Madrig ,the north BP5 .
madrig
Would love one of those belt covers but Imagine by the time international shipping comes into it they’ll be quite pricey
yes shipping international from Canada is insane , this is too bad , a lot of people asked me for . USA have better rate .
unless you have an account with a carrier and use it .
mad. post some pic of the cover on the engine when you get a chance. also we should talk about cf for the trim. not a lot of people run the post facelift consul, but i'd be willing to fund some of the development for a set.
i want to do it , the headache is to make the bracket for the clip .the clip can take a lot of time in fabrication process , i have different idea , it take time to devellop and is not my priority right now .
the tooling for the kicker panel are almost done , but not sure i can mold until september .
  • 1 month later...
the gaz tank for sure ! it s bad !
the flange is rust and one of the hose came out when i touch it . in fact the rust start on the top , when usually there is no rust proofing sprayed and where sand /dirt accumulate .
turn me mad cause doing this job ,on a 10 year old rusty car, is looking for problem .
This is good to know. When I inspect my tank and fuel pump for leaks, ill keep this in mind!
Did you already replace the gas tank?
  • 3 weeks later...
  • 1 month later...
worked on a new prototype for the cubby gauge . installed in the car also , still never bought the oil pressure gauge !
i think i should have bought the white one and do the red cirlcle , same concept as the ring for the center console . will try !
That cubby pod looks fantastic! It looks just like the OEM STI gauge pack bezel.
I just wish someone could make a triple stealth pod so the door could still close or at least some type of cover over it, if not the original cubby door.
[ATTACH]264568[/ATTACH]
https://flic.kr/s/aHsmgVMtS6
this is a kit i did for a member
is all fiberglass parts !
people do not notice is extended !
[ATTACH]264618[/ATTACH]
So based on the first picture the fender is a two piece that needs to be bonded, primed and painted? If not, is it just a single piece like the OEM front fender? I am obviously interested and after witnessing the quality of your products first hand, I'm sure the fenders won't disappoint. Also of course I'm assuming there is no difference between the 05-07 front fenders between the wagon and sedan Legacy.
