DugsSin Posted October 5, 2018 Share Posted October 5, 2018 Time for some Pre-Winter maintenance. Hoping the Osrams are as good at the Rally ones I had. The three fingered oil wrench works very well. Link to comment Share on other sites More sharing options...
Perscitus Posted October 5, 2018 Share Posted October 5, 2018 (edited) Time for some Pre-Winter maintenance. Hoping the Osrams are as good at the Rally ones I had. The three fingered oil wrench works very well.Have you been running the CVTF in your 2018 OB 3.6R already or planning to drain-n-fill the first time? Edited October 5, 2018 by Perscitus Link to comment Share on other sites More sharing options...
Scooby Fan Posted October 5, 2018 Share Posted October 5, 2018 Okay .... Where does CVT fluid go in a 5th Gen ??? In the 5EAT? Oh yeah...In his OB I guess Link to comment Share on other sites More sharing options...
DugsSin Posted October 5, 2018 Share Posted October 5, 2018 (edited) Have you been running the CVTF in your 2018 OB 3.6R already or planning to drain-n-fill the first time? This will be the first CVT fluid change for the OB but she's not due yet just using my 25% discount. The OB is a 5th Gen. just from a more refined mother. Picked up some break in oil too for my son's soon to be built IAG bullet that might be scary even for the ole man. Edited October 6, 2018 by DugsSin Link to comment Share on other sites More sharing options...
jojorios Posted October 11, 2018 Share Posted October 11, 2018 At 100k, getting ready to have this baby run another 100. Ordered Timing Belt Stuff: http://sixstarbernie.com/i-23179008-subaru-oem-front-oil-seals-kit-wrx-impreza-sti-legacy-gt-forester-xt-outback-turbo.html Thermostat http://sixstarbernie.com/i-23179101-thermostat-seal-kit-for-subaru-wrx-impreza-sti-forester-outback-legacy-baja.html Cam Seals (Just in Case) http://sixstarbernie.com/i-23179008-subaru-oem-front-oil-seals-kit-wrx-impreza-sti-legacy-gt-forester-xt-outback-turbo.html And also from Subaru: Water Pump with gaskets All turbo coolant line items New Top and lower Radiator hoses Link to comment Share on other sites More sharing options...
Perscitus Posted October 11, 2018 Share Posted October 11, 2018 At 100k, getting ready to have this baby run another 100. Thermostat http://sixstarbernie.com/i-23179101-thermostat-seal-kit-for-subaru-wrx-impreza-sti-forester-outback-legacy-baja.htmlNice Jorge! Same thermostat I've been running for 4 years. Bernie mis-quoted the part numbers through: He lists: 21210AA030 Thermostat (1) + 21236AA010 Gasket (1) Should be: 21200AA072 Thermostat (1) + 21236AA010 Gasket (1) = 21210AA030 Kit (the kit part number for both this specific thermostat and gasket paired with at least 5 others). https://legacygt.com/forums/showthread.php/did-you-do-your-5th-gen-todayii-vol-2-closed-200439.html?p=4989095&highlight=thermostat#post4989095 Link to comment Share on other sites More sharing options...
GTEASER Posted October 11, 2018 Share Posted October 11, 2018 PSA.... 5th Gen Leggy is same chassis as 4th Gen OB. 6th Gen Leggy is same chassis as 5th Gen OB. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
jojorios Posted October 11, 2018 Share Posted October 11, 2018 Nice Jorge! Same thermostat I've been running for 4 years. Bernie mis-quoted the part numbers through: He lists: 21210AA030 Thermostat (1) + 21236AA010 Gasket (1) Should be: 21200AA072 Thermostat (1) + 21236AA010 Gasket (1) = 21210AA030 Kit (the kit part number for both this specific thermostat and gasket paired with at least 5 others). https://legacygt.com/forums/showthread.php/did-you-do-your-5th-gen-todayii-vol-2-closed-200439.html?p=4989095&highlight=thermostat#post4989095 Yeah, i noticed that when i was double checking. After cross referencing his numbers, your post and subie site I figured it out lol. Link to comment Share on other sites More sharing options...
Perscitus Posted October 14, 2018 Share Posted October 14, 2018 Time for some Pre-Winter maintenance. Hoping the Osrams are as good at the Rally ones I had. The three fingered oil wrench works very well.Check out posts #1456 on... https://forums.nasioc.com/forums/showthread.php?t=2628737&page=59 Link to comment Share on other sites More sharing options...
Falcor Posted October 17, 2018 Share Posted October 17, 2018 Swung by Subaru on my way home last night and picked this up finally. Since the GT is due for an oil change, I grabbed an oil filter as well. We had a $10 off coupon from the dealer, so made it worth it. Link to comment Share on other sites More sharing options...
shibu Posted October 29, 2018 Share Posted October 29, 2018 I got DOT 4 brake fluid and a 1-1/4 clear pvc pipe, I'm planning to perform a complete brake fluid flush this week. Link to comment Share on other sites More sharing options...
amusa Posted November 2, 2018 Share Posted November 2, 2018 Order is placed for a set of OEM trunk cargo net F551SAJ301. Link to comment Share on other sites More sharing options...
amusa Posted November 2, 2018 Share Posted November 2, 2018 Okay .... Where does CVT fluid go in a 5th Gen ??? In the 5EAT? Oh yeah...In his OB I guess There is a fill and check plug on the transmission on the passenger side above the axle. I took a picture of it while back but if needed I can find it and post it. Link to comment Share on other sites More sharing options...
Perscitus Posted November 2, 2018 Share Posted November 2, 2018 Yup, recently did a full drain and fill on my brother's 2015+ WRX HT-CVT. We used the drain plug, fill level-check plug and then the plugs ont he passenger side of the axle to top her off while up to temp (~140F CVTF temp in the valve body). She took about 6 quarts of Amsoil CVTF and runs great. Another drain and fill in the Spring (to get the fresh fluid ratio up) and then again next Summer/Fall (bringing her up to almost all Amsoil and no Subaru fluid) Mind you the car is also fitted with the Setrab oil cooler (which takes almost an extra 0.5/0.75 qt of fluid) and the lines needed to route it to and from the area behind the front grill. Link to comment Share on other sites More sharing options...
DrD123 Posted November 5, 2018 Share Posted November 5, 2018 New tires all around. Went with the Pirelli P Zero all season plus again - the revised compound is supposed to have improved them further. Drove 500 miles on them this weekend - definitely quieter than the old ones, and they have a different speed rating (Y for the new vs. W for the old ones) Link to comment Share on other sites More sharing options...
hallowground Posted November 5, 2018 Share Posted November 5, 2018 New tires all around. Went with the Pirelli P Zero all season plus again - the revised compound is supposed to have improved them further. Drove 500 miles on them this weekend - definitely quieter than the old ones, and they have a different speed rating (Y for the new vs. W for the old ones)Do you like them? I usually am a strong pirelli fan but I was leaning toward the Yokohama avid ascend gt this next time. I drive 80% highway miles on flat road. I was looking for something with a smooth quiet ride to it. Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
cww516 Posted November 5, 2018 Share Posted November 5, 2018 I've got a set of those on my Baja that were on there when I bought it. They're not particularly loud (far as I've noticed), although I always have the radio on, so my perception may be skewed. Could be the lack of weight over the back axle, or skewed perception again due to having snow tires on the Legacy, but they're pretty bad in the snow in my experience. Shouldn't be a problem if you have a dedicated winter set. They do seem to wear pretty well, though- I don't remember what the DOT date code is, but I've put on about 16k miles (probably 3/4 highway) in the year and a half or so I've owned it, and I can't really see a huge difference in tread depth. I haven't done any rotations, and the back left likes to leak down to about 20 psi over a couple weeks' time, so it's not like I've been particularly kind to them. Link to comment Share on other sites More sharing options...
DrD123 Posted November 7, 2018 Share Posted November 7, 2018 Do you like them? I usually am a strong pirelli fan but I was leaning toward the Yokohama avid ascend gt this next time. I drive 80% highway miles on flat road. I was looking for something with a smooth quiet ride to it.I do like them - I don't have a whole lot of experience with them in snow (we really don't get much), but for the snow covered road conditions we have gotten, they have been fine. wet and dry traction is really good. The recent tire rack review was very favorable, as well as the consumer reports review. Looking at the reviews on tire rack, a number of folks had the same 25k life as me - hopefully the new compound improves that. (25k miles and almost at the wear bars compared to the OEM summer tires which after 20k miles still had 7/32 left) Link to comment Share on other sites More sharing options...
Rittmeister Posted November 7, 2018 Share Posted November 7, 2018 H&Rs, Konis, and KYBs arriving in the next few days... OEM 2013 wheels at the refinisher... complete makeover will ensue in the coming weeks. Link to comment Share on other sites More sharing options...
swells Posted November 7, 2018 Share Posted November 7, 2018 (edited) I have ran the Yokohama Avid Ascend tires for about 6K and they ride very nice. I just did my first rotation and rebalance at Discount Tire and very little wear. They look like new still. I also run them on my Toyota Avalon. I am very happy with them Edited November 7, 2018 by swells Spelling Link to comment Share on other sites More sharing options...
spb Posted November 8, 2018 Share Posted November 8, 2018 Subaru part# 37255AJ000. You know what I mean? Link to comment Share on other sites More sharing options...
cww516 Posted November 8, 2018 Share Posted November 8, 2018 You'll kick yourself for waiting this long, so don't let it sit in your shelf any longer than you have to. Link to comment Share on other sites More sharing options...
sanhozay Posted November 8, 2018 Share Posted November 8, 2018 Does anybody know if this Intake thingy from Wangan will fit on my 2014 2.5i fb25? https://www.wangan-spl.co.jp/products/detail.php?product_id=462 I found this on google, it looks like it attaches to the stock box https://cdn.snsimg.carview.co.jp/minkara/parts/000/007/946/764/7946764/p2.jpg?ct=9f6b9ee45678 Link to comment Share on other sites More sharing options...
Perscitus Posted November 9, 2018 Share Posted November 9, 2018 The airbox milk jug / intake resonance chamber is different between the 5th gens and current WRX/Levorg... so if this thing is designed for those, it will not mate cleanly. Look for the no longer made HKS funnel. That is PnP but a. hard to find now b. fairly pointless just like this thing. The intake resonance chamber is on there for a reason, leave it on. Just as you should leave the stock intake on, stock paper filter (or worse case Cosworth or AEM dryflow or Amsoil nanfiber dropins). If you remove the resonator, expect MAF transfer function instability, MAF spikes, calced Load errors, idle issues, idle fuel trim issues, tip-in/out issues, but hey if the extra noise is worth it - go for it! Link to comment Share on other sites More sharing options...
Falcor Posted November 9, 2018 Share Posted November 9, 2018 You'll kick yourself for waiting this long, so don't let it sit in your shelf any longer than you have to. Same here. Mine is sitting waiting to be installed. It will be a few weeks since we are leaving on vacation tomorrow. Link to comment Share on other sites More sharing options...
