islandborn Posted September 27, 2018 Share Posted September 27, 2018 I have been thru 4 clutches over the life of my '12 LGT. NEVER did I know about this simple preventive measure. Learn from me - do it next time you change your clutch out. As you know, changing the clutch on our cars is quite labor intensive. So here I am, with 10k on my new clutch and I have to go back in to fix something so simple. The link below really has a good read on what happens as well as where I bought it from. (mine looked like the fourth picture - punched thru) Clutch fork - http://www.subispeed.com/2015-subaru-wrx/velox-billet-clutch-fork-2015-wrx-mt#.W60wLmhKi1s Clutch fork pivot ball - http://www.subispeed.com/2015-subaru-wrx/drivetrain/clutches/velox-billet-clutch-fork-pivot-2013-ft86#.W60wnmhKi1s Don't go with OEM - no reason as the cost is not that significant between them. Go buy it and do what Zee and GTEASER does - put it on your shelf - so that when you change your clutch, do this too. Even if you don't need to! Do it. Much love and you're welcome for the enable. Link to comment Share on other sites More sharing options...
eckseleven Posted September 27, 2018 Share Posted September 27, 2018 Good info and links to specific parts and vendors is always appreciated. I'm debating gathering up clutch parts for when the day comes. I'll keep this in mind. Now I just need someone to tell me where to get that TSK3 kit thing Link to comment Share on other sites More sharing options...
Zee199969 Posted September 27, 2018 Share Posted September 27, 2018 Good info and links to specific parts and vendors is always appreciated. I'm debating gathering up clutch parts for when the day comes. I'll keep this in mind. Now I just need someone to tell me where to get that TSK3 kit thing quick search found this:https://www.ebay.com/itm/NEW-PDM-TranQuil-TSK3-Snout-Throwout-Bearing-and-Sleeve-Repair-Kit-Subaru-Turbo-/172362979856 there's a 15% off code, PICKSOON usable at checkout My "Build" Link to comment Share on other sites More sharing options...
airgasm Posted September 27, 2018 Share Posted September 27, 2018 Does that billet clutch fork also fit 4th gen legacies? Link to comment Share on other sites More sharing options...
Syndicate Posted September 29, 2018 Share Posted September 29, 2018 Good info and links to specific parts and vendors is always appreciated. I'm debating gathering up clutch parts for when the day comes. I'll keep this in mind. Now I just need someone to tell me where to get that TSK3 kit thing ...Mach V Motorsport carries the TSK3 kit. Link to comment Share on other sites More sharing options...
Brock Samson Posted January 4, 2019 Share Posted January 4, 2019 The OEM clutch pivot ball I used as preventative maintenance broke after just *750 miles*. Wish I had gone with Subispeed's. Link to comment Share on other sites More sharing options...
Bigktx254 Posted January 8, 2019 Share Posted January 8, 2019 Can i use the billet pivot ball with the OEM fork? Link to comment Share on other sites More sharing options...
Zee199969 Posted January 8, 2019 Share Posted January 8, 2019 Can i use the billet pivot ball with the OEM fork? I think it's the OEM fork that is prone to failure with a stronger aftermarket clutch. If anything, I'd go with the aftermarket fork vs pivot ball between the two, but the pivot ball is fairly inexpensive so why not replace both? My "Build" Link to comment Share on other sites More sharing options...
SJGT Posted January 13, 2019 Share Posted January 13, 2019 Definitely have these parts in my mind for clutch job - I think these were the fail points which caused my 1st aftermarket clutch to die an early death Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
