05LGTL25TSLEEPER Posted March 2, 2019 Share Posted March 2, 2019 (edited) I'm going to start by listing what I have ready, and I'll add more as I work on stripping it. I will ship quickly when a part is sold, and I will try to check the thread and my PMs as much as possible. All parts do not include shipping unless specified. VIN: 4S3BL676854202856 CURRENTLY AVAILABLE: ECU Module w\ Cobb Access Port V2 (Married, OBD2 wire doesn't fully clip in, still works fine) - $275 *SOLD* 5EAT - Level 10 complete service package including Torque Converter \ Valve Body \ Front Diff - ZERO miles - $4000 *SOLD* Rear Differential 115k miles (R160 VCD) - $250 EJ255 OEM Crank - Around 10k miles. (Not coated) - $100 EJ255 OEM Pistons - Around 10k miles. - $100 EJ255 OEM Connecting Rods - Around 10k miles - $120 Cylinder Heads B25 (Assembled \ Around 10k Miles \ Cams Included) - $1100 Adjuster Assembly - Tensioner OEM 13033AA000 (Less than 10k miles) - $50 SOLD Invidia Downpipe (Catless, Divorced) - $130 *SOLD* Invidia Up Pipe (Catless) - $80 *SOLD* ARP Head Studs (Used Once May be missing a few nuts) - $100 SOLD Throttle Body OEM (Coated w\ Enamel, Blue 115k Miles) - $80 Power Steering Pump OEM (NEW Coated w\ Enamel, Blue) - $250 *SOLD* STi Intake Manifold OEM (NEW) - $280 SOLD STi Oil Pump OEM (NEW) - $140 SOLD Mishimoto Oil Cooling System 19 Row w\ lines, adapter & housing (Around 10k Miles) - $190 *SOLD* Oil Pressure Switch OE (NEW) - $8 Injector Dynamics ID 1000cc Top Feed Fuel Rails & Injectors (Less than 10k miles) - $450 *SOLD* DW 65c Fuel Pump (Less than 10k miles) - $70 *SOLD* AEM Wideband Gauge & Sensor (Less than 10k miles) - $140 *SOLD* AEM Oil Pressure Gauge Kit *BRAND NEW* - $170 *SOLD* Aeromotive Fuel Pressure Regulator *NEW* - $150 *SOLD* Auto Meter Mounting Cup NEW - $12 Grimmspeed EBCS (Less than 10k Miles)- $75 *SOLD* Main Wiring Harness (OEM 115k Miles) - $50 Fuse Box - $15 K&N Typhoon Cold Air Intake (Less than 10K Miles) - $130 SOLD Perrin Turbo Inlet Hose (Less than 10k miles) - $90 *SOLD* Perrin Motor Mounts (Around 10k miles) - $190 AVO Throttle Body Hose - $30 EJ255 Starter OEM (115k miles, works fine) - $60 EJ255 Coils (Set of 4 OEM Less than 10K miles) - $200 *SOLD* Nations High Output Alternator 270A (NEW NEVER INSTALLED) - $450 SOLD Gates Water Pump w\ Tensioner & Idler Pulleys (Less than 10k miles) - $120 Turbo Heat Shield (Upper) - $30 Killer B Oil Pan Package (Pan\Pickup\Baffle) Less than 10k Miles (A few scuffs on pan) - $450 *SOLD* Whiteline Adjustable Front Endlinks Installed, Never Driven -$50 Rear Differential Carrier Mount (NEW w\Whiteline Bushings & Bolts) - $120 SOLD Rallitek Front Skid Plate (Some scratches \ Around 10k Miles)- $150 (Local Pickup Only) Enkei Wheels (SR6 17x7.5" +45 w\ Michelin Pilot SS 225/45ZR17 Tires Around 12k Miles \ Good Tread left on tires!) LOCAL ONLY - $600 SOLD OEM Wheels w\ Continental Tires *LOCAL ONLY* - $200 Stoptech Braided SS Brake Lines *NEW* (Front) - $60 *SOLD* Stoptech Braided SS Brake Lines Rear (Less than 10k Miles) - $40 *SOLD* Upper Coolant Reservoir (Enamel Coated) OEM - $60 Intercooler, OEM (Works but crappy fin condition 100k Miles) - $25 Rear Subframe OEM w\ Whiteline Bushings (Less than 10k Miles) - $140 Brace, Cusco Part# 684 477 A (Enamel Coated\Never Installed) - $110 *SOLD* Brace, Cusco Part# CUSC-692 492M Enamel Coated\Never Installed -$190 *SOLD* Rallitek Polyurethane Tranny Insert NEW (Hard) - $35 SOLD Rallitek Polyurethane Tranny Insert NEW (Soft) - $35 *SOLD* Whiteline Bushings NEW - Front Control Arm W0506 - $30 *SOLD* Whiteline Bushings NEW - Control Arm, Rear Upper, Inner W63396 - $25 *SOLD* Whiteline Bushings NEW - Control Arm, Rear Lower, Inner W53353 - $70 Whiteline Front Strut Tower Brace (Installed, never driven) - $90 *SOLD* Cusco Rear Strut Tower Bar Type ALC OS (Installed, never driven) - $140 Cusco Power Steering Rack Brace (Installed, Never Driven) - $35 *SOLD* Spec B Front Control Arms w\ PSRS bushings (Less than 10k miles) - $450 \ Pair *SOLD* Spec B Trailing Arms w\Whiteline Bushings (Less than 10k miles) - $600 \Pair *SOLD* Spec B Lateral Links (Less than 10k miles) - $100 \ Pair *SOLD* Cusco Front Control Arm Mounting Brackets (Less than 10k miles) - $50 \ Pair *SOLD* Whiteline Rear Control Arm Set (Less than 10k miles) - $300 *SOLD* Kartboy Rear End Links (Less than 10k miles) - $50 *SOLD* AVO Rear Underbody Braces - $100 *SOLD* Perrin Pitch Stop Mount - $55 *SOLD* Perrin Crank Pulley (Less than 10k miles) - $45 *SOLD* Perrin Front Sway Bar 25mm (Less than 10k miles) - $100 *SOLD* AVO Rear Sway Bar (Less than 10k miles) - $90 Tein H Tech Lowering Springs Installed, Never Driven - $90 (LOCAL ONLY) *SOLD* Group N Tophats (Installed, Never Driven) - $50 *SOLD* Brake Calipers OEM (Front) Good Working Condition Less than 5k miles - $80 Brake Calipers OEM (Rear) - $50 *SOLD* Parking Brake Kit (Brand New) - $25 Brake Master Cylinder OEM (115k Miles) - $40 Radiator (115k miles OEM) - $60 Axles (115k Miles) - $80 Driveshaft (115k Miles) - $50 Steering Knuckles OEM (Less than 10k miles) - $90 \ Pair *SOLD* Power Steering Rack (Zero Miles Installed) - $90 *SOLD* Front Grill OEM - $70 SOLD Side Skirts - $80 Steering Wheel - $90 *SOLD* Sideview Mirrors - $50 ea. Airbags - Driver & Passenger Side - $80 Each Front Seats (Local only) - $250 SOLD Rear Seat (Local Only) - $200 SOLD Window Control Module (Front Driver's) - $60 *PENDING SALE* Window Control Module (Front Passenger) - $30 Window Control Module (Rear Both Sides) - $20 Speaker Set OEM (Front \ Back \ Tweeters) - $90 Rear Cup Holder - $40 ______________________________________________ BRACKETS & LINES Radiator Stays (New Inserts \ Enamel Coated, Blue) - $15 *SOLD* Upper Radiator Bracket (Enamel Coated, Blue) - $12 AVO Sway Bar Reinforcement Bracket - $80 *SOLD* Intercooler Bracket OEM (Enamel Coated, Blue) - $30 Idler Pulley Assembly OEM (Enamel Coated, Blue w\ New Pulley) - $35 SOLD Turbo Bracket (Enamel Coated, Blue) - $15 Turbo Heat Shield Bracket Upper (Enamel Coated, Blue) - $15 EBCS Bracket (Enamel Coated, Blue) - $20 Collector Cover Bracket, Alternator (Enamel Coated, Blue) - $15 Battery Bracket (Enamel Coated, Red w\ bolts) - $10 Oil Line (Head) (Enamel Coated, Blue) - $10 Turbo Water Pipes (Enamel Coated, Blue) - $15 _______________________________ GASKETS (ALL NEW & OEM) Oil Seal, Rear Main Crank OEM 806786040 - $5 Oil Seal, Cams (Set of 4) OEM 806732160 - $12 Gasket, Rocker Cover (Set of 4) OEM 13293AA051 - $14 Gasket, Power Steering OEM 34621AC024 - $2.50 Gasket, DRAIN PLUG (Set of 2) OEM 11126AA040 - $4 Gasket, Water Pump OEM 21114AA051 - $3.50 Gasket, Grimmspeed 3" Downpipe - $10 *SOLD* Gasket, Grimmspeed Up Pipe To Turbo 24001 - $6 *SOLD* Gasket, Vibrant Performance 3" Downpipe VIB1458 - $4 Gasket Exhaust (Set of 2) OEM 44011AE01A - $7 Gasket, Exhaust Up Pipe To Manifold OEM 44022AA170 - $6 *SOLD* Gasket, Exhaust Turbo Downpipe OEM 44022AA180 - $11 *SOLD* Gasket, Exhaust Manifold OEM (Set of 2) 14038AA000 - $16 *SOLD* Gasket, Intake Manifold OEM (Set of 2) 14035AA421 - $7 Gasket, Intake Manifold OEM (Set of 4) 14035AA510 - $16 Gasket, Diff Carrier OEM 38353AA070 - $2.50 Bracket, Exhaust Pipe Hanger OEM 44201AG00A - $3 *SOLD* Perrin Exhaust Hanger ASM-EXT-100 - $6 Perrin T-bolt Clamp Upgrade Kit (FMIC) - $50 SOLD __________________________________________ PHOTOS AND MANY MORE PARTS TO FOLLOW WILL MAKE AVAILABLE SOON & MORE TO COME EJ255 Case Halves - Around 10k miles. Cleaned, honed and checked by machine shop (one Helicoil insert for motor mount). - $500 Timing Belt Cover (115k miles OEM) - $15 Glove Compartment Door - $40 Cubby w\ Mat - SOLD Hood Prop - $10 SOLD Rear Bumper - $80 Front Bumper - $75 Front Fenders - $130 SOLD Radio \ 6 Disc Changer - $140 SOLD Grimmspeed EBCS sold to Wooosh Gasket, Grimmspeed 3" Downpipe - sold to AWDFTW Gasket, Grimmspeed Up Pipe To Turbo 24001 - sold to AWDFTW Gasket, Exhaust Up Pipe To Manifold OEM 44022AA170 - sold to AWDFTW Gasket, Exhaust Turbo Downpipe OEM 44022AA180 - sold to AWDFTW Gasket, Exhaust Manifold OEM (Set of 2) 14038AA000 - sold to AWDFTW Rallitek Polyurithene Tranny Insert NEW (soft) - sold to AWDFTW Stoptech Braided SS Brake Lines sold to Scottydunno Perrin Turbo Inlet Hose sold to tysparks81 Perrin Pitch Stop sold to tysparks81 Kartboy End Links sold to tysparks81 Aeromotive Fuel Pressure Regulator sold to tysparks81 AEM Wideband A\F Gauge Kit sold to tysparks81 Injector Dynamics Fuel Line Kit sold to tysparks81 AVO Sway Bar Reinforcement Bracket sold to Chocoholic005 Radiator Stays (New Inserts \ Enamel Coated, Blue) sold to Chocoholic005 Power Steering Rack sold to Chocoholic005Steering Knuckles OEM sold to Chocoholic005AVO Rear Underbody Braces sold to Chocoholic005 Whiteline Rear Control Arm Set sold to Chocoholic005 Cusco Front Control Arm Mounting Brackets sold to Chocoholic005 Spec B Lateral Links sold to Chocoholic005 Spec B Trailing Arms w\Whiteline Bushings sold to Chocoholic005 Spec B Front Control Arms w\ PSRS bushings sold to Chocoholic005 Cusco Power Steering Rack Brace sold to Chocoholic005 Whiteline Bushings NEW - Control Arm, Rear Upper W63396 sold to Chocoholic005 Brace, Cusco Part# CUSC-692 492M Enamel Coated sold to Chocoholic005 Brace, Cusco Part# 684 477 A (Enamel Coated) sold to Chocoholic005 Killer B Oil Pan Package (Pan\Pickup\Baffle) sold to Chocoholic005 Edited November 14, 2020 by 05LGTL25TSLEEPER Added Parts Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 2, 2019 Author Share Posted March 2, 2019 (edited) Cobb AP V2, Gaskets, Crank, Pistons, Wrist Pins, ID 1000cc Injectors, Fuel Rails (Lines Sold), Nations High Output Alternator, STI Manifold, Wheels, K&N Intake, Intercooler Bracket, Idler Pulley Assembly, Turbo Bracket, Turbo Heat Shield Bracket, Oil Line, Turbo Water Pipes, 5EAT (Level 10), Torque Converter (Level 10). Edited March 20, 2019 by 05LGTL25TSLEEPER Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 2, 2019 Author Share Posted March 2, 2019 (edited) Cusco Underbody Braces, Throttle Body, AVO Throttle Body Hose, Upper Coolant Tank, Diff Carrier Mount, Rallitek Transmission Mount Inserts, Stoptech Brake Lines, Case Half (Better Photos coming), Connecting Rods, Heads, Perrin Turbo Inlet Hose, Starter, ARP Head Studs, Rallitek Skid Plate Edited March 9, 2019 by 05LGTL25TSLEEPER Adding Photos Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 3, 2019 Author Share Posted March 3, 2019 (edited) Killer B Package, Power Steering Pump, STI Oil Pump, Invidia Up & Downpipes, Mishimoto Oil Cooling Kit Edited March 9, 2019 by 05LGTL25TSLEEPER Adding Photos Link to comment Share on other sites More sharing options...
AWDFTW Posted March 3, 2019 Share Posted March 3, 2019 Gasket, Grimmspeed 3" Downpipe - $10 Gasket, Grimmspeed Up Pipe To Turbo 24001 - $6 Gasket, Exhaust Up Pipe To Manifold OEM 44022AA170 - $6 Gasket, Exhaust Turbo Downpipe OEM 44022AA180 - $11 Gasket, Exhaust Manifold OEM (Set of 2) 14038AA000 - $16 Rallitek Polyurithene Tranny Insert NEW (soft) - $35 Interested in these, depending on shipping to 37604. Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 3, 2019 Author Share Posted March 3, 2019 Gasket, Grimmspeed 3" Downpipe - $10 Gasket, Grimmspeed Up Pipe To Turbo 24001 - $6 Gasket, Exhaust Up Pipe To Manifold OEM 44022AA170 - $6 Gasket, Exhaust Turbo Downpipe OEM 44022AA180 - $11 Gasket, Exhaust Manifold OEM (Set of 2) 14038AA000 - $16 Rallitek Polyurithene Tranny Insert NEW (soft) - $35 Interested in these, depending on shipping to 37604. Shipping should be fairly inexpensive. I will PM you with the details. Thanks! Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 3, 2019 Author Share Posted March 3, 2019 Gasket, Grimmspeed 3" Downpipe - $10 Gasket, Grimmspeed Up Pipe To Turbo 24001 - $6 Gasket, Exhaust Up Pipe To Manifold OEM 44022AA170 - $6 Gasket, Exhaust Turbo Downpipe OEM 44022AA180 - $11 Gasket, Exhaust Manifold OEM (Set of 2) 14038AA000 - $16 Rallitek Polyurithene Tranny Insert NEW (soft) - $35 Interested in these, depending on shipping to 37604. I'm not 100% sure outgoing messages are getting through, but I can ship all of these for $5. If that works for you just PM me your info and I'll get you an invoice right away. Thanks! Link to comment Share on other sites More sharing options...
Infosecdad Posted March 3, 2019 Share Posted March 3, 2019 Do you have any pictures of the power steering pump? Power Steering Pump OEM (NEW Coated w\ Enamel, Blue) Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 3, 2019 Author Share Posted March 3, 2019 Do you have any pictures of the power steering pump? Power Steering Pump OEM (NEW Coated w\ Enamel, Blue) Getting some more photos going tomorrow, that will be included, thanks! Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 3, 2019 Author Share Posted March 3, 2019 (edited) AEM Gauges \ Coils \ Grimmspeed EBCS \ Oil Pressure Switch, Main Wiring Harness, Perrin T-bolt Clamp Kit, Perrin Crank Pulley, Whiteline Bushings Edited March 9, 2019 by 05LGTL25TSLEEPER Adding Photos Link to comment Share on other sites More sharing options...
Wooosh Posted March 3, 2019 Share Posted March 3, 2019 What’s the zip code for local pickup? May have a friend pick up the skid plate n ship it for me Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 3, 2019 Author Share Posted March 3, 2019 Zip code is 33811, Lakeland Florida. I just realized my location still says New York, sorry! I used to live on Long Island, but I moved to Florida. Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 3, 2019 Author Share Posted March 3, 2019 Do you have any pictures of the power steering pump? Power Steering Pump OEM (NEW Coated w\ Enamel, Blue) Photos of power steering pump posted! Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 4, 2019 Author Share Posted March 4, 2019 Just a reminder, please make initial inquiries for parts on the thread, as per the forum rules. Gotta drive between the lines, so to speak! Link to comment Share on other sites More sharing options...
LegacyMike98 Posted March 4, 2019 Share Posted March 4, 2019 Do the rear view mirrors have the turn signals on them? Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 4, 2019 Author Share Posted March 4, 2019 Do the rear view mirrors have the turn signals on them? Yessir, and plastidipped black. Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 4, 2019 Author Share Posted March 4, 2019 Got my hands on a low profile Motorcycle jack today with rubber pads, 5EAT is coming out one night this week. Link to comment Share on other sites More sharing options...
Dphil25gtwagon Posted March 4, 2019 Share Posted March 4, 2019 I got the PM. I will buy the AP, down pipe and up pipe for the price you had mentioned. Link to comment Share on other sites More sharing options...
Scottydunno Posted March 5, 2019 Share Posted March 5, 2019 Stoptech Braided SS Brake Lines (Less than 10k Miles) - $40 Price shipped to zip 02576??? Scotty 05 OBP LGT. Minor stuff done.. Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 5, 2019 Author Share Posted March 5, 2019 I got the PM. I will buy the AP, down pipe and up pipe for the price you had mentioned. Thanks for the message, Accessport, Invidia Downpipe, and Invidia Up pipe pending sale to Dphil25gtwagon! Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 5, 2019 Author Share Posted March 5, 2019 Stoptech Braided SS Brake Lines (Less than 10k Miles) - $40 Price shipped to zip 02576??? Scotty 05 OBP LGT. Minor stuff done.. Hey Scotty, I can get you those brake lines to MA for $5. Does that work for you? Link to comment Share on other sites More sharing options...
Scottydunno Posted March 5, 2019 Share Posted March 5, 2019 Hey Scotty, I can get you those brake lines to MA for $5. Does that work for you?Yup! Paypal? Scotty 05 OBP LGT. Minor stuff done.. Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 5, 2019 Author Share Posted March 5, 2019 (edited) Gettin that transmission out tonight, then starting on the suspension. I hate seeing her this way knowing everything is coming out rather than going in this time...I will miss this car so much Edited March 6, 2019 by 05LGTL25TSLEEPER Adding Photos Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 5, 2019 Author Share Posted March 5, 2019 Yup! Paypal? Scotty 05 OBP LGT. Minor stuff done.. PM sent. Link to comment Share on other sites More sharing options...
05LGTL25TSLEEPER Posted March 5, 2019 Author Share Posted March 5, 2019 Photos of Downpipe and Up pipe added. Link to comment Share on other sites More sharing options...
