saar stam Posted October 9, 2020 Share Posted October 9, 2020 HELLO Does any one can recognize this connection that mark in circle : I100 This wire is going from the power supply to the ac outback 2010 same as B4 . THANKS Link to comment Share on other sites More sharing options...
Brunzo Posted October 9, 2020 Share Posted October 9, 2020 "i" letter in front of the number means "Instrument", ie this connector is a part of instrument panel wiring. Open PDF "Instrument Panel wiring harness" location table and check for location on diagram (attached picture). It shows location of connector behind the glove box. Link to comment Share on other sites More sharing options...
DrD123 Posted October 10, 2020 Share Posted October 10, 2020 So in the USDM service manuals, it doesn't show pin A2 from the AC controller as going into a joint connector at all - it goes directly to fuse 12 (FB-31). I100 might be something different in that car. Link to comment Share on other sites More sharing options...
