Iltl32 Posted April 18, 2021 Share Posted April 18, 2021 Watched a few videos and they all just say remove the nut. The axle spins freely with the nut though. What am I missing? Sent from my SM-G991U using Tapatalk Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted April 18, 2021 Share Posted April 18, 2021 Not sure which location you're referring to and I've completely down a 4th gen lgt to the bare chassis, a diagram or photo would go a long way. Sometimes bolts get rusted in bushing etc, making removal a much more difficult task than it should be. Link to comment Share on other sites More sharing options...
Iltl32 Posted April 18, 2021 Author Share Posted April 18, 2021 This bolt. The 32mm that girls the hub to the axle. It'd not a matter of rust, the issue is that the axle spins with the nut so there's no way to torque the nut. Sent from my SM-G991U using Tapatalk Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted April 18, 2021 Share Posted April 18, 2021 (edited) with out the e-brake I think your only option is a large pry but the nut is still peened over the end of the axle. Edited April 18, 2021 by Shawn06SpecB Link to comment Share on other sites More sharing options...
Iltl32 Posted April 18, 2021 Author Share Posted April 18, 2021 Nevermind, got it by holding a crowbar between the studs. Sent from my SM-G991U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted April 18, 2021 Share Posted April 18, 2021 You break torque on that axle nut, before you lift the car off the ground. Then remove it once jacked up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 19, 2021 Share Posted April 19, 2021 Glad you got it off. Put a wheel/tire on it without a center cap (spare works good for this too), sit on the floor so the car's weight is on it, break it loose. Link to comment Share on other sites More sharing options...
jams20 Posted April 19, 2021 Share Posted April 19, 2021 Car needs to be on the ground to torque it too. Keep the center cap off for this as well. Avoid rejack/tire removal process i went through the first time. Link to comment Share on other sites More sharing options...
whitetiger Posted April 20, 2021 Share Posted April 20, 2021 why not just go get a cheap electric 1/2" drive impact gun and uggadugga it off. if you dont have one, its good to have in general in your tool arsenal. my cheap ryobi one will take them off all day long. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 20, 2021 Share Posted April 20, 2021 I usually keep the rotor and brake pads on, lift the car, ask my wife to press super hard on the brake pedal. That's it. Just did that (for the 15th time maybe ) a couple of weeks back. Link to comment Share on other sites More sharing options...
