seiyafan Posted July 1, 2016 Share Posted July 1, 2016 The extended warranty I purchased on mine is about to expire in three thousand miles. What do you guys do for a check up to identify potential issues? I am thinking of doing an oil analysis. Maybe I will take the car to an auto shop for a thorough check? Link to comment Share on other sites More sharing options...
capttris Posted July 1, 2016 Share Posted July 1, 2016 How many miles on your car? Have you had any issues/repairs/trouble with anything? It's definitely worth it to bring it in and have the dealer take a look to verify there are no issues and nothing to claim under warranty. if they don't find anything, you may have to pay them for their labor to inspect. You should discuss and negotiate this up front, and maybe pay for an oil change/state inspection/tire rotation and perhaps they will then inspect for free if its up on the lift Link to comment Share on other sites More sharing options...
seiyafan Posted July 1, 2016 Author Share Posted July 1, 2016 67000 on the car, zero issue so far. Link to comment Share on other sites More sharing options...
NVAKeith Posted July 2, 2016 Share Posted July 2, 2016 Check for oil leaks. http://legacygt.com/forums/showthread.php/ez36-oil-leak-dealer-wants-pull-engine-249938.html Link to comment Share on other sites More sharing options...
minuccims Posted July 6, 2016 Share Posted July 6, 2016 I looked at all of the TSBs. One of them swapped out the radio from volume fluctuation, another fixed blue tooth, . I also had the rear trunk pistons replaced under extended warranty. It's 50$ a visit, (from recollection) so stack as many up at one time. Never had them paint the stopper rod TSB, but that may be good to do. http://techinfo.subaru.com/search/listResults.html Link to comment Share on other sites More sharing options...
PrimeRib Posted July 6, 2016 Share Posted July 6, 2016 Keep driving it. Link to comment Share on other sites More sharing options...
seiyafan Posted September 22, 2016 Author Share Posted September 22, 2016 The dealership offered a multi-point inspection but I doubt that's sufficient to identify things that might break soon, or is it? Link to comment Share on other sites More sharing options...
NVAKeith Posted September 23, 2016 Share Posted September 23, 2016 Typicaly when it comes to warranty repair, non-wear items are either broken or they aren't. If they're broken, then the warranty will fix them. If something is "on its way out" then you'd have to convince the warranty company that it requires fixing. Check the wheel bearings, check for oil leaks, strange noises, etc., a multi-point inspection should catch those if the mechanic is thorough. I'd be surprised if a repair would be authorized based on an oil analysis (unless it alerted you to coolant/oil mixing). Link to comment Share on other sites More sharing options...
seiyafan Posted September 23, 2016 Author Share Posted September 23, 2016 Not sure if shocks are included in the Gold plus warranty but I guess unless it's seriously broken like leaking oil, just feeling sluggish won't do unless I can convince them, lol. Link to comment Share on other sites More sharing options...
