Zac88 Posted February 12, 2020 Share Posted February 12, 2020 Was driving last night, -20C first couple minutes of my trip could smell fuel and had a missfire, once the engine warmed up it went away, the CEL was not on the dash but when I scanned it with my Accessport the P0304 Showed up. Plugs are 6 years old, time to change? Our weather has been to extreme cold to warm in a matter of weeks. Fuel issues? I barely drive the car anymore so maybe just a hiccup? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 12, 2020 Share Posted February 12, 2020 6 years, on the plugs...how many miles ? they should be changed out at 60,000 miles. I have gone to like 73,000 miles before I had issues. Have you tightened the gas line clamps under the intake manifold ? they have been known to leak when its really cold. Other issues the 05's have are the small black O-rings between the TGV's and the intake manifold. They should be replaced with the new larger orange ones. With a good flash light, you should be able to at the joint and see the O-ring color. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Zac88 Posted February 12, 2020 Author Share Posted February 12, 2020 I replaced the plugs when I had the intake manifold off to replace the o rings and gas line clamps Not sure about mileage, maybe 60,000km, this car isn't driven the easiest. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 12, 2020 Share Posted February 12, 2020 I'll assume the car has a 3" DP and tune ? That should have helped the exhaust valves. A can of Berryman fuel additive may help if its fuel related. https://www.bing.com/shop?q=berryman+fuel+additive&FORM=SHOPPA&originIGUID=FEBE64FCD1D347F5ABB2670C94F0E073 May be a can of dry gas too. If you have some water/condensation in the tank. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Zac88 Posted February 12, 2020 Author Share Posted February 12, 2020 Would Seafoam in the tank work? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 12, 2020 Share Posted February 12, 2020 Yeah, see if it something to handle moisture. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 13, 2020 Share Posted February 13, 2020 I'd maybe suggest some Berryman's B12 fuel additive (old JmP recommendation), get the tank filled up and give it a good drive if you haven't really stretched it out in awhile. Assuming it's driving fine. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Zac88 Posted February 13, 2020 Author Share Posted February 13, 2020 Alright so I reset the ECU, drove to Canadian tire and put 2 bottles of seafoam in the tank. Had fun on the icy roads home. Checked codes when I got home and they were gone, DAM was 1.0 Just weird occurrences I'm guessing? Link to comment Share on other sites More sharing options...
Zac88 Posted February 17, 2020 Author Share Posted February 17, 2020 well its really cold again this morning and the misfire is back, was doing it even while idling. Next step is to swap coil packs? Link to comment Share on other sites More sharing options...
gkinslow Posted February 19, 2020 Share Posted February 19, 2020 Assuming it is the same cylinder, that's where I'd start. Swap coil or plug and see if the misfire follows. Link to comment Share on other sites More sharing options...
