leafyman Posted June 22, 2018 Share Posted June 22, 2018 I just installed a pair of Rockford Fosgate P165 and P165s (component system). The left side (driver's side) sounds great, but the problem is the right side (passenger side). The tweeter, front, and rear door speakers all sound terrible. The volume is very low and the quality is very muffled (similar to the static quality you get from the radio). The wiring should be correct (checked with online sources) and speakers should be fine, as swapping speakers had the same effect. Is it possible that the headunit is the problem here, or it potentially some other problem? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted June 22, 2018 Share Posted June 22, 2018 sounds like an output issue on the headunit or a balance issue. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
