Risen Saint Posted February 6, 2019 Share Posted February 6, 2019 05 LGT 5spd Grimmspeed up pipe Invidia catted dp and q300 CB AEM afr gage COBB 3 port ebcs Grimmspeed intake Moshimoto turbo inlet APv3 Recently replaced some injector o-rings due to a fuel leak i was smelling coming from the passanger side between the turbo and tmic. Decided to do them all for safe measure. Also decided to replace the tgv gaskets and the throttle body gasket while the intake manifold was off. After everything was put back together the fuel leak ceased but i ran into an overboosting problem.. i have been tuned by Eric from Torqued performance for about 2 years now with no noticeable issues. My turbo is tuned to push 17psi but after the fuel leak i was overboosting upwards of about 21 psi.. got in touch with Eric so he threw me a new map.. (a side note MAYBE worth mentioning was upon startup with the new map i was idling super rich at a solid 13.. turned it off then back on and the afr read normal again ~14.7.. what?? Anyways..) after the new map the boost was fine. My general question was what wouldve caused overboost after the fix.. initial thought was mayybbeee it wasnt running correctly when i bought the car? (My buddy told me normal vac at idle should be right around -8 but when i bought the car and installed the AP my vac was showing slightly different at -8.3 average.. SINCE the fuel leak happened about a month ago it dropped down to -8 and would bounce between -7.5 up to about -8.2 during idle.) Anybody?? Link to comment Share on other sites More sharing options...
Risen Saint Posted February 8, 2019 Author Share Posted February 8, 2019 Lol maybe im too detailed on this?? Link to comment Share on other sites More sharing options...
Risen Saint Posted February 8, 2019 Author Share Posted February 8, 2019 Was hoping infamous wouldve chimed in Link to comment Share on other sites More sharing options...
lilredwagon Posted February 9, 2019 Share Posted February 9, 2019 Maybe you had the boost leak when you were tuned, and now that you addressed the boost leak, it's overboosting. (?) Link to comment Share on other sites More sharing options...
Mr-C Posted February 9, 2019 Share Posted February 9, 2019 I was told the CAI will cause over boosting...had to port my wastegate in order to get tuned properly. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
lilredwagon Posted February 9, 2019 Share Posted February 9, 2019 True, but that wouldn't be the case if it was tuned for it. Look at the parts that were changed to cause the new condition. Has the ambient temp changed drastically? Otherwise, if you're still on the same parts, but fixed them; and it was running correctly before, then it must have been tuned for it before (or the ECU was compensating for it). Did you reset the ECU after fixed the leaks? That might have been all it needed. Link to comment Share on other sites More sharing options...
Risen Saint Posted February 10, 2019 Author Share Posted February 10, 2019 Update: might be a fuel injector/coil pack issue .. today i went to the grocery store and wanted to check for anymore issues. At about 11-12psi car started bucking. Changed my parameters to check cylinder roughness and cylinder three was giving me some ticks everytime the boost would hit that 11-12 psi causing car to buck. Can a coil pack/injector cause overboost? Tbh the stock fuel cut our cars have at redline.. sorta felt like that when the car bucks just power loss at that exact moment. Im gonna move a coil pack and injector around just to be sure. Stay tuned * No pun intended Link to comment Share on other sites More sharing options...
Risen Saint Posted February 10, 2019 Author Share Posted February 10, 2019 True' date=' but that wouldn't be the case if it was tuned for it. Look at the parts that were changed to cause the new condition. Has the ambient temp changed drastically? Otherwise, if you're still on the same parts, but fixed them; and it was running correctly before, then it must have been tuned for it before (or the ECU was compensating for it). Did you reset the ECU after fixed the leaks? That might have been all it needed.[/quote'] Yes i reset the ecu.. After i told Eric what was up, he sent me a new map same day and the overboost went away untill he sent me one more map.. the overboost came back which had me more puzzled Link to comment Share on other sites More sharing options...
Risen Saint Posted February 15, 2019 Author Share Posted February 15, 2019 K changed the coil pack on cylinder 3.. overboost seems to be gone but the misfire is definitely gone. Although its as if it started leaning out a tad. Im gonna keep an eye on the afr for a bit Link to comment Share on other sites More sharing options...
Risen Saint Posted February 16, 2019 Author Share Posted February 16, 2019 Still an overboost.. heres another question regarding the tuning if anyone is still following this.. Is it true that the only way to get the proper tuning done on the car is to log it with a wot pull? Like i dont plan on racing this anytime soon, im more for the reliability factor. Going theough this overboost issue ive been asked to wot pull log again but i have the feeling 20psi on whats supposed to be only 17psi will blow the turbo before i even hit 4500 rpms Link to comment Share on other sites More sharing options...
relative4 Posted February 16, 2019 Share Posted February 16, 2019 Just re-read this thread and don't see anything about diagnosis. Have the wastegate actuator, pivot, and hoses been checked thoroughly? Real easy to mess that up with all that IM work. Link to comment Share on other sites More sharing options...
chato Posted February 16, 2019 Share Posted February 16, 2019 might be worth asking for a map that backs off wgdc before you do that pull. also great point on checking mechanical possibilities for overboost and make sure your restrictor pill is still in place Link to comment Share on other sites More sharing options...
relative4 Posted February 16, 2019 Share Posted February 16, 2019 make sure your restrictor pill is still in place He has a 3-port boost controller. No restrictor pill. Link to comment Share on other sites More sharing options...
Risen Saint Posted February 16, 2019 Author Share Posted February 16, 2019 Yes we went over all the vac lines we put back.. i was in a rush to get the job done so havent ordered any new hose kits which i regret. I suppose ill mention the shaft play i felt in the front of the turbine, a little late ... my biddy sent me a link for a new turbine from turbo technics i think it is? https://www.ebay.com/itm/VF40-Billet-wheel-Turbo-CHRA-cartridge-for-Subaru-Legacy-GT-Outback-XT-VA430083/222287814385?epid=19010937597&hash=item33c162def1:g:OdcAAOSw2GlXGJ2P Ill do a little more diagnosing before i jump the gun, but for now i have that saved for the next fix until i upgrade the whole turbo Link to comment Share on other sites More sharing options...
