94legacy22 Posted November 1, 2013 Share Posted November 1, 2013 i have a 2nd gen 2.5 flywheel. i am thinking about doing my clutch in a few months. can i get it machined and then put it in my first gen with a 2.2? not sure if the weight is different. or if it will even fit. thanks!! and i was also woundering if a wrx clutch or even a ss clutch kit will work too. thanks!! Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 2, 2013 Share Posted November 2, 2013 An '02 wrx clutch works on a SS. I don't see why it wouldn't work on a NA first gen but I can't say for sure. Link to comment Share on other sites More sharing options...
USLiberty Posted November 3, 2013 Share Posted November 3, 2013 All turbo clutches are a hydralic pull type, na's use a cable and a pushtype. To do this you would need a SS pedal set and clutch cylinder... I swapped my L with SS equipment and I had to drill a few holes in the firewall to mount the slave cylinder. Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 5, 2013 Share Posted November 5, 2013 Crap! That sucks. I have an SS transmission that I want to swap into my L but I don't have the pedal set and clutch cylinder. Link to comment Share on other sites More sharing options...
USLiberty Posted November 5, 2013 Share Posted November 5, 2013 Correction, The 06+ wrx has a hydraulic push type clutch now. Im pretty sure, You could use a regular cable clutch and pedal set on the SS trans, just wont hold as much power. All the 5 speeds are pretty much interchangeable, a 5spd clutch will even work in a 6 spd but not the other way around. Link to comment Share on other sites More sharing options...
