alex21 Posted July 2, 2014 Share Posted July 2, 2014 My '07 spec.B is more or less stock. The only things I've modified down below are the struts. It was in the shop for another repair when I asked if they could put a hitch on while it was in there. I was told that this model Legacy can't have a hitch installed. Just wondering if this is true... Link to comment Share on other sites More sharing options...
Strizzy Posted July 2, 2014 Share Posted July 2, 2014 http://legacygt.com/forums/showthread.php/different-trailer-hitch-option-204538.html My bad luck build Link to comment Share on other sites More sharing options...
Bdubs Posted July 3, 2014 Share Posted July 3, 2014 The OEM Outback hitch will bolt right up to the sedans. Just doesn't have the harness for trailer lights like the OB does. You can always make one though. Link to comment Share on other sites More sharing options...
wengermi Posted July 4, 2014 Share Posted July 4, 2014 I have the oem hitch installed on my 07 spec.b. Its been there for years with no issues. I spliced the harness into the tail lights. I did my research on it and everyone was saying that the oem one was best. Everyone I talked to said the other hitches tear up the frame after years of use. There are thread inserts in the sub frame for the oem hitch that should have plugs in them that pull straight out. For the wires, you have to pull the plug where the spare tire goes so you don't have to drill holes. The oem trailer harness has a grommet around the wires to reseal the hole. Link to comment Share on other sites More sharing options...
wengermi Posted July 4, 2014 Share Posted July 4, 2014 Also my car is lowered and when the back bottoms out it hits the hitch first and saves my exhaust Link to comment Share on other sites More sharing options...
alex21 Posted July 29, 2014 Author Share Posted July 29, 2014 Thanks for the help guys. Much appreciated Link to comment Share on other sites More sharing options...
