cobar.alex Posted August 17, 2018 Share Posted August 17, 2018 Hey guys, I have a 2005 Subaru Outback XT. The original engine is toast (EJ255) so I decided to get a used engine in working condition. The only one I could find at a reasonable price was the JDM EJ20x. I was told that that it would work perfectly even though it is "slightly" different. I got the car back from the mechanic 2 days ago and itis running smooth the thing is that the car is a lot slower. I really don't know much about cars that's why I'm here. My question is: Is it normal that the car is slower? Do I need to do I tune to the car to bring it back to normal? What is the difference between the two engines? What is the difference HP between the two engines? I know that's a lot of questions, I really appreciate you guys taking the time. Link to comment Share on other sites More sharing options...
choover1101 Posted August 17, 2018 Share Posted August 17, 2018 2.5 liter to 2.0 liter. You lost 20% of your motor capacity. I could see a considerable change in power level. Sent from my SAMSUNG-SM-N910A using Tapatalk Link to comment Share on other sites More sharing options...
utc_pyro Posted August 17, 2018 Share Posted August 17, 2018 The tuneing required for that motor vs the stock one is completely different. Compression ratio is a lot higher, so it’s likely knocking like crazy. It’s probably stuck with an IAM of “0” trying not to blow it up. OP: you need to get your car protuned NOW. Link to comment Share on other sites More sharing options...
