Zac88 Posted May 3, 2019 Share Posted May 3, 2019 Time for my transmission fluid change. What does everyone recommend nowadays? Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted May 3, 2019 Share Posted May 3, 2019 I have a 20L drum of it in my garage My dealer told me Canada wasn't going to get it anymore and he sold me that one at his cost and he had one other. You can still get subaru trans fluid, I just don't think it's exactly the same. https://www.amazon.com/Subaru-75W90-Extra-Transmission-Fluid/dp/B0731SB4M3 Otherwise I'd use Motul 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Dishwasher Posted May 3, 2019 Share Posted May 3, 2019 GL-5 is the requirement. I've used Valvoline in the past and it was fine. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
rhino6303 Posted May 3, 2019 Share Posted May 3, 2019 Most will now say motul is best but I've never tried it. I plan on trying it when my delvac needs changed. Here is my list (favorite to least) 1. Extrs-S (no longer available) 2. Mobil Delvac 75W-90 3. Redline 75W-90NS Link to comment Share on other sites More sharing options...
covertrussian Posted May 3, 2019 Share Posted May 3, 2019 I've been running Walmart's Supertech GL5 fluid and it's doing just fine. All of my grinding issues were related to wearing pressure plate. When the new clutch went in the grinding went away (I started using SuperTech a while before doing the clutch). 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
apexi Posted May 3, 2019 Share Posted May 3, 2019 (edited) I've tried the following, all 75w-90. Supertech synthetic blend, Amsoil severe gear, subaru extra-s, red line ns. Red Line 75w-90NS is my favorite. Supertech is great for the price as well, you can't go wrong with that either. I prefer red line since it shifts better in cold temperatures. I wasn't impressed with extra-s at all, I don't get why people love it so much. Oh yeah, the new subaru stuff seems quite different from extra-s. But it's important to note with the link below, and uoa's/voa's in general, they don't show you everything that's in an oil. Ashless, non-metallic additives won't show up. https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3557119/Re:_Subaru_High_Performance_Ge Edited May 3, 2019 by apexi Link to comment Share on other sites More sharing options...
Zac88 Posted May 4, 2019 Author Share Posted May 4, 2019 Thanks guys! Drove around all morning to find Mobil Delvac but none carried it so I'll be going with Red Line Link to comment Share on other sites More sharing options...
outahere Posted June 1, 2019 Share Posted June 1, 2019 Motul Gear300 works for me. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2019 Share Posted June 3, 2019 As most of the long time members know, it's Motul Gear 300, its not cheap...but its the best stuff out there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
TMBLKDG Posted June 4, 2019 Share Posted June 4, 2019 I've had great success with a mixture of Redline 75-90NS and Lightweight Shockproof. 170K on my '06 WRX using that without a peep out of the transmission. Link to comment Share on other sites More sharing options...
NORULZleggy Posted June 11, 2019 Share Posted June 11, 2019 Amsoil and keep trucking peeps. Quality and the stand behind there product. I have ran it in all my cars, 04 STI, EVO, 09 WRX, 08 Legacy, current 06 LGT. Link to comment Share on other sites More sharing options...
Outblack Posted June 11, 2019 Share Posted June 11, 2019 Motul 300 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2019 Share Posted June 11, 2019 Amsoil and keep trucking peeps. Quality and the stand behind there product. I have ran it in all my cars, 04 STI, EVO, 09 WRX, 08 Legacy, current 06 LGT. May be it was just me but I didn't seem to have much luck their severgear oil. I have a account with them and use there 5w-40 European Classic and their filters and do 7000 mile oil changes. May be I'll give servegear a try again. It is less money the Motul Gear 300. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
EJ from upstairs Posted August 24, 2019 Share Posted August 24, 2019 About a year ago I changed my 5MT fluid using Mobil1 synthetic. After a few months I noticed a slight grind going into 4th gear. By this summer it was way worse and I thought I was headed for a transmission rebuild. After reading as many posts as I could find on the issue, I decided to try a 50/50 cocktail of Redline Lightweight Shockproof and Motul 300. The grind has disappeared and it shifts like butter in all gears, fyi. Should've looked here sooner! Link to comment Share on other sites More sharing options...
