c123money Posted April 3, 2012 Share Posted April 3, 2012 Anyone heard this or installed it? Curious if the gain is worth it and what this would sound like on 2.5i? Let me know if anyone has seen or heard, thanks! http://www.avoturboworld.com/avoshop/legacy-stage-package-p-109.html Link to comment Share on other sites More sharing options...
c123money Posted April 3, 2012 Author Share Posted April 3, 2012 Probably should have added these... http://img42.imageshack.us/img42/5495/2stage1pkg.jpg http://img36.imageshack.us/img36/3499/2stage1pkg4.jpg Link to comment Share on other sites More sharing options...
m_dogg Posted April 3, 2012 Share Posted April 3, 2012 That dyno graph makes me cry...oh well, racing days are over for me. Link to comment Share on other sites More sharing options...
katalyst Posted April 3, 2012 Share Posted April 3, 2012 interesting, didn't know that they had a dyno plot for the stage 1. but that's actually not too bad of a gain considering they're just "bolt-on" mods. i think it would be worth it just for the exhaust note and making the car a bit funner to drive. not necessarily for the numbers. Link to comment Share on other sites More sharing options...
Leviman Posted April 3, 2012 Share Posted April 3, 2012 My fake dyno graph is showing around 150 hp on a stock motor.... what parameters are you putting into that thing? Link to comment Share on other sites More sharing options...
halwith Posted April 3, 2012 Share Posted April 3, 2012 thats the graph from avo's website. at that price it works out to 80$/hp. they say the turbo kit give ~100hp increase for 3200 which is 32$/hp. so the turbo kit is cheaper than the stage one kit. inbeforebuyagtguys. Link to comment Share on other sites More sharing options...
katalyst Posted April 3, 2012 Share Posted April 3, 2012 My fake dyno graph is showing around 150 hp on a stock motor.... what parameters are you putting into that thing? the avo dyno plot looks correct for stock whp. i have seen one other 2.5i dyno plot in person and have measured my car with a dynalicious app for iphone (i know, not the most accurate) but both actually gave results that show the stock 2.5i generates ~105hp at the wheels. the loss of crank power is likely due to the energy consumption required for the AWD system. Link to comment Share on other sites More sharing options...
Leviman Posted April 4, 2012 Share Posted April 4, 2012 the avo dyno plot looks correct for stock whp. i have seen one other 2.5i dyno plot in person and have measured my car with a dynalicious app for iphone (i know, not the most accurate) but both actually gave results that show the stock 2.5i generates ~105hp at the wheels. the loss of crank power is likely due to the energy consumption required for the AWD system. Well I was thinking that that graph looks identical to the romraider dyno thing so I figured it might just be that. But those plots really don't mean much unless you're comparing two of them (which they are) so my info really isn't applicable:) But still, 10 HP up top is a respectable gain for just an exhaust (and just axle-back at that), and an air filter (the throttle controller does nothing for power). With a tune there should be more to be had Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 4, 2012 Share Posted April 4, 2012 I wonder if this dyno was take Pre-TuneUp OB, AVO bought that 2.5i OB with 100+ K on the clock with no maintenance records at all. They have to de-gunk the heads and do a lot of typical tuneup work to get it back to stock levels. Im curious if this graph was taken then ? 22% loss mean it should be around 130 awhp but let say it was 30% loss due to crappy engine conditions it shoudl still be around 120 awhp However AVO makes good products Link to comment Share on other sites More sharing options...
apexjapan Posted April 5, 2012 Share Posted April 5, 2012 Nah, that was after I did the pre-maintenance. Don't get too obsessed about power figures, different dyno's different numbers is a phrase that will always apply. I always will say this, get the dyno figures only to get a baseline to compare improvements/tuning against. Regards, Paul Hansen http://www.avoturboworld.com Link to comment Share on other sites More sharing options...
aquteq Posted April 10, 2012 Share Posted April 10, 2012 I just bought a 2012 Subaru legacy 2.5i I want to gain at least 30 or more HP any ideas or sites for parts upgrades? Thanks Link to comment Share on other sites More sharing options...
RuskiTrombone Posted April 10, 2012 Share Posted April 10, 2012 http://thmotorsports.com/edelbrock/edelbrock_nitrous_system_wet_system/g-52244.aspx Link to comment Share on other sites More sharing options...
c123money Posted April 10, 2012 Author Share Posted April 10, 2012 hahaha http://thmotorsports.com/edelbrock/edelbrock_nitrous_system_wet_system/g-52244.aspx Link to comment Share on other sites More sharing options...
sweet-subaru Posted April 11, 2012 Share Posted April 11, 2012 "Installing the DBW Controller is very easy, and can be accomplished in as little as 10 minutes. However, once the controller is installed, it will need to be programmed for your vehicle’s specific throttle mapping. Once this is done, it will remain in the Central unit’s memory even if removed from the vehicle." paul can you go into further detail on how to program the controller? and do you have a sound clip of these mufflers ?? Link to comment Share on other sites More sharing options...
apexjapan Posted April 11, 2012 Share Posted April 11, 2012 It's not too complicated - you are basically letting it know where 0% and 100% throttle is. That's measured by a voltage signal (drive by wire....), and the box mainly needs to know what the specifics are for your vehicle. So you start that process, press a button when there's no pressure on the throttle, then after it "learns" that, you mash the throttle to 100%, press the set button, and you are ready to go. Here's a sound clip/video of just the mufflers on my Outback. They have the downturned tips (because Outback), but the basic muffler design is the same. [ame=http://www.youtube.com/watch?v=IZywHgcyqWs]AVO Mufflers on a Subaru 2.5i Outback - YouTube[/ame] Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
halwith Posted April 11, 2012 Share Posted April 11, 2012 I just bought a 2012 Subaru legacy 2.5i I want to gain at least 30 or more HP any ideas or sites for parts upgrades? Thanks you mayhave got the wrong car. Link to comment Share on other sites More sharing options...
Kodax Posted April 13, 2012 Share Posted April 13, 2012 Hmmm...how much more gains will the 3.0R get out of this package? Link to comment Share on other sites More sharing options...
apexjapan Posted April 13, 2012 Share Posted April 13, 2012 Probably a few hp, but not much more than that. I don't have any runs with a 3.0R to go on at this time. N/A motors won't get the same big increases that a turbo motor, but then, there's a lot less worry with N/A's, so it's a trade off. Link to comment Share on other sites More sharing options...
Kodax Posted April 14, 2012 Share Posted April 14, 2012 Any torque difference? I was on the Australia Liberty forums. They had significant gains with CAI and a tune. Was wondering if I could combine that with this avo package. Link to comment Share on other sites More sharing options...
apexjapan Posted April 14, 2012 Share Posted April 14, 2012 Of course you can combine it, and if you do throw a tune in the picture, there will be better gains. Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
Kodax Posted April 14, 2012 Share Posted April 14, 2012 Just to double check, the high flow filter seems like a KN filter and the DBW Throttle Controller seems like another Si Drive to me. Am I wrong? Link to comment Share on other sites More sharing options...
apexjapan Posted April 14, 2012 Share Posted April 14, 2012 It's not a K&N, it's a dry filter design that we've been making since about 2004, I believe. DBW systems are somewhat similar to SI drive, but there's more available settings, and to be honest, the SI drive mapping still has the issues that annoy me the most (lack of initial throttle response) that the DBW system is effective in getting rid of. Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com Link to comment Share on other sites More sharing options...
sanchitosonria Posted April 14, 2012 Share Posted April 14, 2012 are the mufflers the same as the ones that are sold separately on the site? Link to comment Share on other sites More sharing options...
apexjapan Posted April 14, 2012 Share Posted April 14, 2012 Yes - the package is just a set of parts that are ordered fairly commonly as a group, with a discount on the entire set. Mufflers are the same as offered separately. Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
Kodax Posted April 15, 2012 Share Posted April 15, 2012 It's not a K&N, it's a dry filter design that we've been making since about 2004, I believe. DBW systems are somewhat similar to SI drive, but there's more available settings, and to be honest, the SI drive mapping still has the issues that annoy me the most (lack of initial throttle response) that the DBW system is effective in getting rid of. Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com Thanks for the clarification. What do you mean by more available settings on the DBW system? Also, cant the people with the Si drive just change the maps on the Si drive with a tune instead of getting the DBW system? I am kinda confused because I was wondering which part of this package gives the extra gains for the car. Link to comment Share on other sites More sharing options...
