Cruisemobile2 Posted January 9, 2018 Author Share Posted January 9, 2018 how did the front lip fit and have you driven in the snow yet with your lowered setup? looks perfect Front lip was pretty easy. Just need to trim about 2.5-3 inches off at each end. At this point, I have gone through 3 lips haha. Yes, driven offroad in dirt and snow. Does just fine. Only reason why I went through 3 lips is because of little animals crossing the road or road debris Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 9, 2018 Author Share Posted January 9, 2018 Here was the first pic taken when I got the car back from Infamous Performance. Mike Sprankles did an amazing job putting engine together. http://i65.tinypic.com/x3x28i.jpg Some of the old stuff http://i68.tinypic.com/162yhj.jpg Here are the specs of the new build: Outfront Motorsports Refreshed Block and Heads CP Forged Pistons TGV Deletes ARP Head Studs King Racing Bearings LIC Motorsports Aluminum Cam Seals 08 STi Oil Pump (11mm Pump) JDM Cast Impeller Water Pump Cobb Uppipe Group N Motor Mounts New OEM VF40 Turbo New OEM Throttle body Every vacuum line and rubber hose was replaced Wanted to keep things reliable for daily use so nothing crazy here but she sure is perky than before! Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 10, 2018 Author Share Posted January 10, 2018 (edited) Next few pics of her being put to use after the rebuild and break-in http://i66.tinypic.com/m8l3dt.jpg http://i66.tinypic.com/1110djp.jpg http://i65.tinypic.com/11cce4p.jpg http://i64.tinypic.com/5cf4p5.jpg http://i68.tinypic.com/w8u9n7.jpg http://i67.tinypic.com/2ikm6v.jpg This was out at a camping trip back in 2014. Don't mind the front lip hanging lose.....a squirrel came out of nowhere when drifting around a few bushes out there and hit him. The little guy was ok though and carried on. Edited January 10, 2018 by Cruisemobile2 Adding info Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 10, 2018 Author Share Posted January 10, 2018 (edited) http://i67.tinypic.com/vhywps.jpg http://i65.tinypic.com/3496nhh.jpg and when we hit 250k on the chassis http://i63.tinypic.com/14nmsgp.jpg http://i67.tinypic.com/j8mh3o.jpg Edited January 10, 2018 by Cruisemobile2 Added photos Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 10, 2018 Author Share Posted January 10, 2018 A few months later and a couple thousand miles down the road....it was time to do more maintenance again. The original driveshaft gave out and I noticed the Megan rear lateral links started to bend! At the same time, my clutch started to go out so decided to swap that out as well. Also threw on a new set of tires! http://i66.tinypic.com/fxw39i.jpg List of junk in the trunk: New Toyo Proxes 4 Plus tires (235/40) Competition Clutch Stage 2 with brass back and 12lbs lightened flywheel Wholesale Import Parts rebuild-able driveshaft http://www.wholesaleimportparts.com Whiteline Anti-lift kit Whiteline front control arm bushings Whiteline lateral link kit ..tossed in a Perrin pitch stop mount cause it was on sale at rallysportdirect.com Also, please to announce that Whiteline also sponsored the build so super stoked about that! All work was done by AQ Motorsports in Torrance, CA Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 10, 2018 Author Share Posted January 10, 2018 Once back from AQ Motorsports, we went and got the car properly aligned. http://i66.tinypic.com/2qm12zc.jpg Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 24, 2018 Author Share Posted January 24, 2018 Next...it was on to the brakes! This is an area I hate the most about the OBXT...don't understand why they came with smaller brakes to begin with compared the lgt wagon....yet the OBXT weights about 200lbs more... This is what I end up with after only a few minutes of going in hot at a few corners at Adams Motorsports park... http://i67.tinypic.com/w7e77t.jpg Same Duralast rotors which i installed over 100k ago... I had switched out the pads about 4 times by then. Now, it was time to upgrade the brakes Front are Greddy 6 pot calipers with 2 piece Grex Rotors, Carbotech 1521 pads, and Brembo Stainless lines vs Stock http://i67.tinypic.com/9abgja.jpg Rear are STI Gold Brembo 2 pot calipers, stock Brembo Pads, Yimisport Brembo rear bracket, KNS shorten rear stainless brake lines, and DBA 4000 series adapter rotor vs Stock http://i64.tinypic.com/2eb5stl.jpg Just so people know, the Greddy 6 pot calipers are Rotora FC6 calipers. Rotora had some sort of collab with Trust/Greddy/Grex in Japan a few years ago to produce a limited set for the GD chassis. Less than a handful have ever made it over to the U.S. so these puppies are by far the rarest parts I have on the car. Before I installed them, I sent them to Wicked Auto Detailing in Costa Mesa to have them ceramic pro coated in order to preserve the finish as much as possible. Thanks again to @speedmasterlee for hooking me up with a nearly brand new set! BIG difference in braking and can now brake with confidence! Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 24, 2018 Author Share Posted January 24, 2018 Quick photo after the install of the brakes.. http://i63.tinypic.com/254vc5h.jpg Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 24, 2018 Share Posted January 24, 2018 Nice. Could you feel the added weight to each wheel with this new brake setup? Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted January 25, 2018 Author Share Posted January 25, 2018 Nice. Could you feel the added weight to each wheel with this new brake setup? Thanks! Honestly, you do feel up front a tadddddd bit more weight in the steering but nothing that would be of a concern or is over excessive. I can honestly yield that tiny bit of extra weight for better braking power. The upgraded system does stop on a dime and I no longer experience brake fade. The upgraded brake system vs to the stock system honestly was not that much heavier. I didn't get around to weighing them but the 6pot calipers vs the stock front calipers pretty much felt the same...same goes for the rear. Only the front and rear rotors were slightly heavier than stock but still, nothing major that would hamper performance Link to comment Share on other sites More sharing options...
lilredwagon Posted February 16, 2018 Share Posted February 16, 2018 So as far as the rear suspension, are you on the stock trailing arms? I ask because your rear tires don't look like they are pushed forward as much as other lowered Outbacks. Also, did you need to change to the LGT upper control arm/bumpstop, or do your coilovers have internal bumpstops? Thanks in advance! Your wagon looks great, I'm hoping mine will look as good when I get the suspension sorted! Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted February 21, 2018 Author Share Posted February 21, 2018 So as far as the rear suspension, are you on the stock trailing arms? I ask because your rear tires don't look like they are pushed forward as much as other lowered Outbacks. Also, did you need to change to the LGT upper control arm/bumpstop, or do your coilovers have internal bumpstops? Thanks in advance! Your wagon looks great, I'm hoping mine will look as good when I get the suspension sorted! Thank you! I am still using the stock trailing arms but I also have the whiteline bushings in them so i think that might have helped a little. I also removed my rear bumpstops so there is currently none in there. My BC Racing coilovers have internal bumpstops. I honestly have never maxed them out even with a full gear and 2 passengers in the back on long road trips to the mountains. Link to comment Share on other sites More sharing options...
lilredwagon Posted February 21, 2018 Share Posted February 21, 2018 Thanks for the response! This gives me something to think about because if I don't have to buy LGT upper control arms and bump stops, then that closes the gap in price between coilovers and a good strut/spring combo. Thanks! Link to comment Share on other sites More sharing options...
arsene Posted March 22, 2018 Share Posted March 22, 2018 Gotta say I love the build! By far the sexiest tire/wheel fitment I've seen. I'm gonna shoot for similar sizes on my Outback and was wondering what all you would suggest for accomplishing it. I know you mentioned you had to trim the fenders, but what else would you recommend? Link to comment Share on other sites More sharing options...
DadBod Posted May 12, 2018 Share Posted May 12, 2018 Been following you on insta for a while, this thread answers so many questions I had about your build! Great OBXT! Some good inspiration in there for mine. Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 14, 2018 Author Share Posted August 14, 2018 Gotta say I love the build! By far the sexiest tire/wheel fitment I've seen. I'm gonna shoot for similar sizes on my Outback and was wondering what all you would suggest for accomplishing it. I know you mentioned you had to trim the fenders, but what else would you recommend? Sorry, been off the forums the last few months If you're going low, definitely go for some coilovers (Feals, BC Racing, etc.). Also, be sure to change your later links in the rear. and get a good alignment Link to comment Share on other sites More sharing options...
arsene Posted August 15, 2018 Share Posted August 15, 2018 Sorry, been off the forums the last few months [emoji38] If you're going low, definitely go for some coilovers (Feals, BC Racing, etc.). Also, be sure to change your later links in the rear. and get a good alignment [emoji38]Thanks for the reply [emoji16] Went with BR extreme low and lateral links. Installed the lower ones myself but am having the uppers installed and having it aligned tomorrow. Most shops refused the work "because it's aftermarket" but the dealership is fine with it oddly. Might help that my friend works there. I've been following you on Instagram, keep up the amazing posts! Sent from my Pixel using Tapatalk Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 29, 2018 Author Share Posted August 29, 2018 Thanks for the reply [emoji16] Went with BR extreme low and lateral links. Installed the lower ones myself but am having the uppers installed and having it aligned tomorrow. Most shops refused the work "because it's aftermarket" but the dealership is fine with it oddly. Might help that my friend works there. I've been following you on Instagram, keep up the amazing posts! Sent from my Pixel using Tapatalk Thanks man! Hope you're digging the new suspension setup! It's looking good! Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 29, 2018 Author Share Posted August 29, 2018 Finally got around to upload more pics! Next on the build was upgrading the sway bars. Thanks to my sponsor Whiteline for sending me this care package. Front and Rear adjustable sway bars, Front and Rear adjustable endlinks, rear diff bushings, rear diff outrigger bushings, and positive gearbox bushings! http://i65.tinypic.com/14mf4a8.jpg Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 29, 2018 Author Share Posted August 29, 2018 Right before the install, I also picked up an Ultra Racing rear subframe brace. Since the Legacy/Outback rear subframe sway bar mounting points are notorious for bending or even breaking when going with a thicker sway bar....I figured I pick something up to be safe. I didn't like the AVO brackets and thought the Ultra Racing rear subframe brace was unique...they're pretty much the only company I know of that makes such a brace. http://i67.tinypic.com/4jq6ax.jpg It pretty much tie's up the rear end. Looks pretty aggressive back there now http://i65.tinypic.com/33xk1zo.jpg http://i66.tinypic.com/ie1qox.jpg Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 29, 2018 Author Share Posted August 29, 2018 After the suspension was done, I decided to pick work on the cooling a bit. Picked up a Koyorad Hyper V dual core radiator, pretty blue Samco hoses, and an aluminum expansion tank. http://i63.tinypic.com/2rm03l4.jpg http://i67.tinypic.com/2ir7u9u.jpg http://i65.tinypic.com/35cj0co.jpg http://i63.tinypic.com/n1s7bt.jpg http://i67.tinypic.com/95vrqs.jpg Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 29, 2018 Author Share Posted August 29, 2018 Unfortunately, the aluminum expansion tank didn't fit with the stock intake pipe so needed to hold off of on it until I get an aftermarket intake haha! Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 30, 2018 Author Share Posted August 30, 2018 For Halloween 2017, for sh!ts an giggles...decided to dress the car up as a Star Wars/Star Tours Starspeeder 3000 haha! http://i68.tinypic.com/28jf50.jpg Attended Subiefest and somehow out of 5000+ Subaru folks, my car was the only few selected to be in Subaru Magazine of Japan! http://i68.tinypic.com/15yc6ko.jpg http://i68.tinypic.com/f07xxg.jpg Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 30, 2018 Author Share Posted August 30, 2018 Before Subiefest, I attended 86Fest and actually won best Subaru Legacy/Outback! http://i65.tinypic.com/htba0p.jpg People were actually digging the Star Tours Starpeeder 3000 theme so decided to leave it on. Towards the end of the year, I attended Subie Invasion in Las Vegas and took home best Subaru Outback! http://i63.tinypic.com/28wozgm.jpg Link to comment Share on other sites More sharing options...
Cruisemobile2 Posted August 30, 2018 Author Share Posted August 30, 2018 Out at Fremont Street in Las Vegas http://i65.tinypic.com/2z9bint.jpg Christmas Tree and hauled by the Starspeeder 3000! http://i64.tinypic.com/25hl2ds.jpg Link to comment Share on other sites More sharing options...
