Syzygy05 Posted May 2, 2021 Share Posted May 2, 2021 This is a pedantic question, but does it matter for an AWD car as long as it it done at set intervals? Link to comment Share on other sites More sharing options...
ammcinnis Posted May 2, 2021 Share Posted May 2, 2021 As long as you consistently use the same pattern you're OK. You just need to cycle each tire through each position. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
waldguy Posted May 3, 2021 Share Posted May 3, 2021 Yup, do either, but the same thing all time. BTW, a front to back is not sufficient. I did that a couple times before I bought an extra stand set. One tire ended up wearing a bit more than all the others. I started doing the cross pattern and all tires evened up. Link to comment Share on other sites More sharing options...
XT-sub Posted May 5, 2021 Share Posted May 5, 2021 (edited) This is a pedantic question, but does it matter for an AWD car as long as it it done at set intervals? It depends if the tyres are unidirectional or non-unidirectional. The original tyres are non-unidirectional (i.e. no specific rotational direction). The below 11-28 & 11-29 from the 2019 US Outback & Legacy Owner’s Manual shows the difference. 2019_Outback_&_Legacy_Owners-Manual_11.28.pdf 2019_Outback_&_Legacy_Owners-Manual_11.29.pdf Edit: Of course this is in addition to what ammcinnis posted. Edited May 5, 2021 by XT-sub Link to comment Share on other sites More sharing options...
