Ridgeracer Posted December 25, 2010 Share Posted December 25, 2010 Merry Xmas all. Seems like my front O2 died on me today so I was thinking about using the analog output 2 I believe to simulate the front O2 sensor. The outputs are 0-5V signal but I'm not sure about the proper scaling to use. Anyone else try this yet?? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Th3Franz Posted December 25, 2010 Share Posted December 25, 2010 the LC-1 wideband does not read accurately around stoich. I wouldn't use any of its signals for closed loop, if that's what you are thinking. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Ridgeracer Posted December 25, 2010 Author Share Posted December 25, 2010 Hummm....exactly what I wanted to do...Well has anyone tried to use a Bosch 15011 OE sensor vs the stock Denso that likes to die every 60K miles...? What about NTK/NGK 24821..?? Did more searching. I found the OE Denso sensor on RockAuto.com for 90 bucks. I only think the LC-1 can be used for the rear sensor input on the ECM. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Th3Franz Posted December 26, 2010 Share Posted December 26, 2010 I'm not using a rear O2 at all and the car is running great. I just disabled the rear O2 in the map. My car has 68k miles and I run leaded race gas and my front O2 is still reading fine. I would stick with the OEM Denso front O2 sensor -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Ridgeracer Posted December 26, 2010 Author Share Posted December 26, 2010 Yeah I'll stick with what I know works. thx Got the new Denso sensor from Rockauto yesterday. Same exact sensor but the protective cable jacket is blue vs yellow. Took about 1 minute for the ECU to calibrate the heater. Cost me 95 bucks shipped priority 3 day mail. I think the dealer charges 115 or so. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
