2005 Outback 2.5 Engine Diagnostic Help
We purchased a 2005 Subaru Outback Automatic from a neighbor. We noticed it sitting parked for the last year or so. It's in great condition but the owner said it started running terrible, coming over the pass, so they drove it home and parked it. We got it for $400. All I have done is drag it home and pull the covers to check the timing belt. It is in terrible condition but the 3 marks on the camshaft pulleys and crankshaft pulley are all pointing at the 12 o'clock position. Is it possible the oil pump went out? I can still turn the engine, I did it to align the timing marks. Any recommendations on where to start? Put it back together and start it? New timing belt first? Thank you.
The battery is dead, will it store the codes? We are going to put a new timing belt on it, drain the oil, check for metal shavings, put it back together, charge the battery and check for codes.
Sent from my moto g(7) optimo (XT1952DL) using Tapatalk
http://people.csail.mit.edu/ilh/vacation/
You might enjoy the service manual.
You might want the drain the oil and check for metal first, before doing the timing belt...
Engine Build - Click Here
  • 3 weeks later...
They do. I found a video on YouTube that talks about chunks of steel foil in the oil pan of a Subaru. It was a rod bearing. The people that sold us the car said it ran but was noisy. So now we know why.
