superdopepenguin Posted March 5, 2016 Share Posted March 5, 2016 Aloha all, I just hit 100k mi in my 05 Lgt 5mt Ltd and am looking to do some upgrades. I flashed stage 1 (Cobb AP), got a catless uppipe and cobb sts on the way. Have done a lot of searching/reading and it sounds like a rear sway bar is a good next step? Looking for any advice on size, brand, if I should do front + rear, and if I need to upgrade anything else like struts, coils, endlinks, etc when I do this. Figure it might need it w/ 100k mi and then throwing on a bigger sway bar(s). Thanks for the help ya'll! Link to comment Share on other sites More sharing options...
K2e2vin Posted March 5, 2016 Share Posted March 5, 2016 I'd say tires. Link to comment Share on other sites More sharing options...
ashwinearl Posted March 5, 2016 Share Posted March 5, 2016 Most say that if you get a bigger rear sway bar to also put in a reinforcement bracket (like the AVO one) at the same time. For endlinks, Kartboy's and Moog are often recommended. The stock mounts for the rear sway bar can bend/break. If they break, they need to be re-welded. I personally didn't see a huge improvement with just sway bars. I later went with Koni inserts and stock springs and am still on the fence of going with some stiffer springs. 100k on the stock struts and they are probably tired. Link to comment Share on other sites More sharing options...
