05LegacyGTGa Posted July 25, 2017 Share Posted July 25, 2017 So none of this started happening until after the second time I took my car back after the new dash install. Randomly, when I'm driving with the radio or CD on, there will be a really loud pop from the speakers like someone dropped a mic or something. Then it all cuts off, including the display for the climate control. This unbearable pop will continue until I actually press the knob to turn the stereo off. After that, everything is back to normal. It will do this at least once every time I drive it. I'm afraid this is going to mess multiple things up. Does this sound like a loose connection or something from them having stuff out to do the dash? I've emailed the people I dealt with at the dealership about it, but have gotten no response. By the way, my car is an 05 Limited Wagon, 5EAT, dual climate control blah blah... Any help is greatly appreciated! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 25, 2017 Share Posted July 25, 2017 I'm afraid this is going to mess multiple things up. Does this sound like a loose connection or something from them having stuff out to do the dash? I've emailed the people I dealt with at the dealership about it, but have gotten no response. By the way, my car is an 05 Limited Wagon, 5EAT, dual climate control blah blah... Any help is greatly appreciated! Yes. It does sound like a loose connection. Check the back of the radio unit and make sure all the connections are snug. And see how it goes. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted July 25, 2017 Author Share Posted July 25, 2017 How do I get it out? I haven't done it yet on this car! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 25, 2017 Share Posted July 25, 2017 There must be some walk-thru on the forum for this. But essentially you have to take off the gear shift cover with cigarette lighter the two fake wood garnish on the side of the radio then take out the 6 (or 8 screws) holding the head unit. then pull the head unit and check out the connectors. Link to comment Share on other sites More sharing options...
BLBostonLegacy Posted July 25, 2017 Share Posted July 25, 2017 Sounds like loose ground issues Link to comment Share on other sites More sharing options...
SVXdc Posted July 26, 2017 Share Posted July 26, 2017 This video shows how to remove the OEM head unit from a 2006 (and how to disassemble the HU): Your OEM HU is now ~13 years old, so it may simply be dying. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 26, 2017 Share Posted July 26, 2017 I can't believe these things are that old now. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted July 28, 2017 Author Share Posted July 28, 2017 Yea, I was wondering about it just starting to go out bc of age too. Now I'm having a separate problem. I've had the car 2 years now and yesterday it started running hotter than normal for the first time. I was in traffic, 95 degrees out and the AC running pretty hard. Once I started moving it would cool down. But it seemed like a wide range of temperature. I turned my BtSsm on and I was getting coolant temps from 190 moving to 220 sitting. When I got home I noticed the drivers side fan was't running (even after letting it sit there and letting the coolant temp get up to 110). Could it be the fan? Relay? ECM? The car is an early 05 and I read about some of the issues they had. Could it be something with what the radio is doing? I have yet to doubt this car but kind of nervous after the whole ordeal yesterday! Link to comment Share on other sites More sharing options...
sunny5280 Posted July 28, 2017 Share Posted July 28, 2017 Yea, I was wondering about it just starting to go out bc of age too. Now I'm having a separate problem. I've had the car 2 years now and yesterday it started running hotter than normal for the first time. I was in traffic, 95 degrees out and the AC running pretty hard. Once I started moving it would cool down. But it seemed like a wide range of temperature. I turned my BtSsm on and I was getting coolant temps from 190 moving to 220 sitting. When I got home I noticed the drivers side fan was't running (even after letting it sit there and letting the coolant temp get up to 110). Could it be the fan? Relay? ECM? The car is an early 05 and I read about some of the issues they had. Could it be something with what the radio is doing? I have yet to doubt this car but kind of nervous after the whole ordeal yesterday! Plug the diagnostic connectors (green connectors in the passenger footwell, together and the fans will cycle through a test. If the fans work then it's likely a restriction in your radiator and time for a new one (I had the same problem and it ended up being the radiator). Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted July 28, 2017 Author Share Posted July 28, 2017 Plug the diagnostic connectors (green connectors in the passenger footwell, together and the fans will cycle through a test. If the fans work then it's likely a restriction in your radiator and time for a new one (I had the same problem and it ended up being the radiator). Thanks! I'll give that a try! Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted July 28, 2017 Author Share Posted July 28, 2017 Well, just tried it. Got lots of clicks like the AC compressor and the passenger side fan would come on, but the drivers side fan never did anything...Bad fan? Link to comment Share on other sites More sharing options...
sunny5280 Posted July 28, 2017 Share Posted July 28, 2017 Well, just tried it. Got lots of clicks like the AC compressor and the passenger side fan would come on, but the drivers side fan never did anything...Bad fan? I'd say it's likely. Both my fans cycle when I plug in the connector. It would explain the issue you're experiencing. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted July 28, 2017 Author Share Posted July 28, 2017 I guess I'll try that first. Thanks! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 28, 2017 Share Posted July 28, 2017 good troubleshooting. And yeah 220F is pretty high. So does anybody know if each fan has its own relay? If yes, could be a bad relay instead of a bad fan. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 28, 2017 Share Posted July 28, 2017 looks like there are at least two relays controlling the fans. So that could be the issue. Easiest way to find out is swap the fans to see if the second one still works. I'd doubt it'd be dead actually Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted July 29, 2017 Author Share Posted July 29, 2017 I was thinking it could be a relay too. Will a relay still click when it's bad or not working right? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 29, 2017 Share Posted July 29, 2017 Not sure. Have you tried unplugging the fan that is not working and hooking up directly to the battery? Quick check to see if it works. I've also read last night that the fan could actually be failing, where its bearing dries up or something, making the fan harder to spin, and thereby prone to destroy the relay. Something like that.. Link to comment Share on other sites More sharing options...
sunny5280 Posted July 29, 2017 Share Posted July 29, 2017 looks like there are at least two relays controlling the fans. So that could be the issue. Easiest way to find out is swap the fans to see if the second one still works. I'd doubt it'd be dead actually I'd say it would be easier to swap the relays. I believe I did just that when I was troubleshooting my cooling fan issue. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 30, 2017 Share Posted July 30, 2017 Good point. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 1, 2017 Author Share Posted August 1, 2017 I'm still at the same spot. No one has a relay in stock... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 1, 2017 Share Posted August 1, 2017 So, did you confirm it is a relay problem then? Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 2, 2017 Author Share Posted August 2, 2017 Not 100%. I connected the 2 green connectors and the drivers side fan never came on. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 2, 2017 Author Share Posted August 2, 2017 Just went and swapped relays and did the test with the green connectors again. Still no drivers side fan. I put my finger on the relays while it was going through the test mode and they all feel like they're clicking. Bad fan? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 2, 2017 Share Posted August 2, 2017 Then, I would now unplug the fan and connect it directly to the battery and see if it turns on. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 2, 2017 Author Share Posted August 2, 2017 What would be the best way to do that? Link to comment Share on other sites More sharing options...
