RedDawg Posted December 28, 2015 Share Posted December 28, 2015 Headed out to work this morning and the car wouldn't start. Luckily the wife was off today so I could take her car. Just tried to jump-start it after work using her car and no-go. Nothing lights up, no gauges, no startup sequence, and no starter clicking. If it was the starter, but I had a good battery, wouldn't the gauges still light up during the startup sequence? Dome light works and keyless entry/chirp still works, but no dash lights turn on. Link to comment Share on other sites More sharing options...
lee07 Posted December 29, 2015 Share Posted December 29, 2015 Check the battery voltage, should be around 12.5v Link to comment Share on other sites More sharing options...
Harsho1 Posted December 29, 2015 Share Posted December 29, 2015 also check battery cable ends Link to comment Share on other sites More sharing options...
RedDawg Posted December 29, 2015 Author Share Posted December 29, 2015 Tried a new battery, cleaned battery terminals, checked all fuses.......still nothing. Link to comment Share on other sites More sharing options...
ragman Posted December 30, 2015 Share Posted December 30, 2015 When turning it over, check the volts at the starter. If its getting 12V at the starter, then I'd think the starter is shot. If you have no power at the starter, then you'll have to investigate fuses, wiring, ignition switch, etc. Link to comment Share on other sites More sharing options...
