Guest LGT-NY Posted July 11, 2009 Share Posted July 11, 2009 I searched around quite a bit but couldn't find any info. Does any know a good place that I can find a diagram of the grease fitting locations for my LGT? I'm going to start changing my own oil and want to make sure everything is sufficiently greased but I'm not exactly sure where all the fittings are. Any help would be much appreciated. Thanks, Ben Link to comment Share on other sites More sharing options...
badwolf Posted July 11, 2009 Share Posted July 11, 2009 There are no grease fittings. Link to comment Share on other sites More sharing options...
BigBad Posted July 11, 2009 Share Posted July 11, 2009 Yes they are all sealed units (no Zerk fittings) as are most cars these days. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted July 11, 2009 Share Posted July 11, 2009 Oh shit, well I feel stupid. So there is no maintenance required? Link to comment Share on other sites More sharing options...
rao Posted July 11, 2009 Share Posted July 11, 2009 None for the bushings. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted July 11, 2009 Share Posted July 11, 2009 Cool, thanks for the info guys. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 16, 2009 Share Posted July 16, 2009 That's been the norm for decades. All those people that paid for a oil change and lube all those years got, took. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bluesuby Posted July 17, 2009 Share Posted July 17, 2009 That's been the norm for decades. All those people that paid for a oil change and lube all those years got, took. "Lube" probably was greasing the door hinges. Of course you won't know unless you ask. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 21, 2009 Share Posted July 21, 2009 "Lube" probably was greasing the door hinges. Of course you won't know unless you ask. I think it was more like greasing your wallet so the money comes out easier... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
