ashwinearl Posted November 13, 2019 Share Posted November 13, 2019 My mechanic was replacing the PCV valve assembly and every hose they touched was disintegrating. When I tapped into a boost line for my boost gauge, it was porcelain. Since it is already at the shop partially apart, we're going to replace the worn out pieces. Some are basic vacuum hoses, some are specific pieces with defined bends in them. Is there a good place for diagrams for ordering the OEM pieces I might need? I am at the Opposed Forces page right now. Does anyone make 2005 Legacy GT specific kits anymore? Thanks. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 13, 2019 Share Posted November 13, 2019 I'm going to guess your better off just going to the auto parts store and X number of feet of a few different size vacuum hoses. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 15, 2019 Share Posted November 15, 2019 BestbuySubaru.com Pictures can be difficult to decipher sometimes but they will have all of the diagrams. Link to comment Share on other sites More sharing options...
bluesuby Posted November 15, 2019 Share Posted November 15, 2019 I initially bought a PCV valve for my 2005 LGT wagon, but after reading warnings regarding what a pain it is to attempt replacement of just the PCV, I bought Subaru part 11815AB790 "Hose Assy-PCV" which includes all the hoses etc, even the required clamps. Link to comment Share on other sites More sharing options...
ashwinearl Posted November 16, 2019 Author Share Posted November 16, 2019 I've just been going through diagrams and past posts. Here are things that came up for reference: This is a good post on hoses near the PCV This was an old post on a group buy for some Venair Ancillary Hoses and it lists OE part numbers of hoses that it replaced. 99071AC020 11861AA030 99071AC260 99071AC320 99071AC670 807403542 99071AC720 11861AA030 99071AC240 99071AC010 99071AD100 99071AC230 11852AA090 99071AC220 This was from a NASIOC post I think of a WRX owner that replaced his hoses: "General Silicon Hose tubing - order from http://www.siliconhose.com 13mm x 8 feet 6mm x 6 feet 4mm x 8 feet Heater Hose: 0.31"" x 8 Feet" also there is a Vibrant Silicon Vacuum Hose kit from http://www.fastwrx.com. When I set my vehicle as a 2005 Legacy GT the web page says that it fits on a 2005 Legacy GT 5 ft. of 1/8" (3.2mm) I.D. hose 10 ft. of 5/32" (3.75mm) I.D. hose 4 ft. of 3/16" (4.5mm) I.D. hose 4 ft. of 1/4" (6mm) I.D. hose 2 ft. of 3/8" (10mm) I.D. vacuum hose 1 Link to comment Share on other sites More sharing options...
Nonamedude Posted November 16, 2019 Share Posted November 16, 2019 I think you've found what you need. From what I could find silicone is better for vacuum and not as ideal for fluids. Lots of debate there. I went with oe hoses. It was a pain deciphering all the diagrams. Get an idea and then just go talk to your local parts guy. Ask them for 20% off or something cuz such a big order. A bunch of them would need to be ordered in as well. The only one I had issue with was the 5/8" breather hose to the aftermarket turbo inlet. Just a bit too short. So that got whatever the auto parts store had. Which was stiff and thick and obnoxious but it works. Turbo smart sells long lengths of silicone hose. I also used the mishimoto catch can kit for $8 for my pcv to turbo inlet. AFAIK no one makes a full hose kit anymore except maybe these people in Britain and it's special order. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
big ears Posted November 16, 2019 Share Posted November 16, 2019 I ordered my replacement hose in bulk from boostcontroller.com purchased by the foot, different diameters and they shipped very quickly from East to West coats. Link to comment Share on other sites More sharing options...
