Tehnation Posted August 4, 2020 Share Posted August 4, 2020 I banged up my car a while ago, so I don't have that sticker that has all the ac data. Anyone know how much refrigerant is needed for the system or a picture of that ac tag? Link to comment Share on other sites More sharing options...
rhino6303 Posted August 5, 2020 Share Posted August 5, 2020 I banged up my car a while ago, so I don't have that sticker that has all the ac data. Anyone know how much refrigerant is needed for the system or a picture of that ac tag?It's in the FSM. Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 13-15oz Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 And depending on your climate, it’s very picky. Link to comment Share on other sites More sharing options...
apexi Posted August 5, 2020 Share Posted August 5, 2020 https://parts.subaru.com/p/Subaru_2005_Legacy-25L-TURBO-5MT-4WD-GT-Limited-Sedan/AC-System-Information-Label/49283385/73772AG02A.html Link to comment Share on other sites More sharing options...
jp233 Posted August 5, 2020 Share Posted August 5, 2020 yes, 13-15 oz of HFC134a fridge. It says only to use Denso Oil 8 in the compressor, too Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 denso oil 8 i think is the same as pag 46 oil. Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 It's in the FSM. I looked in fsm, couldn't find it in the ac section. Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 Anyone know how much compressor oil it needs? I'm flushing out the entire system so I can start from scratch. Link to comment Share on other sites More sharing options...
Infosecdad Posted August 5, 2020 Share Posted August 5, 2020 I think it's on pg 5923 (AC-23). If I'm reading it correctly, it says 70g? Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 Mine has this gibberish. Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 (edited) I found what you are looking at! Thanks for heads up! Basically, I'm going to break the system somewhere and push air through it to push out all the old stuff. Then you have to crack the schrader valve for one of the service ports, probably hi side, put system under vacuum and let it suck in some oil. Make sure to weigh the oil! The r134a can's already have their weight on it. My cans are like 12oz, so I will have the extra can on scale while its going in, and stop when it loses 2 oz's. Edited August 5, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 70g's is 2.46918 ounces. this is all weight not volume for anyone reading! For the refrigerant 400 +-30 = 370-430 grams, 13.0514oz - 15.1678oz. It says amount contained in compressor, which is kind of confusing. The oil moves through the entire system. I'll just assume that's what the total system needs. Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 Mmmm sadly no. Weigh the cans before. I have yet to see one have exactly what it says. If you have metal in the system there is a can of stuff you can put in but I just break the lines and use brake clean and blow compressed air through them into a paper towel till it’s clean. Add the oil to your compressor then put the vacuum on the system. The vacuum will boil out any moisture. Add refrigerant from a vacuum and when you weigh your cans tare the weight. Be as precise as you can, these cars are fickle bitches with ac in the heat Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 Also the evaporator and condenser will hold oil. Usually just blow out the evaporator and if it’s open it’s best just to replace the expansion valve and condenser Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 where do you pour in the oil? directly into the compressor on top? And where do you push the brake cleaner and air through? Will weigh them first, thanks for the tip. Any other tips? Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 WITH oem spec parts. I replaced the expansion valve a few years ago with an autozone replacement and the ac cycled constantly. Replaced with the dense oem and the orifices were different size. Ac has worked about as good as it can ever since Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 (edited) Add your oil to the larger hole on the compressor, that’s the intake. Rotate the compressor a few times by the clutch. When I clean the lines I separate them in sections. Line from the compressor to the evap, evap to the condenser and condenser to the compressor. Spray in one side and blow and out the other. Replace all o rings along the way Edited August 5, 2020 by blackobxt Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 ah hell, this sounds like project lol. Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 It’s not so bad! Just disconnect the two hoses at the compressor, disconnect the two hoses at the evap on the firewall and hopefully you are replacing the condenser and expansion valve. Just clean the lines replace the o rings and put it all back together. Easy peasy. Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 Should take less than an hr. You will spend more time waiting with a vacuum on the system than you will on cleaning and replacing Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 the condenser was changed before I took the car off the road, actually I went through several, rocks keep eating them. Why change the expansion valve? Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 (edited) It’s purpose in the system is to be a restriction so blockages can form there and with it only being like $13 why not? Edited August 5, 2020 by blackobxt Link to comment Share on other sites More sharing options...
Tehnation Posted August 5, 2020 Author Share Posted August 5, 2020 part # 72126AG14A this guy? https://parts.subaru.com/p/Subaru_2005_Legacy-25L-TURBO-5MT-4WD-GT-Limited-Sedan/Cover-Expansion-Valve/49280596/72126AG14A.html 73210AG01A is condenser.... 300 bucks, I always get them on amazon or rockauto for like 70-80. Link to comment Share on other sites More sharing options...
blackobxt Posted August 5, 2020 Share Posted August 5, 2020 (edited) 4752046 on rock auto for the expansion valve $17.52 The condenser is less important to be oem spec, buy that shiz on amazon for $73 Edited August 5, 2020 by blackobxt Link to comment Share on other sites More sharing options...
