jojorios Posted May 15, 2017 Share Posted May 15, 2017 I was looking through the BNR website and forgot that they had offered a 16G turbo (TD05H EVO3 16G). I don't think I have ever seen it mentioned on here. Just curious on any thoughts on it, if any. Link to comment Share on other sites More sharing options...
Mrstacy Posted May 15, 2017 Share Posted May 15, 2017 ^ I believe they said boost kicks in 300 rpm lower than 18G. Link to comment Share on other sites More sharing options...
FLlegacy Posted May 15, 2017 Share Posted May 15, 2017 Is the exhaust housing also upgraded? And the wastegate? If so I would say go for it! Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted May 15, 2017 Share Posted May 15, 2017 IIRC the 18G is best suited for our unique setup. I think islandborn ran a 20G with no additional benefits vs his 18G. Though I don't recall anyone posting about a 16G My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted May 15, 2017 Share Posted May 15, 2017 fahr_side said that the only gain we get from the 20g over the 18g is if you're running the STI cams, or aftermarket cams, along with it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
mcg_ Posted May 15, 2017 Share Posted May 15, 2017 When I inquired the most knowledge 5th-gen guy on the forums here (tough guess, right) about a TDO5/16G, he said the following "Having done the r&d we decided the 16G did not offer anything useful. The 18G spoils so fast on that short factory header it's not worth the hit to power potential." Regardless, I'm still interested in a 16G..... Link to comment Share on other sites More sharing options...
Rutchard Posted May 15, 2017 Share Posted May 15, 2017 I'm guessing the 16g isn't much of an improvement over the stock turbo, especially for the same price as the 18g... Link to comment Share on other sites More sharing options...
jojorios Posted May 15, 2017 Author Share Posted May 15, 2017 Yeah, I know that the 18G seems to be the sweestspot. I was more curious about the 16G just because, I've never seen anything on it on the boards. Link to comment Share on other sites More sharing options...
Starks Posted May 15, 2017 Share Posted May 15, 2017 I have that 16g on my DD lancer. Wait!...Are they really swapping the compressor wheels and mating the 16g cold side to the vf54? Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
fahr_side Posted May 16, 2017 Share Posted May 16, 2017 [emoji23][emoji23] I have that 16g on my DD lancer. Wait!...Are they really swapping the compressor wheels and mating the 16g cold side to the vf54? Sent from my SM-G935V using Tapatalk No, this is definitely not recommended. Go search on Deadbolt VF-40-18G for a full development history / horror story about big compressors matched to small turbines. It's crucial to maintain balance between exhaust and intake flow. There's no point cramming more air into the cylinders than you can scavenge via the exhaust. Since any of these hybrid turbos have to be custom built, you can choose any compressor wheel you like from 16G to 20G. Bryan used to offer the FP 68HTA which was great for the E85-only crowd. I can tell you nothing larger than a TD05H turbine will fit 'nicely' in the exhaust housing. Cram a TD06 in there and the geometry is horrible. On a 2.5, the 20G is really too large to be paired with a TD05H except in an 8cm2 housing, and even that isn't ideal. The stock P18 exhaust housing is about 7.4cm2 by my measurements. See how the physical, mechanical limits are often outside of practical limits? Note that the STi exhaust cams have the same valve lift as the oldskool single-AVCS 255 or 257 items. I haven't measured the duration on either but the profile looks identical. All you are doing here is un-handicapping the motor after Subaru dumbed it down. I no longer stock these hybrid turbos btw, I shipped the last one today. Any further orders would have to be GBs. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
BBPeik Posted May 16, 2017 Share Posted May 16, 2017 Thanks as always for the helpful info. So I am running the 20g with the sti cams and I must say it is pretty good. I have seen the comparison on how the 18G is better though. In your opinion, what would be the best turbo for our cars with the associated mods? Cams, injectors etc.? My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
fahr_side Posted May 16, 2017 Share Posted May 16, 2017 Again it's more a question of availability and how far you're willing to go with custom fabrication. If you're keeping the stock header you're stuck with the stock housings and IMO the best route for that is the TD05H-18G you now have. As I laid out in my power manifesto, you need 750s to feed that on gas and 1000s if running E85. I think the used STi exhaust cams are a really good solution as they are cheap, plentiful and OEM quality. OTOH, S2baru had really good results with his GSC stg1 cams. I was very impressed with how those filled out his torque curve without seeming to delay spool to any appreciable degree. I think the Tomei Poncam would do very well also. Once you decide that's not enough, you're moving on from the stock header and into custom fabrication territory, and which point you're only really limited by what will physically fit between the oil pan and the radiator. :O How crazy do you want get? What won't you do in the quest for more power, or can't accept? Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
BBPeik Posted May 16, 2017 Share Posted May 16, 2017 Thanks for the help fahr_side. Sounds like the only direction for me is custom. That will not be happening at all. Unless I move out of California anyway. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
GTEASER Posted May 16, 2017 Share Posted May 16, 2017 Yeah, good ol' California. That's why my dream has always been 2 motors. One relatively stock running Stage1 or Stage2 (dp only to swap if need be for emissions testing), and run the other as a monster build. A weekend or 2 every 2 years to drop the stock motor in, get the emissions test, and swap back to the monster motor should be all it takes to circumvent the emissions requirements. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
BBPeik Posted May 16, 2017 Share Posted May 16, 2017 Yeah, I think I am as far as you can go here and still smog. I have to change DP, BPV, CP, and IC. Other than that I am "Smog legal" My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
