stopthepig Posted January 25, 2016 Share Posted January 25, 2016 dumbest thing happenned intsalling after market radio and yellow constant 12 volt wire came loose when sliding radio in and shorted out.. well now key is stuck in ignition, gear shifter wont shift, and car has not started since short. no power or power drain since battery dead now.. suggestions? has this happened to anyone else? also could it be some fuse /relay? there was initially some humming coming from dash area around sterring wheel and some humming from engine compartment.. thanks in advance for any help Raul:spin: Link to comment Share on other sites More sharing options...
CTATV Posted January 25, 2016 Share Posted January 25, 2016 dumbest thing happenned intsalling after market radio and yellow constant 12 volt wire came loose when sliding radio in and shorted out.. well now key is stuck in ignition, gear shifter wont shift, and car has not started since short. no power or power drain since battery dead now.. suggestions? has this happened to anyone else? also could it be some fuse /relay? there was initially some humming coming from dash area around sterring wheel and some humming from engine compartment.. thanks in advance for any help Raul:spin: Subscribed Link to comment Share on other sites More sharing options...
stopthepig Posted January 25, 2016 Author Share Posted January 25, 2016 huh? Link to comment Share on other sites More sharing options...
