Countchocula Posted December 20, 2019 Share Posted December 20, 2019 (edited) Doesnt open EDIT: IT's Open thanks to (MOST) of your help. If this happens to you, have someone hold the hood release in the open position and open the hood even though it doesn't pop up. Next question...could someone direct me to a way to adjust the latch now that it's open? The cable actuates the latch but it does not pop up. Thanks! Edited December 23, 2019 by Countchocula Link to comment Share on other sites More sharing options...
Countchocula Posted December 20, 2019 Author Share Posted December 20, 2019 The cable is definitely moving and I can hear the latch moving under the hood when the lever is pulled. But not enough I guess. Its cold but not frozen. How else do you get under the hood if the latch won't open. Can anyone help?! Thanks!! Link to comment Share on other sites More sharing options...
Humble Rumble Posted December 20, 2019 Share Posted December 20, 2019 You could try removing some of the plastic pop clips that hold on the under cover of the bumper and reaching up behind the grill. Might be tight and dicey though. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
NVAKeith Posted December 20, 2019 Share Posted December 20, 2019 Try having one person push down on the front edge of the hood while you pull and hold the lever. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 20, 2019 Share Posted December 20, 2019 get some lithium grease and spray the locking mechanism and then using the hood lever work the cable and lock assembly.. should be able to open hood after a few pulls on the cable. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted December 20, 2019 Share Posted December 20, 2019 Lift up on the hood or give it a few thumps with your fist while someone pulls the lever. If its rusty, a little pb blaster will help loosen up the mechanism. Link to comment Share on other sites More sharing options...
Scubaboo Posted December 21, 2019 Share Posted December 21, 2019 Maybe charge the car battery through the cigarette lighter plug so you can get it started and drive it to a repair shop? Link to comment Share on other sites More sharing options...
Code Posted December 21, 2019 Share Posted December 21, 2019 Latch Lube. You must be new here. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Countchocula Posted December 23, 2019 Author Share Posted December 23, 2019 Try having one person push down on the front edge of the hood while you pull and hold the lever. This totally worked thanks. Pulling and HOLDING IT it released position while I lifted on the hood got it up. Appreciate it! Link to comment Share on other sites More sharing options...
Countchocula Posted December 23, 2019 Author Share Posted December 23, 2019 If this happens to you, have someone hold the hood release in the open position and open the hood even though it doesn't pop up. Next question...could someone direct me to a way to adjust the latch now that it's open? The cable actuates the latch but it does not pop up. Thanks! Link to comment Share on other sites More sharing options...
BoozeRS05 Posted December 23, 2019 Share Posted December 23, 2019 With the hood open take some motor oil and drip it onto the hood spring locking mechanism. Lower the hood onto the safety latch, but don't close the hood fully. Then actuate the hood on the spring mechanism back and forth a half dozen times. Close hood fully, go about your life. Lube your latch regularly! Just did my specB the other day. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
creep_nu Posted December 23, 2019 Share Posted December 23, 2019 With the hood open take some motor oil and drip it onto the hood spring locking mechanism. Lower the hood onto the safety latch, but don't close the hood fully. Then actuate the hood on the spring mechanism back and forth a half dozen times. Close hood fully, go about your life. Lube your latch regularly! Just did my specB the other day. i always just spray it down with some silicon spray when i'm lubing up the door weather seals every year. keeps it working pretty good in my books, but same general idea Link to comment Share on other sites More sharing options...
BoozeRS05 Posted December 23, 2019 Share Posted December 23, 2019 If you're jammed up in a parking lot or gas station, and have limited supplies it works great. Idk if I keep silicone/penetrating spray with me on the road all the time, probably do have it in my trunk though. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
