bcmaxx Posted January 17, 2015 Share Posted January 17, 2015 I have a ej22e, wrx oil pump, turbo supply line teed off the oil pressure sensor port, new hlas, poperly bled. at high engine rpm the rh bank hlas are losing there prime ( 5000rpm plus). I am currently running 5w30 mobil synthetic oil, 15-16 psi at idle (740rpm) and 56-59 at 5000rpm. Is the oil too thin at operating temp?, is my turbo theiving too much flow from the rh oil gallery? pressure seems just fine, could it be flow? I also run only oem subaru filters. Was thinking of crimping my steel tube turbo supply line , and maybe changing to a 10w30? or 15w40? at a loss. Problem seemed to crop up after doing the tcm mod, which brings the rpm higher before shifting. Link to comment Share on other sites More sharing options...
USLiberty Posted January 17, 2015 Share Posted January 17, 2015 I have 25-30 psi at idle(950rpm warmed up) and up to 90 driving with rotella t6 5-40w , could it be an oil pump or clogged line? Could Run some mystery oil till the next change. Link to comment Share on other sites More sharing options...
snederhiser Posted January 18, 2015 Share Posted January 18, 2015 Hello; Thinking you are on the right track with your thinking! The turbo on my Mercedes diesel has a restrictor port on the infeed oil line. I would make a bushing to fit into the inlet line of the turbo and drill the orifice .030-.060 thousandths. Also using a heavier weight oil such as t-6 might be a good idea, Steven. Link to comment Share on other sites More sharing options...
bcmaxx Posted January 18, 2015 Author Share Posted January 18, 2015 I put a bit of a crimp in the steel line and a half bottle of lucas. So far so good. Ill swap the oil for 10w30 as well Link to comment Share on other sites More sharing options...
USLiberty Posted January 18, 2015 Share Posted January 18, 2015 The Shell rotella T6 is great for even track day subarus and its usually 21$ or less for a gallon at wallmart. What are you using for your turbo oil feed line? I had issues with the return line leaking after installing a non oem steel braided line. I did not notice low oil pressure but my feed line comes off the back of the block. Maybe you need some restriction, you could probably use OEM turbo lines. I have a few wrx oil feed/return lines if you need. Link to comment Share on other sites More sharing options...
bcmaxx Posted January 18, 2015 Author Share Posted January 18, 2015 5/16 steel line with oem banjo fitting at turbo side. Im pretty sure it had an orifice on it. Its off an 02 wrx Link to comment Share on other sites More sharing options...
bcmaxx Posted January 23, 2015 Author Share Posted January 23, 2015 there is no orifice i cant believe the flow. Not too sure how I'm not getting smoke out my turbo.. adding a 0.03 (0.8mm) orifice tommorow. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 24, 2015 Share Posted January 24, 2015 Blown seals on the turbo? Link to comment Share on other sites More sharing options...
bcmaxx Posted January 24, 2015 Author Share Posted January 24, 2015 Blown seals on the turbo? Nope no smoke at all. Turbo is working perfect. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 24, 2015 Share Posted January 24, 2015 Oops sorry. I now see you said "not" getting smoke out of my turbo. Link to comment Share on other sites More sharing options...
bcmaxx Posted January 25, 2015 Author Share Posted January 25, 2015 Replaced complete rh rocker shaft. Bled new hlas. Used a syring and primed assemby before install. Nice and quiet. Link to comment Share on other sites More sharing options...
