bewoin Posted October 1, 2014 Share Posted October 1, 2014 Well, as I discovered a hole in the top of my coolant filler tank near the yellow plastic cap, it's hidden behind the radiator, I saw that after the coolant overflow cause the previous owner overfilled it. I don't think it's normal, what do you think? The hole is located in the circle mark. Link to comment Share on other sites More sharing options...
chaz517 Posted October 1, 2014 Share Posted October 1, 2014 Anything leak from it when fully warm? Link to comment Share on other sites More sharing options...
bewoin Posted October 1, 2014 Author Share Posted October 1, 2014 Sometimes, when I drive a little bit too fast. Link to comment Share on other sites More sharing options...
chaz517 Posted October 1, 2014 Share Posted October 1, 2014 LOL, which is probably often. You obviously never want coolant leaking. It probably isnt the biggest deal in the world, but I wouldn't feel comfortable driving like that for too long. Is there white residue anywhere or everywhere under the hood? Link to comment Share on other sites More sharing options...
MrTris Posted October 1, 2014 Share Posted October 1, 2014 It's supposed to be there. If the coolant is overflowing from it, every time you drive, I'd check to make sure that you've also got coolant in the turbo tank. If not, you've got yourself a water jacket leak. AKA, blown HG. Otherwise, you've just got too much coolant. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 1, 2014 Share Posted October 1, 2014 Just checked the wagon, no hole that I can see. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bewoin Posted October 1, 2014 Author Share Posted October 1, 2014 I've check all the coolant levels, radiator, IC, everything seems right except the fact the coolant filler tank was almost filled to the top when I bought it, After few miles I rechecked it and that's when I saw the hole. No coolant seems to have spilled all over the place. It overflow only one time since, because the level was still a bit high when cold. I going to keep an eye on this, and closed that hole. I'm just wondering how it come to this? Link to comment Share on other sites More sharing options...
compsurge Posted October 2, 2014 Share Posted October 2, 2014 No idea. Maybe they drilled a hole. You should check the turbo reservoir and radiator to make sure they are full, as well as the radiator inlet tube near the power steering pump. Link to comment Share on other sites More sharing options...
Rhitter Posted October 2, 2014 Share Posted October 2, 2014 No idea. Maybe they drilled a hole. You should check the turbo reservoir and radiator to make sure they are full, as well as the radiator inlet tube near the power steering pump. How do you check the radiator inlet tube? Just squeeze it? My OBXT build Link to comment Share on other sites More sharing options...
Max Capacity Posted October 3, 2014 Share Posted October 3, 2014 I've check all the coolant levels, radiator, IC, everything seems right except the fact the coolant filler tank was almost filled to the top when I bought it, After few miles I rechecked it and that's when I saw the hole. No coolant seems to have spilled all over the place. It overflow only one time since, because the level was still a bit high when cold. I going to keep an eye on this, and closed that hole. I'm just wondering how it come to this? Have you sucked the coolant out of the tank to get it back down to the "full when cold" line ? You may want to carry some coolant with you until your sure there are no issues. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ibr_adam09 Posted October 4, 2014 Share Posted October 4, 2014 I think I had a hole in my tank but cant rememeber where. There should be one though so air can escape the if the radiator is going to push fluid into the tank. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 4, 2014 Share Posted October 4, 2014 I thought the yellow cap had the hole. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bewoin Posted October 6, 2014 Author Share Posted October 6, 2014 Have you sucked the coolant out of the tank to get it back down to the "full when cold" line ? You may want to carry some coolant with you until your sure there are no issues. No I haven't yet, cause I want to know if there's a leak somewhere else as well. Link to comment Share on other sites More sharing options...
