Scooby2.5 Posted November 21, 2010 Share Posted November 21, 2010 Updated Build info, picking up car from Cobb Plano Aug 28th with new motor and tune. Car right at 250K Updated Tune Aug 2015 http://legacygt.com/forums/attachment.php?attachmentid=216324&d=1442069821 August 2011 http://accessecu.com/dyno/graph.php?gb=0&hp=1&torque=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=2785&rgb1=000000255&runid2=2784&rgb2=204000000 http://legacygt.com/forums/attachment.php?attachmentid=148506&d=1365970937 http://legacygt.com/forums/attachment.php?attachmentid=148518&d=1365974548 Car: 2005 Outback XT Tuner: Calvin Dotson Cobb Tuning Plano TX Dyno Info: Mustang Temp: OLD-55-65F New-65-70 Sea Level: Aprox 1000 FT Fuel: E85 105 octane/ 93 Octane PowerTrain: Tuned by Calvin Dotson Cobb Tuning Plano TX Cobb Ver 2 AP w Access Tuner Race 350 whp (E85) TMIC 385 whp (E85) FMIC 373 wtq (E85) TMIC 423 wtq (E85) FMIC 304 whp (93) TMIC 350 whp (93) FMIC 317 wtq (93) TMIC 360 wtq (93) FMIC AVO380 (Garrett 2871r) AVO Wastegate Actuator Cobb Turbo Heat Shield Turbo Blanket Prodrive EBCS AVO FMIC Cobb XLE BOV AVO BOV Hose AVO Throttle Body Hose Cobb Cold Air Intake Perrin Turbo Inlet Aeromotive Stealth 340 LPH Fuel Pump Aeromotive Fuel Pressure Regulator Aeromotive Oil filled Fuel Gauge 07 STI Fuel Pump Control Module ID 1000cc Top Feed Injectors and Conversion (Bosch) Custom Fuel Lines Cobb Catted DownPipe DEI Wrapped Cobb Catback LegacyGT 3" Exhaust Grimmspeed UP DEI Wrapped Grimmspeed Ported Exhaust Manifolds Grimmspeed High Flow Crossover DEI Wrapped Crawford V2 AOS Cobb Lightweight Crank Pulley Gates Racing Blue Timing Belt Grimmspeed Radiator Shroud Koyo Racing Aluminum Radiator VH2778 Samco Radiator Hoses Braille B3121 Light Weight Battery Motul Xcess 5w 40 Synthetic Cobb Stage 2 Motor- Cobb/Watt Built: 07 STI Block, 07 STI Forged Crank, Manley Platinum 2618 Forged Pistons Manley Turbo Tuff H-Beam Rods, STI 11mm Oil Pump, Killer B P/U Tube STI bearings, ARP Rod and Head bolts Grimmspeed TGV Deletes DriveTrain: 08 STI 6 Speed DCCDPro DCCD Controller 08 STI DCCD Switches 07 STI R180 Torsen 08 Spec B Rear Axels Spec B Driveshaft STI Spec B Short Throw Shifter COBB Short Throw Shifter Lever STI Shifter Bushings STI Group N Tranny Mount STI Group N Motor Mounts STI Pressure Plate STI Clutch 08 STI Flywheel Subaru Extra-S gear oil F&R Suspension: Cobb Rear Sway Bar Cobb Front Sway Bar Cobb Sway Bar Bushings F/R Kartboy Endlinks F/R Racecomp Tarmac 1 Coilers Subtle Solutions 1" lift spacers Brakes: Stoptech ST40 BBK LGT Rear Brake Calipers Stop tech Street Performance Pads Stop tech 2 piece rotors Aluminum hats Centric Rear rotors Stop tech SS Brake Lines Motul RB600 Fluid Audio: 2007 Spec B Radio MP3, Aux Input, Satellite Control 2007 Spec B Console Cubby Aux input for Iphone Subaru Sirius Satellite Radio Module Subaru Factory under seat Sub Woofer X2 Interior: STI Pedals STI 3 Gauge Pack in Cubby STI Front Seats 05 STI Alcantara in Rear Seats Cobb Shift Knob Spec b shift surround plate STI badge Redline Leather shift boot Redline Leather brake lever boot STI DCCD Controls Auto dimming Homelink Mirror Innovate LC-1 Wideband VBG1 v1.05 AFR and Boost Gauge Passport X50 Exterior: Window Tint Front 35% Rear 20% Volt HID Kit with DRL Disabled Toshiba HIR High Beams STI Badge JDM Outback Bumper with Exhaust Cutouts Legacy GT Rear Bumper Beam Michelin Pilot Super Sport Summer Tires 2011 18" STI Enkei Wheels 5x100 to 5x114 15mm Adaptec Speedware/Motorsport-Tech Adapters Winter Setup: 17" Rota wheels and Blizzack tires 5x100 225x55x17 Link to comment Share on other sites More sharing options...
Drift Motion Posted November 21, 2010 Share Posted November 21, 2010 me like bbk... Link to comment Share on other sites More sharing options...
spec.B Dream Posted November 21, 2010 Share Posted November 21, 2010 I love this car. It was great to meet you last weekend. Link to comment Share on other sites More sharing options...
PlaxPhoto Posted November 22, 2010 Share Posted November 22, 2010 Holy f I wanna ride to see how this outback handles! Link to comment Share on other sites More sharing options...
chutrain Posted November 22, 2010 Share Posted November 22, 2010 I would take off the STi badge and powdercoat the exhaust tips black. Maybe put on a baby on board sticker and have the ultimate grocery getting sleeper. Link to comment Share on other sites More sharing options...
brilliant sleeper Posted November 22, 2010 Share Posted November 22, 2010 SICK! Haven't seen an '05+ Outback XT with this much done to it. Great sleeper! Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 22, 2010 Author Share Posted November 22, 2010 Thanks Guys, taken me going on 5.5 years and 141,000 miles to get this far doing a little bit here and a little bit there but it has turned out pretty well I think. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 22, 2010 Author Share Posted November 22, 2010 SICK! Haven't seen an '05+ Outback XT with this much done to it. Great sleeper! I need your user name! Link to comment Share on other sites More sharing options...
simple Posted November 24, 2010 Share Posted November 24, 2010 Greg, wow I had no idea you were putting that much work into the OB XT! Aside from the color, I would want everything you've done for my car. Too bad I spend my $$ on other habits. Next step, shave the roof! You don't need that roof rack do you? Awesome car. Has the car been trouble free on all those 141,000 miles? It looks better than new! Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 25, 2010 Author Share Posted November 25, 2010 Pretty much trouble free, I had a bad wheel sensor once in the winter it was packed with snow. I replaced the turbo at 112,000 BEFORE it would have likely failed. I also had a throw out bearing starting to make noise as it was going bad. So thats when I replaced the clutch. Word to the wise here, if your TO bearing starts making noise in the cold weather or otherwise, get it replaced ASAP, as it will damage the tranny snout if you don't. As soon as mine made noise I yanked the transmission. Other than that not really any other problems. I do use the rack once in a while so really need it to stay..... Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 25, 2010 Share Posted November 25, 2010 Very nice! Clean and sleeper= awesome Link to comment Share on other sites More sharing options...
john_knoxville Posted November 25, 2010 Share Posted November 25, 2010 curious how much was spent since new? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 26, 2010 Author Share Posted November 26, 2010 ^ Ive never totaled it up , I dont think I want to know. Its been spread out over 6.5 years if thats any consolation. I will say this, almost everything on this car was purchased used, or a great deal from a vendor, or Subaru Bucks from using my credit card with work. My last car a 1997 Jeep Cherokee that was lifted and modded out had 175,000 on it when I sold it on ebay for 9000. I put that as a big down payment on the Outback when I purchased it. Its been fun, and I do plan on keeping it for quite some time. Link to comment Share on other sites More sharing options...
doccrowley Posted November 26, 2010 Share Posted November 26, 2010 Hey, which Rotella oil are you using? 5-40 or really 15-40? Sweet wagon by the way. Very clean and seems like a complete build. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 26, 2010 Author Share Posted November 26, 2010 Oops its 5w-40 T6 Link to comment Share on other sites More sharing options...
Hops Posted November 30, 2010 Share Posted November 30, 2010 Sickest Outback ever... Perfect sleeper! Buy my cars! Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 30, 2010 Author Share Posted November 30, 2010 Thanks man, did you ever pull the trigger on any STI seats? Link to comment Share on other sites More sharing options...
Hops Posted November 30, 2010 Share Posted November 30, 2010 Going to hold off a bit... Got two big projects ahead of me! Took a break from building the wife's wagon to build my car, then I scored a deal on a dyno with Christian from Cobb so now I'm building both! STi seats are still in my future. Buy my cars! Link to comment Share on other sites More sharing options...
OutbackXT05 Posted November 30, 2010 Share Posted November 30, 2010 Very clean outback you have going there. Definently a sleeper. I want that rear bumper if i could ever find one cheap, but i doubt it Link to comment Share on other sites More sharing options...
ssbtech Posted November 30, 2010 Share Posted November 30, 2010 Wonderful job, I wish I had the time, money and space to do that. How does the BC/BR suspension ride? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted December 1, 2010 Author Share Posted December 1, 2010 BC/BR's ride really well. I run them right in the middle settings most of the time. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted December 1, 2010 Author Share Posted December 1, 2010 Very clean outback you have going there. Definently a sleeper. I want that rear bumper if i could ever find one cheap, but i doubt it japanparts.com My Install Write Up http://legacygt.com/forums/showthread.php/jdm-outback-bumper-install-69935.html?t=69935 Its went up a few hundred dollars since I bought it. Plus I got a discount from the OLD prices listed being a LGT member. Link to comment Share on other sites More sharing options...
pnmid Posted March 5, 2011 Share Posted March 5, 2011 Yours is really the nicest Outback I've seen. If I were to buy a 2010 Outback, I'd do what you've done to a 3.6R. Link to comment Share on other sites More sharing options...
boost4life Posted March 5, 2011 Share Posted March 5, 2011 Very nice man! Link to comment Share on other sites More sharing options...
Scooby2.5 Posted March 13, 2011 Author Share Posted March 13, 2011 Thanks again everyone for the compliments. Ill be putting the matching Blue Alcantara in the factory back seat cover soon. I am going to take the stock rear seat covers off and my wife is going to sew the Alcantara in where we take the tweed out. Ill post pics as soon as I get it done. Link to comment Share on other sites More sharing options...
