Seattle, WA: HID kits and misc bits
I have two Retro-Quik kits from The Retrofit Source for sale. Its projectors and adapters only for both kits, but I have some other bits as well. Prices don't include shipping. I can wipe things down with a clorox wipe or whatever if you feel more comfortable. I'm near UW campus, so I can do local handoff in this area.
1: Was in and out of the headlight housing a few times, and shows a bit of wear on the projector body and the adapter plates. The lenses are good. I tested the solenoids, and they're good too. This set has the upgraded bulb holders installed. I managed to lose both an original screw and an extended screw, so there are only 11 total of each. Sealant included: SOLD
2: Effectively new in box, I think I had the adapters out once to compare to the other set I had. Never mounted. Sealant included: SOLD
Sealant: GONE
I have 9006 splitters, so you can power the solenoids in the projectors, if you want: SOLD
I also have a set of 55w, 5500k h1 HID bulbs, ballasts and a dual relay wiring harness from DDM: SOLD
Bulbs available ^: $10
90mm Switchback LED halos. They were mounted up once, but don't appear to have any wear: SOLD
Amber corner lights, in case you want to go clear corners, but the lights need to be yellow *shrug*: SOLD
Gas struts I snagged off RockAuto that I never installed: $10
GrimmSpeed Master Cylinder Brace ('05-'07 GT, non-vdc): SOLD
Edited by PassedTents
