InsatiableAmos Posted June 20, 2020 Share Posted June 20, 2020 I have a 2005 Legacy GT that is throwing a P0340 Intake Cam Sensor Bank 1 code. The code pops up while cranking in a very specific way: When starting the car after clearing the code, it sputters but does not catch and start after the first crank, and then immediately throws the code. If I keep cranking the second crank catches and the car starts and runs just fine. This is repeatable - I’ve been able to do it 2-3 times in a row in my driveway. I’ve replaced the bank 1 intake cam sensor, and I’ve even tried disconnecting the alternator to see if a noisy alternator signal is causing the issue (see this thread: https://forums.nasioc.com/forums/showthread.php?t=2786898&page=2 ) and neither have resolved the code. Any ideas as to what might be the culprit? How do I test the power/harness connection to the sensor? Link to comment Share on other sites More sharing options...
InsatiableAmos Posted June 20, 2020 Author Share Posted June 20, 2020 Ahh, I think I found the issue: Two of the wires pulled out of the Cam Position Sensor connector plug! That would probably do it... Anyone know the part number for the harness-side connector so I can replace it? Link to comment Share on other sites More sharing options...
InsatiableAmos Posted June 21, 2020 Author Share Posted June 21, 2020 As usual - iWire to the rescue: https://www.iwireservices.com/product-page/cam-position-sensor-dbw I just wish they were local to me... Link to comment Share on other sites More sharing options...
Paycheck Posted November 29, 2020 Share Posted November 29, 2020 Hi there, Did the new connector solve your issue? I've been chasing the same code for a couple of years now. In my case, it only appears in cold weather. However, I did find this (pic attached) in a manual that another user shared a while back. Might help you too. I haven't gotten to it myself, but now that the cold weather is here, it's time to get out the multi meter. I'd be curious to know how you make out. $$$ Link to comment Share on other sites More sharing options...
Register a new accountSign in
