Countchocula Posted April 17, 2021 Share Posted April 17, 2021 (edited) Edit: It was the motor. Or anything else to check? Doesn't move at all No motor noise from wither driver's switch or passenger door switch? Order a new Motor/regulator? Or some other diagnostic to check? Thanks!! Edited April 23, 2021 by Countchocula Fixed Link to comment Share on other sites More sharing options...
Scubaboo Posted April 18, 2021 Share Posted April 18, 2021 They sometimes stick when not used in a while. It may take a few up/down presses on the switch to get it to move. I once had the drivers window not move no matter what though, it was the motor for that one. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 19, 2021 Share Posted April 19, 2021 First try the various relays/fuses in the car and in the engine bay then try driver side window switch bank, it functions as a breaker of sorts for the other 3 doors. If the passenger/other doors were working fine and now are not they all have not failed at once. If you dont want to buy a new switch you can test voltage btwn the switch and window motor and body harness to switch. Link to comment Share on other sites More sharing options...
Countchocula Posted April 20, 2021 Author Share Posted April 20, 2021 Thx for the replies. So not sure why I wouldn't have checked fuses but I thought you may have been on to something when there was NO FUSE in the INSTRUMENT PANEL #29 location Lower Left corner which is "POWER WINDOW RELAY" I put in a 30A and No change at all. There was another fuse two to the right 29 - a 20A for the Power window passenger side" and was fine. I swapped the P/W relay with the horn relay and no change. All windows work except the Front Passenger. Link to comment Share on other sites More sharing options...
Countchocula Posted April 23, 2021 Author Share Posted April 23, 2021 It was the motor. Apparently they just sell it 1 piece with the motor and regulator. Got one on Amazon in 2 days for 45.00. Worked perfectly. Link to comment Share on other sites More sharing options...
