Turned on Headlight but NO HEADLIGHT?!
First encounter with this problem after 7 years of ownership.
Everything was fine until I parked the car and got take out. I turned on the ignition and switch on the light, but no headlight. The interior dash and center console is on, the parking light is on but NO HEADLIGHT? WTF is the problem here?
I had to drive 3 miles on local street with only my halos on, i feel so stupid!
Instagram: itshangertime :spin::spin::spin: ○ ○ ○
I'm thinking both burned out at the same time, or you bruned out a while ago and he never noticed.
Subaru made a stronger bulb back in late 04 or so. I was going through low beams and Silverstars every few weeks back in that time. Then I bought the OEM replacements and they lasted until few months back, one low beam when it and I bought 65w Osrams through the link in this site.
http://legacygt.com/forums/showthread.php/daniel-stern-lighting-and-subaru-headlight-options-45991.html
Engine Build - Click Here
If they're the original bulbs, you've been quite fortunate. Most of the '05-06 have short bulb life. I blame it on the DRL's but others have different opinions.
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
I blew both the headlights at the same time on my 05 OBXT - THE DAY I BOUGHT THE CAR NEW FROM THE DEALERSHIP. It's definitely possible.
[CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER]
http://memegenerator.net/cache/instances/400x/12/12982/13293951.jpg
you get it fixed?
lol^
was going to find the problem but both headlight miraculously turned on.
Although, last night my driver side was off but that side has always given me problems.
Every now and then, my driver's side headlight doesn't cut on when I first start the car. I have to get out and tap the housing. The light bulb isn't loose at all either.
that happens to me every 3-6 months. before last weekend it only happens on the driver side. but now the problem had switched over to the passenger side for the first time :eek: and then both headlights.
I took a look at the wiring yesterday, from what I can see, the problem is with the connectors. The pins are kind of rusted. A temporary fix I've found is to sand it down with sand paper and it'll last me another 6 months.
Now I give up. Considering going back to halogen bulb or retrofit :spin:
