Notorious Posted February 20, 2019 Share Posted February 20, 2019 I’m getting an obnoxious clicking sound during low speed turns in either left or right directions but primarily turning right. -new CV Axles -relatively new Mevotech LCA with the new bushings -greased sway bar bushings -sway bar end links are as tight as I can get them (tightened while on jacks and while the suspension is slightly loaded with a jack under wheel.) I notice that the clicking primarily happens during right turns especially when I’m backing out of my driveway but it happens occasionally to the left as well. Could a worn top hat or strut cause this issue or clicks at low speed? Trying to shake the car and put weight on the strut does not replicate the clicking sound. I can’t replicate the sound turning the wheel and spinning it. I’ve been chasing this clunk for months now and it’s only gotten worse. I have a feeling it’s the top mount but I don’t have a wrench offset enough to tighten it with that Allen key in as well. Sound seems to be coming from top of the strut rather than the bottom. I am leaning toward the top hat not seating properly or the spring. Update, got a video Link to comment Share on other sites More sharing options...
Notorious Posted February 20, 2019 Author Share Posted February 20, 2019 bump Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 20, 2019 Share Posted February 20, 2019 What aftermarket changes to the suspension or strut assemblies? Spherical or solid endlinks? I think I've heard of aftermarket axles clicking. I've come to discover for a couple reasons - OEM rebuilt axles only. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Notorious Posted February 20, 2019 Author Share Posted February 20, 2019 What aftermarket changes to the suspension or strut assemblies? Spherical or solid endlinks? I think I've heard of aftermarket axles clicking. I've come to discover for a couple reasons - OEM rebuilt axles only. Lowering springs, KYB struts. Mevotech Axles. Cusco Front sway bar. Solid Kartboy endlinks. Do they need to be greased? I swapped in the OEM axles to see if it remedied the issue and nothing changed. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 20, 2019 Share Posted February 20, 2019 Won't a center diff going bad make that noise ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 20, 2019 Share Posted February 20, 2019 I lube my KB solid endlinks f&r probably twice a year just with white silicon spray. I could see spherical endlinks binding, but my KB solid endlinks have been quiet for years and I'm in a much different climate than you. Is it evident stationary turning the wheel? Does it translate into the steering wheel or drive-ability, or just audible? EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Notorious Posted February 20, 2019 Author Share Posted February 20, 2019 I lube my KB solid endlinks f&r probably twice a year just with white silicon spray. I could see spherical endlinks binding, but my KB solid endlinks have been quiet for years and I'm in a much different climate than you. Is it evident stationary turning the wheel? Does it translate into the steering wheel or drive-ability, or just audible? I don't think it was the sway bar end links either since I had them disconnected on that side after I lubed the bushings to isolate the endlinks being a problem. Too lazy to remove the whole sway bar for a more conclusive test but I'd say the end links are fine. I'll try to lube them up a bit. Occasionally evident while stationary when moving the steering wheel back and forth away slightly. But more so when doing the same movements once the car begins moving. It is just audible, I don't think I can feel the clicks through the steering wheel at all. Link to comment Share on other sites More sharing options...
Andy_Mac Posted February 20, 2019 Share Posted February 20, 2019 Interestingly I've heard from two people recently with the same clicking and both had different faults. One was shagged tophat bearings, replaced them and the noise went away. The other was wheel bearings, still tight but enough give under load to cause issues. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
Notorious Posted February 21, 2019 Author Share Posted February 21, 2019 Any tips on properly diagnosing which of those two it could be? I’d rather not do trial and error this time. Wheel bearing is tight and was replaced <25k miles ago Link to comment Share on other sites More sharing options...
rhino6303 Posted February 21, 2019 Share Posted February 21, 2019 I second a possible center diff issue. Link to comment Share on other sites More sharing options...
Notorious Posted February 21, 2019 Author Share Posted February 21, 2019 Update, was able to get a buddy help me out and turning the wheel while car is stationary. We were able to replicate the sound. It does not only occur when the wheel is turned right but rather shifting from left and back to right in random angles in the steering. Top hat bushings seem fine, minimal play during steering changes full lock to lock. About the same on each side. The noise is now confirmed to be around the wheel area. Perhaps the ball joint has worn prematurely in the Mevotech arms? I might just order Whiteline KCA313 to replace the ball joint and tie rod ends and maybe it will remedy it, I was planning on purchasing them anyways but not this soon. Could an improperly seated spring make this noise? The clicking isn’t constant and it sounds like it needs load from steering input and weight before the click happens when the load finally releases if this makes sense.. If it is the center diff, wouldn’t the noise be present whenever the wheels are spinning? I appreciate all the help so far but long story short, top hat bearings and endlinks are ruled out. Link to comment Share on other sites More sharing options...
lilredwagon Posted February 22, 2019 Share Posted February 22, 2019 Wheel bearing. Go slowly in a parking lot with the front wheels at lock. Just go around in a tight circle and have another person on the outside of the car walking along side. If you're by yourself, you can go to a parking lot that has a big concrete wall next to it. If you do the same small circle next to the wall with your windows down, the wall should reflect the sound and you'll be able to hear it. You can also do youtube searches for "front wheel bearing ticking" or something like that, and see if that matches the sound you're hearing. Link to comment Share on other sites More sharing options...
lilredwagon Posted February 22, 2019 Share Posted February 22, 2019 Ooh, also check the torque on your lug nuts on that corner. *Barely* loose lugs make a ticking/creaking sound. Link to comment Share on other sites More sharing options...
Notorious Posted February 22, 2019 Author Share Posted February 22, 2019 Wheel bearing. Go slowly in a parking lot with the front wheels at lock. Just go around in a tight circle and have another person on the outside of the car walking along side. If you're by yourself' date=' you can go to a parking lot that has a big concrete wall next to it. If you do the same small circle next to the wall with your windows down, the wall should reflect the sound and you'll be able to hear it. You can also do youtube searches for "front wheel bearing ticking" or something like that, and see if that matches the sound you're hearing.[/quote'] I did a search online and it doesnt seem to match the noise I am hearing. Both left side wheel bearings have been replaced with OEM units within 15k miles. Lug nuts are definitely tight and torqued down, same with the axle nut. Link to comment Share on other sites More sharing options...
Notorious Posted February 23, 2019 Author Share Posted February 23, 2019 Update, got a video recorded under the car Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 23, 2019 Share Posted February 23, 2019 Seems like you've narrowed the list down to only a couple items left.. Ball joints or top hats, maybe tie rods. Might as well keep going until it's all new My new Legacy has a clicking/clunking sound on acceleration now that I'm apart of your thread.. Sounds like a top hat to me, but thanks a lot. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Notorious Posted February 24, 2019 Author Share Posted February 24, 2019 Seems like you've narrowed the list down to only a couple items left.. Ball joints or top hats, maybe tie rods. Might as well keep going until it's all new My new Legacy has a clicking/clunking sound on acceleration now that I'm apart of your thread.. Sounds like a top hat to me, but thanks a lot. I think I’m gonna order Whiteline’s bumpsteer kit KCA313 which includes a ball joint and tie rod ends. I just really hope I can rule out the strut or top hat since that just adds to the list of parts I need to replace before track days. Link to comment Share on other sites More sharing options...
