ZackC Posted April 9, 2020 Share Posted April 9, 2020 So I just received a new cord from Cobb for my v3 but my accessport still loses connection with the car. It stays on, but will pull the screen after you shut your car off saying the accessport is trying to connect with the vehicle for just a split second and then will show all my gauges again. Any ideas on how to fix? (Trying to upload a video but won’t work. Will keep trying to get it on.) Link to comment Share on other sites More sharing options...
Pleides Posted April 9, 2020 Share Posted April 9, 2020 Ben from the Gears and Gasoline had similar issues with his flood-salvaged Legacy GT wagon a couple years ago. Hopefully you don't have any issues with the electrical system. Are your battery and alternator in good working order? Link to comment Share on other sites More sharing options...
ZackC Posted April 9, 2020 Author Share Posted April 9, 2020 Ben from the Gears and Gasoline had similar issues with his flood-salvaged Legacy GT wagon a couple years ago. Hopefully you don't have any issues with the electrical system. Are your battery and alternator in good working order? I haven’t had any issues at all with anything electrical. My turbo was upgraded and engine was rebuilt about 20k miles ago and my mechanic didn’t mention any other issues with the car. Link to comment Share on other sites More sharing options...
DaveWaters Posted April 9, 2020 Share Posted April 9, 2020 Maybe I’m not reading this right, when you shut the car off it says lost connection with car? Does it work fine otherwise with the car on? Link to comment Share on other sites More sharing options...
ZackC Posted April 9, 2020 Author Share Posted April 9, 2020 No it sends the message that it’s trying to connect with the car when the car is on. The same message it says when you turn off the car. Link to comment Share on other sites More sharing options...
DaveWaters Posted April 9, 2020 Share Posted April 9, 2020 Gotcha. I think I remember a thread on here that discussed repairing the obd2 connector (car side). Something having to do with loose terminals. Link to comment Share on other sites More sharing options...
ZackC Posted April 9, 2020 Author Share Posted April 9, 2020 So I uploaded the video I took to YouTube. Hope this clarifies more Link to comment Share on other sites More sharing options...
DaveWaters Posted April 9, 2020 Share Posted April 9, 2020 Have you contacted Cobb about the problem? Guessing you may have due to you just receiving a new cable. Not that it should make a difference but have you connected it to accessport manager to see if a firmware update is available? Link to comment Share on other sites More sharing options...
ZackC Posted April 11, 2020 Author Share Posted April 11, 2020 Have you contacted Cobb about the problem? Guessing you may have due to you just receiving a new cable. Not that it should make a difference but have you connected it to accessport manager to see if a firmware update is available? Yes I have contacted Cobb and I did the most recent update that came out last month. Guess I’ll have to call them and possibly send it in for them to look at. I also checked all my prongs and wires in my OBD port and they all look fine. I also took the car out with my code reader plugged in instead of my accessport. I can only look at one gauge at a time, had the boost gauge up and I drove around for 5 or so minutes and my code reader didn’t lose connection with the car at all. So it’s gotta be something with my unit itself. Link to comment Share on other sites More sharing options...
