4shizl Posted April 24, 2014 Share Posted April 24, 2014 Shifter has been working great until today. I went through a laser wash and had the underside of my vehicle sprayed. Half way through the wash my check engine light came on so I headed straight home. I reversed into my garage then had to leave shortly after. As I was accelerating down the street I went to shift into second only to be rejected. No grinding or any noise, just not wanting to seat in position. All other gears work fine. I went back home check my MTF and it was normal color, smell, and at full line. Completely lost!! Link to comment Share on other sites More sharing options...
Kennyfvholla Posted April 25, 2014 Share Posted April 25, 2014 Well, something is obviously causing a jam and not allowing the shifter/linkage pulling the shift rod to pull the fork/shift sleeve into/over the syncro and onto the input shaft gear. You're probably going to have to pull the trans if it doesn't work itself out over time. It could be a couple of things. Don't try and force it in too much as you'll cause more damage. Link to comment Share on other sites More sharing options...
