PeterJMC Posted September 16, 2015 Share Posted September 16, 2015 I purchased my 2008 Legacy GT spec.B in September 2015 with 71,800 miles. The car color is Quartz Silver Metallic (QSM). This is my second Subaru Legacy. My first was a 5 speed 2006 Legacy GT in Satin White Pearl with Taupe interior. I traded that car in for a Prius Five Hatchback in December of 2010 and now I'm back! This car has been with two owners prior to me and I am the third owner of this vehicle. Second owner: CT08Spec.B - here is his build thread and here is the sales thread First owner: Chris - Founder of EFI Logics (R.I.P) For Sale thread is here on NASIOC Go baby GO! parts Cobb Accessport (AP) Version 3 (V3) - Installed on 10/16/2016 - etune w/Tuning Alliance Intake - GrimmSpeed Intake - Installed on 12/6/2015 ByPass Valve - Forge Cat-back Exhaust - SPT V2 Downpipe - Invidia w/cat (meow) Lightweight Crank Pulley - GrimmSpeed - Installed on 9/26/15 Suspension '15 STi Steering Rack - Installed on 2/8/16 (Underdogs 2015 STi Steering Rack Swap Thread) STi Steering Knuckle - Installed on 2/8/16 Whiteline Steering Rack Bushings (KSR207) - Installed on 11/28/2015 Whiteline Roll Center Kit (KCA313) - Installed on 11/28/2015 Front Strut Tower Brace - Cusco Front Sway Bar - Whiteline - Installed on 2/8/16 Rear Sway Bar - Cobb Rear Sway Bar Reinforcement - Perrin / Cobb Endlinks (Front and Rear) - Kartboy (solid) Whiteline Rear Adjustable Arm kit (KTA124) - Installed on 9/30/2016 Coilovers - RaceComp Engineering Tarmac 1 - Installed on 10/12/2015 - Springs: 400 lbs Front and 400 lbs Rear - spec.B top hats Front and Rear - Front Rebound: 9 clicks from full soft - Rear Rebound: 7 clicks from full soft - Front Height: 18 threads exposed below collar - Rear Height: 14 threads exposed below collar Wheels Spline lugs - McGard 18x8 BBS RE875 - Powder coated Gunmetal - 235/40/18 - Bridgestone Potenza RE760 Brakes Master Cylinder Brace - GrimmSpeed Front Calipers - Brembo (Powdercoated Black w/Silver Lettering) Brake pads - Hawk HPS Rotors - Something Transmission Short Throw Shifter - Cobb Front Shift Bushing - Cobb Rear Shift Bushing - Kartboy Group N Transmission Mount - Installed on 12/5/2015 Engine Bay Turbo Heat Shield - GrimmSpeed Oil Cap - GrimmSpeed Alternator Cover - GrimmSpeed - Installed on 9/26/15 Radiator Shroud - GrimmSpeed - Installed on 9/26/15 Oil Plug Quick Drain Valve - Fumoto F-105 Redline Tuning QuickLIFT Plus Hood Struts - Installed on 10/22/2015 JDM Engine Bay Covers - Installed on 11/28/2015 Exterior Front Lip Rain Guards - JDM stuff Tint - 3M Crystaline 40CR and 70CR on windshield - Installed on 10/22/2015 Trunk wing - Stanza Wing Horns - Hella Supertones w/Subimods bracket Grill - Painted Flat/Matte Black Front Plate Mounting - GrimmSpeed Front Plate Relocation Kit - Installed on 9/22/15 Headlights - Custom painted headlight housing - Reflectors removed - Projectors: TSX-R lenses - HID: 6k Foglights - HID 5k - Housing - Painted flat/matte black Interior Si Drive Dial - Lathewerks Steering Wheel - GT Spec (D shaped) Interior LED Lights - Diode Dynamics Center Arm Rest Extension - Subaru Center Arm Rest Storage (JDM Part No: J2017AG00) - Installed on 10/15/2016 STi Shift Knob (Subaru Part No: 35022VA000) - Installed on 12/20/2015 Link to comment Share on other sites More sharing options...
PeterJMC Posted September 16, 2015 Author Share Posted September 16, 2015 Picture Album - https://goo.gl/photos/6hEuZcnysbYH7QQm7 Link to comment Share on other sites More sharing options...
PeterJMC Posted September 16, 2015 Author Share Posted September 16, 2015 Things to do: - Reposition an A/C line that is rubbing against the GrimmSpeed Master Brake Cylinder Brace - Troubleshoot and fix illuminated VDC light - Replace/Fix front windshiled, it's severely pitted - Install everything below! Parts Whore List: Rear Brembo Conversion - Rear Brembo Brake Calipers - Rear Brake Rotor - DBA T2 ('04 STi fitment) - Rear Brake Pads - Hawk HPS - KNS Brakes enlarged rear parking brake shoes - KNS Brakes rear Brembo caliper mounting bracket Injector Dynamics 1000cc Injectors Composite TGV Deletes DW 300c Fuel pump Infamous Performance Tuning: Turbo Oil Feed Line v2 GrimmSpeed: Electronic Boost Control Solenoid GrimmSpeed: Top Mount Intercooler (Thermal coated) JDM Power Folding Side Mirrors GrimmSpeed: Air Oil Separator Cobb: Mufflers Whiteline Rear Swaybar MOOG: Endlinks (K750023) MOOG: Endlinks (K750049) Perrin: Turbo Inlet Pipe GrimmSpeed: EWG up-pipe Tial: 38mm MVS EWG An OEM Turbo... JDM Double DIN Radio Conversion Goodridge SS Rear Brake Line Goodridge SS Clutch Line AVO Rear Swaybar Reinforcement Bracket JDM Honeycomb grille WeatherTech Digital Floor Mats Link to comment Share on other sites More sharing options...
PeterJMC Posted September 16, 2015 Author Share Posted September 16, 2015 I'm picking the car up this Sunday with my brother and a friend! We are driving up in a rental and driving back with the car. Link to comment Share on other sites More sharing options...
Merc6 Posted September 16, 2015 Share Posted September 16, 2015 Hope it checks out, rebuilds are not as fun as it looks online. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted September 16, 2015 Share Posted September 16, 2015 You better bring friends, there may be guns involved. The previous owner may have a hard time letting go...LOL Enjoy the car, your going to have a great ride home. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted September 16, 2015 Share Posted September 16, 2015 Jealous of the B, I've seen one within a 60 mile drive from my place. None are out here. Congrats on the purchase, now lets see some pics! 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Max Capacity Posted September 17, 2015 Share Posted September 17, 2015 Pic's are here, http://legacygt.com/forums/showthread.php/jays-2008-lgt-spec-b-166467.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Merc6 Posted September 20, 2015 Share Posted September 20, 2015 I'm picking the car up this Sunday with my brother and a friend! We are driving up in a rental and driving back with the car. Today is the day, where is the Vlog? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
PeterJMC Posted September 21, 2015 Author Share Posted September 21, 2015 The car is home! We got home at around 10pm last night. I'll have to take pictures when I get home after work. Here is one during one of the handful of re-fuelings on the way home... This definitely doesn't sip gas like a Prius. Link to comment Share on other sites More sharing options...
PeterJMC Posted September 21, 2015 Author Share Posted September 21, 2015 Here is a shot of leaving the CT08Spec.Bs place Link to comment Share on other sites More sharing options...
Gire Posted September 21, 2015 Share Posted September 21, 2015 Welcome back, OG member! Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2015 Share Posted September 21, 2015 Yep, that's no Prius, but it's a lot more fun to drive. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PeterJMC Posted September 22, 2015 Author Share Posted September 22, 2015 @ 72,255 miles I did all this: Clear vinyl wrapped front plate Installed a GrimmSpeed License Plate Relocation Kit Installed a plate frame on the rear First MOD done! I just did the pretty basic thing of putting the front and rear license plates on the car. Obviously, this isn't really anything exciting. Maryland requires both front and rear license plates to be displayed. Clear vinyl wrapped front plate I clear vinyl wrapped the front plate to help prevent surface pitting due to impacts from road debris and to also aid in the ease of cleaning off bug guts! I'm pretty sure that I could technically be cited a repair order from Maryland because I "technically" have something covering the front plate. I've been cited a handful of times for having clear bubble covers over a plate even though the covers didn't distort the plates image at all. Ohh well. The installation was pretty straight forward, if you've done vinyl wrapping before. You will absolutely need a heat gun to properly shape the vinyl to conform and stretch around the raised lettering. If you plan on doing this and its your first time, I'd recommend paying a shop to do this or buying a couple of sheets in case you mess up. You can't tell it's wrapped unless you are 1 foot away and really looking for something. GrimmSpeed License Plate Relocation Kit P/N: 094011 I decided to go with the GrimmSpeed License Plate Relocation Kit because it provided a very clean no drill solution to mount a front plate to the car. The bumper had no holes in it and I wanted to keep it that way. The installation was super easy and wasn't any different from the generic installation instructions they have hosted online HERE. You have the ability to position and angle the front plate in just about any manner you wish to. The finished mounting position that I settled with is at a slight angle that follows the curve of the front bumper. To finish this up, I'd like to drill a hole in the tow hook cover to clean up the overall install. I'll complete that some other time. Unboxed! Installed front view Installed - view from passenger side looking toward driver side Installed - view from drivers side looking toward passenger side Installed - view from overhead Installed a plate frame on the rear I picked up a plate frame for the rear that doesn't cover any of the plate and does provide a simple and thin border around the perimeter. I also picked up a mounting and hardware cover kit. With everything tightened down, the mounting kit keeps the the plate slightly raised off the deck lid. It's a nice no rattle install with the bolt heads covered Plate Frame and Hardware Installed Installed and showing air gap Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted September 22, 2015 Share Posted September 22, 2015 Welcome back!! Link to comment Share on other sites More sharing options...
300zx2g35 Posted September 22, 2015 Share Posted September 22, 2015 To finish this up, I'd like to drill a hole in the tow hook cover to clean up the overall install. I'll complete that some other time. I did this with both my LGT and Spec B and it definitely looks a lot better than not having the cover there. Link to comment Share on other sites More sharing options...
Merc6 Posted September 23, 2015 Share Posted September 23, 2015 VA has the same laws and I hated the front plate. Being in Ohio now with VA plates the front is gone. Haven't done anything to the holes yet. Sent from my iFail using Tapatalk App 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
PeterJMC Posted September 23, 2015 Author Share Posted September 23, 2015 Welcome back!! Thanks, Nolmers! It's good to be back and is taking a bit to get used to, but in a good way. I did this with both my LGT and Spec B and it definitely looks a lot better than not having the cover there. Any tips on drilling the hole right the first time? I was thinking about using a laser to maintain the marked area. VA has the same laws and I hated the front plate. Being in Ohio now with VA plates the front is gone. Haven't done anything to the holes yet. ... Does Ohio require front plates that you might have to eventually get if you switch your registration? Link to comment Share on other sites More sharing options...
Merc6 Posted September 23, 2015 Share Posted September 23, 2015 The VA registration has my Ohio address so they didn't seem to care. Being so far away they don't enforce VA plate laws nor emissions but I still have a cat in the down pipe. Va for cars not garaged in Va only need to be insured to renew. I only have to do safety when I get back to that area with my car. Usually Tyson's corner or somewhere near. Sent from my iFail using Tapatalk App 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Thetoad Posted September 23, 2015 Share Posted September 23, 2015 If only,,,,,I had a stealthy grille on mine,,,, It's the only shortcoming I have,,,,but driving one of these types are something that may appear transient for the moment but on long trips those moments accumulate and as has been said they are incredibly fun to drive.....regardless of their age.... Link to comment Share on other sites More sharing options...
LatentWagen Posted September 23, 2015 Share Posted September 23, 2015 Oh look, a build thread! Don't know how I missed the first week of this show LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 23, 2015 Share Posted September 23, 2015 "Build" thread? He put vinyl on his license plate. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
LatentWagen Posted September 23, 2015 Share Posted September 23, 2015 Pshh, see those "more stuff here" filler posts? ... I see much stickerbombing in this thread's future. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
BigBlack-V Posted September 23, 2015 Share Posted September 23, 2015 My poor old car :spin::lol::p I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
PeterJMC Posted September 23, 2015 Author Share Posted September 23, 2015 @ 72,255 miles I took it to AndrewTech Automotive and they did all this in the past two days: Performed Multi-point Inspection Performed Compression and Leakdown Test Removed Tint Took the car to a Maryland (MD) Vehicle Inspection Station After looking at reviews on a few shops in the area, I decided to take it to AndrewTech Automotive to look over the car and make sure it's ready to pass MD state inspection. Before I even got to the shop the car threw a Check Engine Light (CEL) with a code P0172 - System too rich bank 1. Vacuum hoses checked out OKAY. The IAT needed some TLC. I cleaned it up, cleared the codes and logged some miles on the car before heading in to make sure the car was good to go. Performed Multi-point Inspection Everything checked out good. A few things noted were that the the following items needed to be replaced soon battery, oil, and accessory belt. Performed Compression and Leakdown Test Compression TestCylinder 1 = 130Cylinder 2 = 130Cylinder 3 = 130Cylinder 4 = 130 Leakdown Results:Cylinder 1 - 5%Cylinder 2 - 4%Cylinder 3 - 5%Cylinder 4 - 5% Removed Tint Car was purchased with 20% tint all around which would not pass inspection. AndrewTech took the car to a local shop, Cutting Edge Tint, to do the work. The tint was pulled off and I'm looking at some brands to put back on. Took the car to a Maryland (MD) Vehicle Inspection Station AndrewTech also took the car to a local shop that is licensed to perform state inspections. The car passed MD inspection with only one minor correction needed. The center brake light was missing a bulb. Bulb was installed the car is now street legal! So now it's time for the MODs to begin? Link to comment Share on other sites More sharing options...
