Enkei pfr1 18x8 35 offset
Will this work on an outback? I searched and had a hard time finding my answers. Anyone running this set up?
Sent from my SM-N920V using Tapatalk
In general yes, it should fit, with cutting. However, you are going to have to do fender work to get it to fit.
Read through Rebourne's thread to get an idea of what it will take. Although, he is only at 18x8+35 in the rear.
http://legacygt.com/forums/showthread.php/rebournes-06-obxt-build-thread-243318.html
I had a chance to buy some with 3 set of used tires for 625 but I don't want to hack up the fenders to get them to fit right.
If you do, it will look awesome. But, you will have to hack the / roll / cut the fenders and might have increased wheel bearing wear.
  • 1 month later...
I know it's a stale post but depending on how low you are....well, here is THE MATH based on the stock OB 17x7x48 wheel running a 225/55-17.
I'm on LGT struts/shocks and there is only about 6mm of clearance between the tire and the spring perch on the front. Going to 18's will be...interesting.
