Libertarian Posted June 3, 2020 Share Posted June 3, 2020 But now I have major air leakage overnight. Say 40-50psi in each bag and the tank completely empty. FUN! Took a while but its been figured out - its the actual actuator itself that is leaking. Its not closing properly. Mechanic is ordering me a spare while they get mine serviced. If they cannot do it they need to give me the newer model, which would be good - but it has smaller fittings, so theyll also have to suffer the cost of getting me some adapters. Ha! Drama of bagged cars ey. Link to comment Share on other sites More sharing options...
Grnlantern1 Posted June 3, 2020 Share Posted June 3, 2020 Took a while but its been figured out - its the actual actuator itself that is leaking. Its not closing properly. Mechanic is ordering me a spare while they get mine serviced. If they cannot do it they need to give me the newer model, which would be good - but it has smaller fittings, so theyll also have to suffer the cost of getting me some adapters. Ha! Drama of bagged cars ey.Do you mean the Air Manifold that regulates the pressure for all corners..? Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Grnlantern1 Posted June 6, 2020 Share Posted June 6, 2020 Well added some more Interior details with some Garson Seat Belt Covers and Seat Cushion.. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
PATS4LIFE Posted June 13, 2020 Share Posted June 13, 2020 (edited) Finally got to install back the stock springs.. If anyone interested my H&R spring will be for sale!! Ok after getting an alignment,the shop got the alignment on the spot,but when they test drive it car was pulling to the right,and tech said most likely that the caster was off and it’s not adjustable on our car,so my question is is there a way to adjust caster? Edited June 24, 2020 by PATS4LIFE Link to comment Share on other sites More sharing options...
Grnlantern1 Posted July 4, 2020 Share Posted July 4, 2020 Installed some Diamond Floor Mats for the Daily Driving.. They fit pretty good. I bought the mat insert to sit on top for a little more grip. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Libertarian Posted July 9, 2020 Share Posted July 9, 2020 Do you mean the Air Manifold that regulates the pressure for all corners..? Sorry, yes. It was changed yesterday (big delay) and the tank is still leaking. What the ****? My mechanic cannot see any leaks anywhere - so its a mystery it seems. I may have to live with it. Link to comment Share on other sites More sharing options...
gathermewool Posted July 9, 2020 Share Posted July 9, 2020 There are only so many places to spray soapy water, right? '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
Grnlantern1 Posted July 9, 2020 Share Posted July 9, 2020 Sorry, yes. It was changed yesterday (big delay) and the tank is still leaking. What the ****? My mechanic cannot see any leaks anywhere - so its a mystery it seems. I may have to live with it.Where are you losing pressure? Struts or Tank? If your losing Tank Pressure Check all your connections and Plugs from the Tank to the Manifold Control Unit. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
T2018 Posted July 9, 2020 Share Posted July 9, 2020 Just installed BC racing coilovers today Link to comment Share on other sites More sharing options...
DougKelly20 Posted July 19, 2020 Share Posted July 19, 2020 Started blacking out my chrome with matte black vinyl. First time working with it... took 5 hours to do the first side, but it's turning out pretty well. 3M knifeless tape is clutch..... Link to comment Share on other sites More sharing options...
gathermewool Posted July 20, 2020 Share Posted July 20, 2020 I hope that looks better in person! What'd you take that picture with, an iPhone 4S? '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
DougKelly20 Posted July 20, 2020 Share Posted July 20, 2020 (edited) Haha maybe my phone was grimey from all the sweat. Doing this 95 degree heats sucks! Ahh just checked, it's because of the size restriction on uploads through tapatalk...not using VIP. Edited July 20, 2020 by DougKelly20 Link to comment Share on other sites More sharing options...
gathermewool Posted July 21, 2020 Share Posted July 21, 2020 95, sheesh! we're only just above 90 here, but with no wind today it was sweltering! Good on you for pushing through the heat! '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
charles_catbagan Posted July 21, 2020 Share Posted July 21, 2020 they are 18x9.5 35offset,. did it my self spray cans Link to comment Share on other sites More sharing options...
Libertarian Posted July 21, 2020 Share Posted July 21, 2020 Had the air manifold thing (for my air suspension) changed as my old one was filled with rust and was causing leaks. Turns out the new one also leaks Then my cut out exhaust valve decided to die - the motor would power up but wouldnt close the valve. I just got a new valve and got it put in! Easy! Video of valve! Last but not least - my car sittin' pretty: Link to comment Share on other sites More sharing options...
raider600 Posted July 21, 2020 Share Posted July 21, 2020 I'm doing brakes this weekend. I grabbed some Centric rotors and hawk hps for front. Link to comment Share on other sites More sharing options...
mcbowflex Posted July 21, 2020 Share Posted July 21, 2020 New member here. Picked up a black 15 Premium about a week and a half ago. Just installed the Tail as Turn from diode dynamics yesterday. The extra light from 2 additional reverse lights is pretty nice. Link to comment Share on other sites More sharing options...
Grnlantern1 Posted July 22, 2020 Share Posted July 22, 2020 New member here. Picked up a black 15 Premium about a week and a half ago. Just installed the Tail as Turn from diode dynamics yesterday. The extra light from 2 additional reverse lights is pretty nice.Welcome.. Plenty of good stuff here.. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Grnlantern1 Posted July 26, 2020 Share Posted July 26, 2020 Well had a little fun today removing my old front table brackets and getting ready to mount my New one from Garson Japan. They custom made me one as per my dimension and sent me the SJ Forester mounting hardware so today I was looking for a new way to mount it.. Stay tune for the installed pictures. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
raider600 Posted July 26, 2020 Share Posted July 26, 2020 I think the old rotors on my 3.6 were actually 2.5 rotors. Bought the car CPO with 28k miles. Not sure who would have put those on...Yes, I beat the hell out of the old rotors to get them off. No chisel. hah Link to comment Share on other sites More sharing options...
Grnlantern1 Posted July 26, 2020 Share Posted July 26, 2020 I think the old rotors on my 3.6 were actually 2.5 rotors. Bought the car CPO with 28k miles. Not sure who would have put those on...Yes, I beat the hell out of the old rotors to get them off. No chisel. hahDamn that sucks.. Good Luck with the New ones..[emoji41] Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
tmoney468 Posted July 27, 2020 Share Posted July 27, 2020 I think the old rotors on my 3.6 were actually 2.5 rotors. Bought the car CPO with 28k miles. Not sure who would have put those on...Yes, I beat the hell out of the old rotors to get them off. No chisel. hah You can also thread an M8 bolt I believe in those 2 holes to remove the rotor. Whatever works though! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
raider600 Posted July 27, 2020 Share Posted July 27, 2020 You can also thread an M8 bolt I believe in those 2 holes to remove the rotor. Whatever works though! Sent from my iPhone using Tapatalk Yeah, but I couldn't find one in my bucket of bolts. The new brakes though are amazing! Link to comment Share on other sites More sharing options...
tornichoe Posted July 28, 2020 Share Posted July 28, 2020 I think the old rotors on my 3.6 were actually 2.5 rotors. Bought the car CPO with 28k miles. Not sure who would have put those on...Yes, I beat the hell out of the old rotors to get them off. No chisel. hah I think the front rotors on the 2.5 Limited and 3.6 are the same size. I had the issue when I ordered a kit from rock auto and they sent me the pads for a 2.5 standard/premium. Good thing on the pads is that the wrong ones won't fit (notches on the caliper body are different) I could totally see it getting mixed up when ordering aftermarket ones, In your case, someone just wasn't paying attention during installation.... Link to comment Share on other sites More sharing options...
ammcinnis Posted July 28, 2020 Author Share Posted July 28, 2020 (edited) ... someone just wasn't paying attention during installation.... ... or someone just didn't care. Perhaps a bigger question is why the front pads and rotors were replaced at less than 28,000 miles. Looking at the pad wear, I'd say way before 28,000 miles. For me, that would be a big red flag ... CPO or not. Edited July 28, 2020 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
