then back to same issue. Really started to think its the receiver in the car. So i replaced it and reprogrammed remotes and same issue. Then i decided to get some genuine Maxell batteries and have not had an issue since. All of these batteries had 2.8-3.0 V when tested. Even the Maxell only have 3.0V when new and after 1 year they have 2.7V and they work fine. My guess is when the battery gets a load thats when it fails. As for the auto unlock it could be the bcm or the door ajar has no signal. When you put the key in the ignition with the door open does it even chime? Yes with the key in and the door open it does chime. Link to comment Share on other sites More sharing options...
