MC_Legacy Posted September 7, 2018 Share Posted September 7, 2018 I believe I will be rotating my tires for now. Im not sure if they are good to even use in the rear, I just want to slow down the wear and tear on the rubber. Check it out. Let me know what you think Link to comment Share on other sites More sharing options...
stewdogg Posted September 7, 2018 Share Posted September 7, 2018 I run summer, spring and fall to the wear marks and then replace the tires. More wear in the center of the tire means too much air pressure. More wear on the inner and outer treads means too little air pressure. Rotate every other oil change. Link to comment Share on other sites More sharing options...
Notorious Posted September 8, 2018 Share Posted September 8, 2018 A good alignment goes a long way too for making sure your tires wear evenly. Link to comment Share on other sites More sharing options...
dgoodhue Posted September 8, 2018 Share Posted September 8, 2018 It appears the lower set of tires are at 3/32 and the other is 7/32nds tread depth. It does not appear that you or perhaps the previous owner are rotating the tires. You need new tires because the tread depth between tires is too great and and you are wear out your awd clutches. You tires are ~3 time higher than Subaru’s specification for the difference in f & r tires. Link to comment Share on other sites More sharing options...
