robburns201 Posted September 13, 2017 Share Posted September 13, 2017 Will a MBC OR EBC stop over boosting...I'm on a ots stg 2 tune and getting 18+ lbs and should be 16.5 at the highest... Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
robburns201 Posted September 13, 2017 Author Share Posted September 13, 2017 Sorry if it's a dumb Azz question but I'm trying to lean my lesson and ask b4 I buy Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Phate Posted September 14, 2017 Share Posted September 14, 2017 The car comes from the factory with electronic boost control. If you're overboosting, make sure the vacuum lines are connected properly, and that the restrictor pill is present. Also, are you on an OEM turbo or a chinacharger knockoff. I only ask because I had the same problems when I was running the chinacharger that my car came with. No matter how much I messed with it I couldn't get the boost control to behave because the wastegate actuator was basically just wrong. Everything was totally fine after I put a used OEM turbo on. Link to comment Share on other sites More sharing options...
robburns201 Posted September 14, 2017 Author Share Posted September 14, 2017 Oem turbo...I just got stage 2 so I'm thinking on getting the lwg Cobb 2 tune or just a mbc to just keep me at the proper boost till I can get a proper tune....so I can be proper..lol Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
robburns201 Posted September 14, 2017 Author Share Posted September 14, 2017 The car comes from the factory with electronic boost control. If you're overboosting, make sure the vacuum lines are connected properly, and that the restrictor pill is present. Also, are you on an OEM turbo or a chinacharger knockoff. I only ask because I had the same problems when I was running the chinacharger that my car came with. No matter how much I messed with it I couldn't get the boost control to behave because the wastegate actuator was basically just wrong. Everything was totally fine after I put a used OEM turbo on.I will check...thanks...I don't know that could cause over boost Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted September 14, 2017 Share Posted September 14, 2017 Your in CT, you need to meet up with Mike Kinsman of http://www.tuningalliance.com and have him do a street tune. He's just off exit 65 on Rt84. Trust me, you really want to take advantage of his talent. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robburns201 Posted September 14, 2017 Author Share Posted September 14, 2017 Thanks Max! And i am deff. going to get a tune there... I just dont want to much over boost as i have to take care of a few things first b4 i get a tune...like my gas tank replacement...so that's my reason for wanting to know this...If i can keep it at safe levels till i can get to him then i'm happy... Link to comment Share on other sites More sharing options...
Max Capacity Posted September 14, 2017 Share Posted September 14, 2017 Mike replies to emails if you need help to answer that question. Different topic but I'm have him ordering me long rubber exhaust hangers so the Q300 quad tip mufflers don't melt the Spec B rear bumper. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
