Jolbaru_LGT Posted March 9, 2021 Share Posted March 9, 2021 Hi, so my brother(PO) mentioned he previously upgraded the rear sway to a Subaru JDM 19mm. I’ll confirm it with a caliper tomorrow, but I’m wondering where to find replacement poly bushings? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 9, 2021 Share Posted March 9, 2021 https://www.google.com/search?q=Subaru+JDM+19mm&rlz=1C1OKWM_enUS906US906&oq=Subaru+JDM+19mm&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8 I just asked google for you. Got that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pleides Posted March 10, 2021 Share Posted March 10, 2021 I used Energy bushings for my front sway bar bushings. I'm sure they're available for the rear. Link to comment Share on other sites More sharing options...
whitetiger Posted March 10, 2021 Share Posted March 10, 2021 https://www.energysuspensionparts.com/9.5156 -with grease fittings. make sure the bushing brackets are in the size range the of the studs on the car. i picked this part# from memory. verify before purchase. Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted March 10, 2021 Author Share Posted March 10, 2021 Greaseable? With zerk fittings? I’ve never heard of bushings having that. Do I want that? Link to comment Share on other sites More sharing options...
Pleides Posted March 10, 2021 Share Posted March 10, 2021 Polyurethane needs to be greased at least biannually to not squeak. The zerk fitting isn’t anything to worry about. You can grease it with the bushings as well. Link to comment Share on other sites More sharing options...
