DN1911 Posted June 24, 2010 Share Posted June 24, 2010 has anyone tried to put a larger radiator, like a WRX, into an older gen Legacy? i have a 95' Legacy that is running into some cooling issues and with fixing the problem i was thinking about putting in a larger cooler but wasn't sure what might fit? Link to comment Share on other sites More sharing options...
kaz98gt Posted June 24, 2010 Share Posted June 24, 2010 I don't think you'd want to try that; the one that's in there now should do a good job at keeping everything cool if it's functioning properly. What's your motive for going to a larger one? Before you start though, what kind of cooling issues? Link to comment Share on other sites More sharing options...
DN1911 Posted June 24, 2010 Author Share Posted June 24, 2010 the radiator isn't the issue but just figured if a slightly bigger one would fit then great. here is a cut and paste from another forum: I've got a cooling fan issue with my 95 Legacy that is driving me nuts at this point. if we drive the car with the AC on it will start to get warm. i have to shut the AC off and will usually turn the heat on for a short bit to help bring temp down. the temp will fall back into a normal range fairly quickly once the AC is off. what i have found is the drivers side fan is not coming on. i have tested the fan with jumper wires and it does work. i also swapped the relays around from what the haynes manual shows, they all seem fine. so I'm down to the coolant temp sensor, ECU, or a minor wire issue. i don't think it's the sensor because i was told by a Subie Tech that the car would more than likely not run correctly and probably toss a CEL by now. Link to comment Share on other sites More sharing options...
DN1911 Posted June 25, 2010 Author Share Posted June 25, 2010 kind of looks like the early Legacy Turbo radiator may fit.. similar size with thicker core Link to comment Share on other sites More sharing options...
