tigger73 Posted July 24, 2016 Share Posted July 24, 2016 (edited) It seems that a lot of threads in the 6th gen forum area relate to lights/lighting. So to try and reduce the number of duplicate threads here's a "master" index with links to all the current lighting threads. Please search/read through the existing threads before starting a new thread as likely the topic has been discussed/covered before. Also please don't ask questions in this thread. It's intended as an index only. Ask your questions in the relevant thread linked below. OEM Light Bulb Specs 2015 Legacy Bulb Replacement: http://legacygt.com/forums/showthread.php/2015-legacy-bulb-replacement-229862.html Headlight Upgrades 2015 Legacy Bulb Replacement: http://legacygt.com/forums/showthread.php?t=229862 Few questions on replacing the halogen DRL with LED DRL: http://legacygt.com/forums/showthread.php?t=254495 LED Headlights: http://legacygt.com/forums/showthread.php?t=253870 HID install - XenonDepot Philips 4300k: http://legacygt.com/forums/showthread.php?t=247930 Iihs headlight ratings: http://legacygt.com/forums/showthread.php?t=251450 Xenon Depot 9005 LED High Beam/DRL Review: http://legacygt.com/forums/showthread.php?t=245832 OPT7 Led vs. PIAA Halogen vs. OEM: http://legacygt.com/forums/showthread.php?t=248714 Replacing Halogen High Beams with LED's: http://legacygt.com/forums/showthread.php?t=242631 low beam H11 HID from Xenon Depot: http://legacygt.com/forums/showthread.php?t=241941 The "next gen" in the led headlight trend:http://legacygt.com/forums/showthread.php?t=244743 Light Upgrade questions: http://legacygt.com/forums/showthread.php?t=246406 HID Upgrade on 2.5i Limited: http://legacygt.com/forums/showthread.php?t=233107 OLM HP Gen 2 Passive Cooling led low beams: http://legacygt.com/forums/showthread.php?t=242554 Are the LED high beams better than OEMs halogen?: http://legacygt.com/forums/showthread.php?t=243766 HID headlights vs. LED on my Limited - http://legacygt.com/forums/showthread.php/hid-headlights-vs-led-my-limited-254049.html?t=254049&highlight=LED Led 9005 high beams - http://legacygt.com/forums/showthread.php/led-9005-high-beams-250236.html?t=250236&highlight=LED RX350 AFS Bixenon Retrofit (page 11-13) - http://legacygt.com/forums/showthread.php/im2c0ols-15-cwp-legacy-ltd-ride-journal-lots-pictures-229871p11.html?highlight=im2c0ol+retrofit Lighting Observations and Questions (3.6R Limited with HID) - http://legacygt.com/forums/showthread.php/lighting-observations-and-questions-255831.html Rally/Spot/Specialist Lights Light Bar Installation *With Pictures* : http://legacygt.com/forums/showthread.php?t=253876 Legacy Rally Light Bar: http://legacygt.com/forums/showthread.php?t=250961 Hella 500FF Install: http://legacygt.com/forums/showthread.php?t=253182 Vol Fireman Responding lights: http://legacygt.com/forums/showthread.php?t=243241 Fog Lights Fog as DRL: http://legacygt.com/forums/showthread.php?t=248136 Steering Responsive Fog Lights .... : http://legacygt.com/forums/showthread.php?t=250344 Cheap fog light bulbs: http://legacygt.com/forums/showthread.php?t=250796 Fog light kit: weekend install project: http://legacygt.com/forums/showthread.php?t=230637 fog bulb replacement: http://legacygt.com/forums/showthread.php?t=249959 The Illustrious Chrome Fog Surround: http://legacygt.com/forums/showthread.php?t=249449 Fog light as DRL : http://legacygt.com/forums/showthread.php?t=231383 How to: Fog lights on with unlock/welcome lights: http://legacygt.com/forums/showthread.php?t=246290 Fog Light Kit Installation Guide!: http://legacygt.com/forums/showthread.php?t=243285 Steering Responsive Fog Lights: http://legacygt.com/forums/showthread.php?t=244935 Don't buy the fog light kit!: http://legacygt.com/forums/showthread.php?t=236759 2015 Legacy fog light installation : http://legacygt.com/forums/showthread.php?t=244354 OEM Fog Light installation: http://legacygt.com/forums/showthread.php/oem-fog-light-installation-254731.html Morimoto Fogs/Good or Bad? - http://legacygt.com/forums/showthread.php/morimoto-fogs-good-badi-253155.html?t=253155&highlight=LED Head light controls Auto headlight question?: http://legacygt.com/forums/showthread.php?t=254110 Night time turning help: http://legacygt.com/forums/showthread.php?t=247413 Changing the 'Auto' headlight setting to be HID?: http://legacygt.com/forums/showthread.php?t=243498 Did approach lighting replace puddle lights from last gen?: http://legacygt.com/forums/showthread.php?t=245166 Steering Responsive Fog Lights: http://legacygt.com/forums/showthread.php?t=244935 How to turn off approach lighting when opening/closing doors?: http://legacygt.com/forums/showthread.php?t=244858 Approach lighting, does it come from the mirrors?: http://legacygt.com/forums/showthread.php?t=244236 Auto Headlights Issue: http://legacygt.com/forums/showthread.php/auto-headlights-issue-254722.html Limited OEM HID and Auto Headlight mode: http://legacygt.com/forums/showthread.php/limited-oem-hid-and-auto-headlight-mode-256301.html Indicators / Turn Signals Diode Dynamics 2015+ Subaru Legacy Tail as Turn™ +Backup Module! See Install Video! - http://legacygt.com/forums/showthread.php/diode-dynamics-2015-subaru-legacy-tail-turn-backup-module-see-255759.html Side Mirror with Integrated Turn Signal: http://legacygt.com/forums/showthread.php?t=243565 Led help: http://legacygt.com/forums/showthread.php?t=253804 LED's for Turn Signals: http://legacygt.com/forums/showthread.php?t=244408 BRZ tail as turn kit on Legacy? Maybe...stay tuned...: http://legacygt.com/forums/showthread.php?t=244185 Anybody using led bulbs in the rear turn signals? - http://legacygt.com/forums/showthread.php/anybody-using-led-bulbs-rear-turn-signalsi-253641.html?t=253641&highlight=LED Interior LEDs Prolightz V2.0 Interior LED Kit Review: http://legacygt.com/forums/showthread.php?t=251204 LED's interior and exterior. List?: http://legacygt.com/forums/showthread.php?t=233350 Dim map and dome LEDs: http://legacygt.com/forums/showthread.php?t=250748 15' Legacy/Outback Footwell Illumination Kit.: http://legacygt.com/forums/showthread.php?t=237567 Footwell illumination for under $10 : http://legacygt.com/forums/showthread.php?t=243789 2016 OEM Footwell Interior Illumination Kit: http://legacygt.com/forums/showthread.php?t=243883 Cup holder lights, best place to tap in?: http://legacygt.com/forums/showthread.php?t=244846 DD vs. XD - http://legacygt.com/forums/showthread.php/dd-vs-xd-255307.html Zevo DRL LED strips - http://legacygt.com/forums/showthread.php/zevo-drl-led-strips-255255.html?t=255255&highlight=LED Info on installing LED bulbs in your Subaru - http://legacygt.com/forums/showthread.php/info-installing-led-bulbs-your-subaru-248756.html?t=248756&highlight=LED Daytime Running Lights (DRL) Cost to install LED DRLs at dealer or elsewhere?: http://legacygt.com/forums/showthread.php?t=252625 Morimoto and subiespeed C light LED bulb for premium/base: http://legacygt.com/forums/showthread.php?t=244347 DIY: 15'+ DRL Disable: http://legacygt.com/forums/showthread.php?t=229147 DRL on side mirror indicator: http://legacygt.com/forums/showthread.php?t=251331 15'+ C-LED as DRL solved: http://legacygt.com/forums/showthread.php?t=239825 DRL dimming: http://legacygt.com/forums/showthread.php?t=249036 Successful mod Boomerang's (CLEDS) as DRLs: http://legacygt.com/forums/showthread.php?t=248324 Fog light as DRL : http://legacygt.com/forums/showthread.php?t=231383 Need CLed for testing: http://legacygt.com/forums/showthread.php?t=247147 boomerang light on Legacy: http://legacygt.com/forums/showthread.php?t=246361 V3 Triton Switchbacks as DRL : http://legacygt.com/forums/showthread.php?t=245657 How to always keep on the Upper led lights that are like a strip: http://legacygt.com/forums/showthread.php?t=240113 Few questions on replacing the halogen DRL with LED DRL - http://legacygt.com/forums/showthread.php/few-questions-replacing-halogen-drl-led-drl-254495.html?t=254495&highlight=LED Feedback on LED DRLs purchased - http://legacygt.com/forums/showthread.php/feedback-led-drls-purchased-254906.html?t=254906&highlight=LED Cost to install LED DRLs at dealer or elsewhere? - http://legacygt.com/forums/showthread.php/cost-install-led-drls-dealer-elsewherei-252625.html?t=252625&highlight=LED Zevo DRL LED strips - http://legacygt.com/forums/showthread.php/zevo-drl-led-strips-255255.html 7440 to 7443 switchback LED vs. V3 Triton Switchbacks as DRL - http://legacygt.com/forums/showthread.php/7440-7443-switchback-led-vs-v3-triton-switchbacks-drl-255402.html Tinted head/tail lights Wrapping headlights and tail lights...soon: http://legacygt.com/forums/showthread.php?t=253611 License Plate LEDs License Plate LED bulb replacement: http://legacygt.com/forums/showthread.php?t=251218 Third Brake Light Third Brake light wire: http://legacygt.com/forums/showthread.php?t=243984 The We Have too Many Light Threads Thread Lighting Threads: http://legacygt.com/forums/showthread.php?t=245844 Edited September 23, 2016 by tigger73 Tigger73's MY15 2.5i build Link to comment Share on other sites More sharing options...
andrew_l_s Posted July 24, 2016 Share Posted July 24, 2016 This should be a sticky thread so people are forced to see it lol Lighting Mods: $10 Footwell Illumination | Tail as Turn | Fog as DRL Diode Dynamics C-Lights | RX350 Bi-Xenon Retrofit Link to comment Share on other sites More sharing options...
DanG_Legacy Posted July 24, 2016 Share Posted July 24, 2016 sticky!!! Link to comment Share on other sites More sharing options...
subaru2015 Posted July 24, 2016 Share Posted July 24, 2016 +1 sticky! Link to comment Share on other sites More sharing options...
SBT Posted July 24, 2016 Share Posted July 24, 2016 Ti-double-ger-er Thank you. Much appreciated. Stickied for posterity - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
CT2015Legacy Posted July 26, 2016 Share Posted July 26, 2016 Nice! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
denokarter Posted August 6, 2016 Share Posted August 6, 2016 To everyone who has the 2.5l and doesn't want HID or LED conversion kits and simply wants a plug and play LED halogen bulb that performs just as good as the HID and LED , buy the H11 LED 6K PIAA halogen bulbs, even tho they are quite pricy for 299$ , it's the closest match to your LED's and its legal, and best of all plug and play . http://www.piaa.com/LEDbulb Link to comment Share on other sites More sharing options...
Bigkanz Posted August 6, 2016 Share Posted August 6, 2016 Figured I'd throw a picture of my Subispeed OLM HP Gen2 6000k Low Beam LED's in case anyone was wondering what they looked like or just for reference. They're Plug n Play and are super easy to install. Also have a great cut off as well. Link to comment Share on other sites More sharing options...
denokarter Posted August 6, 2016 Share Posted August 6, 2016 (edited) Figured I'd throw a picture of my Subispeed OLM HP Gen2 6000k Low Beam LED's in case anyone was wondering what they looked like or just for reference. They're Plug n Play and are super easy to install. Also have a great cut off as well. Very nice, where did you purchase those ? Are they just on your lowbeam ( during night) or do you have another pair of them installed as your DRL as well ? Edited August 6, 2016 by denokarter Link to comment Share on other sites More sharing options...
Bigkanz Posted August 8, 2016 Share Posted August 8, 2016 Very nice, where did you purchase those ? Are they just on your lowbeam ( during night) or do you have another pair of them installed as your DRL as well ? Just low beams, and actually bought them from a member here Robstunner who bought his legacy from me lol. But he bought them on Subispeed.com Link to comment Share on other sites More sharing options...
Diode Dynamics Posted August 11, 2016 Share Posted August 11, 2016 We have a new Legacy in the studio this week! Very excited to post some of the new products we've developed for the Legacy. We will also have installation videos for each location as well Nick C. John C. Diode Dynamics Link to comment Share on other sites More sharing options...
DanG_Legacy Posted August 11, 2016 Share Posted August 11, 2016 We have a new Legacy in the studio this week! Very excited to post some of the new products we've developed for the Legacy. We will also have installation videos for each location as well Nick C. Ive been waiting for this all my life... Link to comment Share on other sites More sharing options...
Diode Dynamics Posted August 11, 2016 Share Posted August 11, 2016 Ive been waiting for this all my life... The tail-as-turn™ looks amazing on the 6th Gen! Can't wait to post that video Nick C. John C. Diode Dynamics Link to comment Share on other sites More sharing options...
aotus Posted August 14, 2016 Share Posted August 14, 2016 (edited) sure hope DD is making this c-light for us... http://www.diodedynamics.com/store/catalog/product/view/id/23059/s/2015-2016-subaru-wrx-sti-c-light-switchback-led-boards/category/634/ Edited August 15, 2016 by aotus Link to comment Share on other sites More sharing options...
DanG_Legacy Posted August 15, 2016 Share Posted August 15, 2016 The tail-as-turn™ looks amazing on the 6th Gen! Can't wait to post that video Nick C. im waiting for it!! Link to comment Share on other sites More sharing options...
Diode Dynamics Posted August 15, 2016 Share Posted August 15, 2016 sure hope DD is making this c-light for us... http://www.diodedynamics.com/store/catalog/product/view/id/23059/s/2015-2016-subaru-wrx-sti-c-light-switchback-led-boards/category/634/ http://cf.chucklesnetwork.com/items/1/1/7/1/3/1/original/hey-relax-buddy-im-working-on-it.jpg Just a few more weeks! Made in USA as well Thanks, Nick C. John C. Diode Dynamics Link to comment Share on other sites More sharing options...
RobbieGT Posted August 15, 2016 Share Posted August 15, 2016 (edited) http://cf.chucklesnetwork.com/items/1/1/7/1/3/1/original/hey-relax-buddy-im-working-on-it.jpg just a few more weeks! Made in usa as well thanks, nick c. take my money take my money! But in all serious please let me know as soon as you guys develop them, i'll be ordering them right away. I've got a guy doing the demon eye install in my lights so i'm gonna hold off for now until these are ready. Edited August 15, 2016 by RobbieGT Link to comment Share on other sites More sharing options...
CT2015Legacy Posted August 16, 2016 Share Posted August 16, 2016 http://cf.chucklesnetwork.com/items/1/1/7/1/3/1/original/hey-relax-buddy-im-working-on-it.jpg Just a few more weeks! Made in USA as well Thanks, Nick C. Please do take my money as well!!! I cannot wait to get these C lights brighter! Best news I've heard all day! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Diode Dynamics Posted August 19, 2016 Share Posted August 19, 2016 Here's two helpful installation videos for the Legacy that we just put together: [ame=http://www.youtube.com/watch?v=oTouXHyPtyM]How to Install 2003-2016 Subaru Legacy Backup & License Plate LEDs - YouTube[/ame] How to Install 2003-2016 Subaru Legacy Backup & License Plate LEDs [ame=http://www.youtube.com/watch?v=4eIC-SmBNlM]2016 Subaru Legacy DRL & Front Turn Signal LEDs - YouTube[/ame] 2016 Subaru Legacy DRL & Front Turn Signal LEDs We will have more products and installation videos available soon! Thank you, Nick C. John C. Diode Dynamics Link to comment Share on other sites More sharing options...
3.0R-AUS Posted August 20, 2016 Share Posted August 20, 2016 Dumb question: if 6 ohm resistors are required per bulb to fix hyper-flashing, would putting two sets of 6 ohm resistors in line with the rear bulbs and none with the fronts achieve the same end result? Link to comment Share on other sites More sharing options...
im2c0ol Posted August 20, 2016 Share Posted August 20, 2016 2015-2016 RX350 AFS Bixenon Retrofit page 11-13 http://legacygt.com/forums/showthread.php/im2c0ols-15-cwp-legacy-ltd-ride-journal-lots-pictures-229871p11.html?highlight=im2c0ol+retrofit 16' Legacy Mods: 55w HID + XB35 5500k, LEDS upgrades, XB Type T Fog, 20mm SB. Custom Footwell Illiminate Kit; http://legacygt.com/forums/showthread.php/15-legacy-outback-footwell-illumination-kit-237567.html Link to comment Share on other sites More sharing options...
Diode Dynamics Posted August 22, 2016 Share Posted August 22, 2016 Dumb question: if 6 ohm resistors are required per bulb to fix hyper-flashing, would putting two sets of 6 ohm resistors in line with the rear bulbs and none with the fronts achieve the same end result? You could, but we recommend adding a resistor for each location to spread out the heat. Thanks! Nick C. John C. Diode Dynamics Link to comment Share on other sites More sharing options...
Diode Dynamics Posted August 22, 2016 Share Posted August 22, 2016 [ame=http://www.youtube.com/watch?v=mTd5QOTyURU]How to Install 2014+ Subaru Legacy Rear Turn Signal LEDs - YouTube[/ame] How to Install 2014+ Subaru Legacy Rear Turn Signal LEDs Nick C. John C. Diode Dynamics Link to comment Share on other sites More sharing options...
Bigkanz Posted August 24, 2016 Share Posted August 24, 2016 http://www.diodedynamics.com/store/catalog/product/view/id/22234/s/2014-2016-subaru-legacy-fog-light-leds-pair/ Anyone use these yet? Didn't think we could use these without the whole new housing and what not. Link to comment Share on other sites More sharing options...
bobbydd21 Posted August 24, 2016 Share Posted August 24, 2016 http://www.diodedynamics.com/store/catalog/product/view/id/22234/s/2014-2016-subaru-legacy-fog-light-leds-pair/ Anyone use these yet? Didn't think we could use these without the whole new housing and what not. I purchased H11 LED bulbs for my foglights on Amazon and they were plug and play. No need for a new housing. Link to comment Share on other sites More sharing options...
