Rainis Posted September 16, 2017 Share Posted September 16, 2017 Hey guys. I haven't posted here much but I have learned a lot from this forum. So thanks for the wealth of information that you have shared over the years! I am having trouble removing the PVC valve in my 2.5 engine. The valve is threaded into an aluminium piece that goes into the engine block. It seems like the PCV valve is really tight in there, and the aluminium piece is spinning. The piece in question is the one with the red arrow pointing a it. I tried to get locking pliers and channel locks in there, but no success. The aluminium piece that is spinning has two flat sides. It seems like they are there to grasp that piece. I was thinking about using a 19 mm wrench to kept it in place (crescent wrench didn't work) and maybe use an impact wrench to take out the PCV. Any ideas? Because this is driving me nuts. Thanks in advance! Link to comment Share on other sites More sharing options...
RustyRuu Posted September 16, 2017 Share Posted September 16, 2017 it is a bitch, I can't remember everything i did. but pulling with vise grips away from the hole is what worked the best for me and some cussing. I just pulled the entire piece that was pressed into the block out. it was the only way to get the pcv off and i still had to use lots of heat to get it out. then "press" (violently smash with a mallet)the piece back in and install a new pcv. is your intake still on it may help to remove it, i would try and impact and heat if you have it the piece that is pressed into the block is not a part, as in no part number, as in you can not buy one, be carefull... Link to comment Share on other sites More sharing options...
RumbleRumble Posted September 18, 2017 Share Posted September 18, 2017 make sure the check valve is metal like the oem one and not plastic. Link to comment Share on other sites More sharing options...
Rainis Posted October 17, 2017 Author Share Posted October 17, 2017 Hey, thanks for the answers. Took it to the Subaru tech and... the thing is really tight in there. They gave up and told me to keep going... They didn't charge me anything. I haven't tried to pull out the whole assembly from the engine block. And I think I will not try... Here is the interesting thing: the tech told me to put some wd-40 (or any other oil-based solvent) in the valve before an oil change. That should do it... The car has 170k miles, and the valve should be changed by now. There are no problems, the engine runs fine, but... This was preventative medicine because I don't want any problems down the road. I checked the nipple that is connected to the PCV valve and there is some sludge in there. The PCV valve should have more. Any other ideas? Thanks in advance! Link to comment Share on other sites More sharing options...
Sara32013 Posted October 21, 2017 Share Posted October 21, 2017 Wow thats crazy. I just changed mine and it came right out with a wrench. Whole thing took like 3 minuets. Good luck! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted October 21, 2017 Share Posted October 21, 2017 Heat will be your best friend. Get that aluminum hot, grab the flats with your 19mm or whatever it takes to hold it and see if that works. Link to comment Share on other sites More sharing options...
