TheDon427 Posted August 20, 2012 Share Posted August 20, 2012 Hey guys, I'm at work so I apologize if I leave any info out. Basically, my wife hates the way my stock Spec.B rides. I too have been surprised at how "stiff" it feels going over bumps. I just hit 34k miles so I doubt my suspension is blown. Anyway, she said I can go ahead and get a new suspension setup as long as it improves ride quality. As of right now, the only suspension mods are Rallitek fr/r sways and endlinks. So, I already have a set of JDM Pinks brand new in the box. I was waiting on picking up a set of HD's. However, I'm now worried that would not improve the ride quality as she has requested. So, my other option would be a good set of coils like KW's or RCE. Has anyone had both of these setups? How does the HD/Pink compare to stock regarding ride quality? The car is a daily driver, about 63 miles daily, so ride comfort is a concern. Stick with Pinks and get either Bilstein HD's or Koni's? Or get a quality set of coilovers? Car is 100% dd, no track use. Main concern is ride quality. Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 20, 2012 I Donated Share Posted August 20, 2012 Koni yellows are adjustable, and fairly inexpensive as far as shocks go. Link to comment Share on other sites More sharing options...
xero287 Posted August 20, 2012 Share Posted August 20, 2012 Coils will never be softer than struts/springs. Go with the HD/Pinks. Link to comment Share on other sites More sharing options...
Pete1122 Posted August 20, 2012 Share Posted August 20, 2012 Do the Koni, that way you can dial them in to your preference. Link to comment Share on other sites More sharing options...
TheDon427 Posted August 20, 2012 Author Share Posted August 20, 2012 Not looking for them to necessarily be "softer" but a better ride quality. A good quality coilover (RCE or KW... not ISC, BC, etc.) will have far superior dampening when hitting bumps instead of riding like a Civic on cut springs. The Koni's are better than HD's? Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 20, 2012 I Donated Share Posted August 20, 2012 Not looking for them to necessarily be "softer" but a better ride quality. A good quality coilover (RCE or KW... not ISC, BC, etc.) will have far superior dampening when hitting bumps instead of riding like a Civic on cut springs. The Koni's are better than HD's? Yes the konis are better than the HDs. Also, they're adjustable so you can dial in what kind of response from them you want. Link to comment Share on other sites More sharing options...
TheDon427 Posted August 20, 2012 Author Share Posted August 20, 2012 How are the Koni's when matched with the JDM Pinks? Link to comment Share on other sites More sharing options...
iggybdawg Posted August 20, 2012 Share Posted August 20, 2012 Contact Shaikh at Fatcat Motorsports, have him rebuild a set of bilsteins to match the pinks and request comfort. I got a used set of bilstein pss coilovers here, and he is rebuilding them for me right now. They take a long time, though, so if you go that route, maybe you should be a used set to send him rather than taking them off your car and having it undrivable for so long. http://www.fatcatmotorsports.com/ Link to comment Share on other sites More sharing options...
mr.hicksta Posted August 20, 2012 Share Posted August 20, 2012 I'm switching to HDs/Pinks from RCE Tarmac 1s and have been told the combination is outstanding. While I'm sure somone has ran Konis/Pinks it seems that the usual combination is HDs/Pinks. I don't think you'll be disappointed going with HDs... Link to comment Share on other sites More sharing options...
mr.hicksta Posted August 20, 2012 Share Posted August 20, 2012 Contact Shaikh at Fatcat Motorsports, have him rebuild a set of bilsteins to match the pinks and request comfort. I got a used set of bilstein pss coilovers here, and he is rebuilding them for me right now. They take a long time, though, so if you go that route, maybe you should be a used set to send him rather than taking them off your car and having it undrivable for so long. http://www.fatcatmotorsports.com/ I sent my HDs back to Bilstein in CA and was told it would take 6 weeks to complete. Either way they'll be matched to my JDM Pinks and I'm looking forward to ditching the coils for that setup Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 20, 2012 I Donated Share Posted August 20, 2012 I'm going to be running koni/epic when I get mine done. I've heard this is also an amazing combo. Link to comment Share on other sites More sharing options...
TheDon427 Posted August 20, 2012 Author Share Posted August 20, 2012 I'm going to have to read up some more but can't find many threads/members that discuss Koni's and Pinks. Plenty for HD's and Pinks though. Link to comment Share on other sites More sharing options...
whitetiger Posted August 20, 2012 Share Posted August 20, 2012 they are great with pinks. again, since konis are adjustable, you can set them so they are good with nearly any reasonable spring rate, pinks included. HD's are not adjustable so they are what they are with pinks and if you dont like them, too bad. konis are just better. Link to comment Share on other sites More sharing options...
TheDon427 Posted August 20, 2012 Author Share Posted August 20, 2012 I just read that the Koni's can't be installed on the factory Bilsteins. Is this true? If so, I may be out of luck and have to get the Bilstein HD's or look into other strut options such as Tokico, KYB, etc. Link to comment Share on other sites More sharing options...
whitetiger Posted August 20, 2012 Share Posted August 20, 2012 yes, you need regular lgt struts and top hats for the konis. they are easy to find though. ypu just need the fronts, you can re-use your rear hardware. Link to comment Share on other sites More sharing options...
Pete1122 Posted August 20, 2012 Share Posted August 20, 2012 I run Koni struts with Cobb springs and love the setup. Link to comment Share on other sites More sharing options...
TheDon427 Posted August 20, 2012 Author Share Posted August 20, 2012 Thanks, Pete but I have Pinks, not COBBS. I'm trying to gauge whether or not it's worth keeping the Pinks or dropping the $$$ on a good set of coils. If I keep the springs, I then need to figure out which struts are best for comfort. Link to comment Share on other sites More sharing options...
scoobydoobie Posted August 20, 2012 Share Posted August 20, 2012 Pinks are a JDM spring and are designed to work with bilsteins. I have HDs/Pinks and the ride is pretty stiff. Great handling and a nice ride but harsh over bumps and rough roads. Link to comment Share on other sites More sharing options...
TheDon427 Posted August 20, 2012 Author Share Posted August 20, 2012 Yup, I'm aware that the HD's and Pinks are made for each other in regards to handling and performance. However, my main priority is ride comfort. If I decide to go with Koni's, I think what I'll do is buy a set of LGT struts and gut them so that I can resell the Spec.B struts and springs. Link to comment Share on other sites More sharing options...
CapnJack Posted August 20, 2012 Share Posted August 20, 2012 How soon you want them? I ordered my pinks from EDO Performance about 8 weeks ago. They are due to be here in two weeks from Japan. I could not find anyone that stocked them in the states. My understanding is that unless you can find a used set or someone has them sitting on the shelf, be prepared for a wait. Link to comment Share on other sites More sharing options...
sbw Posted August 21, 2012 Share Posted August 21, 2012 The HDs are significantly stiffer than oem spec b bilsteins takeoffs. There's no more "comfort" in HDs. You're moving from a softer suspension to a stiffer suspension. Link to comment Share on other sites More sharing options...
TheDon427 Posted August 21, 2012 Author Share Posted August 21, 2012 CapnJack, I already have the Pinks. New in the box. So it seems like I'm going to search for reviews of the Koni/Pinks combo or find a set of RCE's, KW's or similar quality coils. Link to comment Share on other sites More sharing options...
Heedz Posted August 21, 2012 Share Posted August 21, 2012 RCE Tarmac 1's ride amazing WPMarky can attest to that since I was in his car Struts would be a cheaper option and pinks would not be a bad keep with them but I would get springs that would be fit for your set up. Since you still have not used your pinks yet, you can definitely still sell them and get a different spring set easily. If you want improved handling and a bit of lowering theres plenty of reviews here on epic springs with konis on soft settings riding almost like stock, and when you want to with the konis you have the choice to stiffen it up. I have swifts with konis and also the Perrin PSRS, the ride is not the softest but definitely rides better than some cars on other suspension set ups I've been in. Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 21, 2012 I Donated Share Posted August 21, 2012 RCE Tarmac 1's ride amazing WPMarky can attest to that since I was in his car Struts would be a cheaper option and pinks would not be a bad keep with them but I would get springs that would be fit for your set up. Since you still have not used your pinks yet, you can definitely still sell them and get a different spring set easily. If you want improved handling and a bit of lowering theres plenty of reviews here on epic springs with konis on soft settings riding almost like stock, and when you want to with the konis you have the choice to stiffen it up. I have swifts with konis and also the Perrin PSRS, the ride is not the softest but definitely rides better than some cars on other suspension set ups I've been in. ^^There will be a GB for epic springs soon... Link to comment Share on other sites More sharing options...
scoobydoobie Posted August 21, 2012 Share Posted August 21, 2012 The HDs are significantly stiffer than oem spec b bilsteins takeoffs. There's no more "comfort" in HDs. You're moving from a softer suspension to a stiffer suspension. This. Any combination of HDs or Koni's with aftermarket springs will make for a stiffer, harsher ride than your stock Spec.B suspension. As far as high dollar coilovers riding smoother than stock, I have no experience or input about that. Link to comment Share on other sites More sharing options...
